Faster DIG algorithm
Results 1 to 9 of 9
    Sep 2009
    Default Faster DIG algorithm
    Hi, I'm working on battery powered device. I need to extract 4 digits from word variable.
    PORTA.4=1
    TmpB=Pressure DIG 3
    PORTA.4=0
    Looking on my scope it takes 985uS to calculate digit.
    TmpB=Pressure DIG 0 takes 245uS...
    So for 4 digit it need 2.464mS.
    ARRAYWRITE Str,[DEC4 Pressure]
    This is little faster, it takes 2.295mS to execute. But I think it could be done faster...
    Does anyone have idea how to implement it faster?
    I'm goggling for algorithm...
    Jan 2013
    Texas USA
    Default Re: Faster DIG algorithm
    You can reduce the time a tiny bit by performing the operations manually, but just by a few Instruction cycles.
    Here is what I ran in the MPLAB Simulator.
    The times are listed for each method.
    '*  Name    : DigTest.pbp                                       *
    '*  Author  : TABsoft                                           *
    '*  Notice  : Copyright (c) 2015 TABSoft                        *
    '*  Date    : 2/12/2015                                         *
    '*  Notes   : PIC MCU @ 4MHz                                    *
    '*****PIC MCU Configuration Fuses (MPASM)*****
    #IF __PROCESSOR__ = "18F4620"
            CONFIG OSC = ECIO6            ; EC oscillator, port function on RA6
            ;CONFIG OSC = INTIO67	      ; Internal oscillator block, port function on RA6 and RA7
            ;CONFIG  WDT = OFF             ; WDT disabled (control is placed on the SWDTEN bit)
            CONFIG  PWRT = OFF            ; PWRT disabled
            CONFIG  BOREN = SBORDIS       ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
            CONFIG  BORV = 3              ; Minimum setting
            CONFIG  WDT = ON              ; WDT enabled
            CONFIG  WDTPS = 512           ; 1:512
            CONFIG  CCP2MX = PORTC        ; CCP2 input/output is multiplexed with RC1
            CONFIG  PBADEN = OFF          ; PORTB<4:0> pins are configured as digital I/O on Reset
            CONFIG  LPT1OSC = OFF         ; Timer1 configured for higher power operation
            CONFIG  MCLRE = ON            ; MCLR pin enabled; RE3 input pin disabled
            CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
            CONFIG  DEBUG = OFF           ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
            CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
            CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
            CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
            CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
            CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
            CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
            CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
            CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
            CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
            CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
            CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
            CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
            CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
            CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
            CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
            CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    #else
        #ERROR "This program requires a PIC 18F4620 MCU"
    #endif
    OSCCON = $60  ' Set PIC to 4Mhz & ECIO Clock Mode
       ADCON0.0 = 0  ' A/D Converter module is disabled
         ADCON1 = $0F  ' %0000 1111 AN2=VSS, AN3=VDD, AN12-0 = Digital
         ADCON2 = $00  ' %0000 0000
          TRISB = %11111111 ' Set PORTB as input
      INTCON2.7 = 0 ' Enable PORTB pullups
          TRISC = TRISC & %11011111   ' Set PORTC pin directions (pin5 output to RTC VCC2)
    '*****Define LCD registers and bits*****
    define LCD_BITS      4
    define LCD_LINES     2  ' Set to number of lines for the LCD
    Define LCD_DREG      PORTD
    Define LCD_DBIT      4
    Define LCD_RSREG     PORTE
    Define LCD_RSBIT     0
    Define LCD_EREG      PORTE
    Define LCD_EBIT      1
    define LCD_RWREG     PORTE
    define LCD_RWBIT     2
    define LCD_COMMANDUS 1500
    define LCD_DATAUS    44
    pressure var word
    tmpDig0 var byte
    tmpDig1 var byte
    tmpDig2 var byte
    tmpDig3 var byte
    '*****Initialize LCD*****
       Low LATE.2  		    ' LCD R/W line low (W)
       Pause 500       	  ' Wait .5 second for LCD to Initialize
    lcdout $fe,1
    pressure = 1102
    'Start Stopwatch in MPLAB Simulator
    tmpDig0 = pressure dig 0
    tmpDig1 = pressure dig 1
    tmpDig2 = pressure dig 2
    tmpDig3 = pressure dig 3
    'Stop Stopwatch in MPLAB Simulator  = 2962 Instruction Cycles @4MHz = 2.962ms (Fosc/4)
    lcdout $fe,1,dec tmpDig3, dec tmpDig2, dec tmpDig1, dec tmpDig0
    tmpDig0 = pressure // 10
    tmpDig1 = pressure / 10
    tmpDig2 = pressure / 100
    tmpDig3 = pressure / 1000
    tmpDig1 = tmpDig1 // 10
    tmpDig2 = tmpDig2 // 10
    tmpDig3 = tmpDig3 // 10
    'Stop Stopwatch in MPLAB Simulator  = 2086 Instruction Cycles @4MHz = 2.086ms (Fosc/4)
    lcdout $fe,$c0,dec tmpDig3, dec tmpDig2, dec tmpDig1, dec tmpDig0
    TABSoft
    Hi Pedja
    DIG extracts ONE decimal digit ... ( here the 4 th )
    what you are telling is not the same.
    So, ... what exactly do you want to do ???
    Sep 2009
    /My english isn't good. Tabsoft got it right.
    I'll try to explain better...
    I have word variable Pressure.
    I need to extract digits from Pressure variable to 4 different variables for displaying on static 7 segment LCD.
    Offtopic:
    To dive LCD just connect pin to pin LCD with MCU, and in ISR XOR LAT with mask every 20mS or so...
    BANKSEL PORTA 'Select Bank
    MOVLW 11101111b 'Mask unused pins
    XORWF LATA,F 'Invert unmasked pins and write to LATA
    It should have lower power consumption than multiplexed LCD wit LCD module on PIC.
    Back to topic:
    One thing that I tried is to use DIG and 4 variable. If I can extract one digit much faster, then do same thing for all 4 digits. That is why I ask for faster extracting for one variable...
    Other way is to use arraywrite, and DEC4 to extract digit. Each byte in array will have one digit.
    Tabsoft, thank you. You give me an idea:
    Pressure = 1234
    tmpDig0 = Pressure // 10 'tmpDig0 =4
    pressure = Pressure / 10 'Pressure=123
    tmpDig1 = Pressure // 10 'tmpDig1=3
    tmpDig2 = Pressure // 10 'tmpDig2=2
    tmpDig3 = Pressure / 10 'tmpDig3=1
    This will be probably ok. It takes just under 1,5mS.
    I didn't mention that I'm using PBPL and running on intosc at 16MHZ for all test.
    I'm waiting boards to arrive, so I can't measure current consumption jet. So there is always option to go back to PBPW.
    Thank you all.
    Jan 2013
    Texas USA
    I confirmed you observations when I reran the routines @ 16MHz and PBPL.
    I did notice if you use PBP's "DIG" command, the number of instruction cycles used are not consistent for various 4 digit numbers.
    Here is the data I collected.
    Algorithm 1:
    Pressure = 1234
    tmpDig0 = Pressure dig 0
    tmpDig1 = Pressure dig 1
    tmpDig2 = Pressure dig 2
    tmpDig3 = Pressure dig 3
    Algorithm 2:
    Pressure = 1234
    tmpDig1 = Pressure / 10
    tmpDig2 = Pressure / 100
    tmpDig3 = Pressure / 1000
    Algorithm 3:
    Pressure = 1234
    PBPW @ 16MHz
    Algorithm   Inst Cycles     Time
    1           2958            739.50 us
    2           2086            521.50 us
    3           1783            445.75 us
    PBPL @ 16MHz
    1           9626            2.406500 ms
    2           6830            1.707500 ms
    3           5839            1.459750 ms
    Obviously PBPL slows down the routines considerably.
    Good luck.
    TABSoft
    Sep 2009
    Thanks.
    I'll post current consumption when I get PCB.
    Hi guys,
    This is an interesting topic.
    I was wondering if the following line ( i dont know how fast it runs ) can also run faster with the technic shown above:
    LCDOUT $FE,LINE2,"FREQ ",DEC DISPFREQ DIG 2,DEC DISPFREQ DIG 1,",",DEC DISPFREQ DIG 0, " KHz    "
    Best regards
    Rui
    Jan 2013
    Texas USA
    Yes, it will reduce the number of instruction cycles in your example.
    Given that you are only extracting 3 digits of your DISPFREQ variable, Algorithm #2 will be faster.
    Assuming you are using PBPW not PBPL here are the instruction cycles results.
    Using the DIG method: 7606 Inst Cycles
    Using Algorithm #2: 7293 Inst Cycles
    That is a savings of 313 instruction cycles. If you are running a 4Mhz Fosc/4 MCU then that would be a 313us savings.
    Though it is a small savings on cycles and time, it does come at a cost of 3 extra byte variables to hold the values.
    Here are the two code options tested.
    tmpDig0 var byte
    tmpDig1 var byte
    tmpDig2 var byte
    DISPFREQ var byte
    LINE2 con $c0
    DISPFREQ = 1234
    'Output: FREQ 23,4 KHz
    tmpDig0 = DISPFREQ // 10
    tmpDig1 =DISPFREQ / 10
    tmpDig2 = DISPFREQ / 100
    LCDOUT $FE,LINE2,"FREQ ",DEC tmpDig2,DEC tmpDig1,",",DEC tmpDig0, " KHz    "
    TABSoft
    Greetings Tabsoft,
    Thank you for the information and tip.
    Very helpfull !
    Rui
  1. help about ds1804 (dig. pot.)
    By chailuck in forum mel PIC BASIC Pro
    Last Post: - 7th August 2010, 10:33
  2. A Checksum Algorithm
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 8th December 2008, 22:33
  3. DIG DEC Madness
    Last Post: - 13th June 2008, 23:05
  4. Use of DIG, DCD, NCD
    By websmith in forum mel PIC BASIC Pro
    Last Post: - 6th November 2006, 06:14
  5. 'DIG' equivalent in other Languages?
    By Art in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 22:43
