port handle
Results 1 to 7 of 7
Thread: port handle
    Nov 2007
    sri lanka
    Default port handle
    dear
    i want to write something like this
    go_sub1:
    go_sub2:
    go_sub3:
    go_sub1:
    high porta.0
    go_sub2:
    high portb.1
    go_sub3:
    high portb.2
    my pboblem is program goto first go_sub0: then high portb.0 then program goto go_sub1: then high portb.1 but low portb.0.
    please write me example for this i want to do portb.0 stay on high with second step.
    thank you
    Default Re: port handle
    go_sub1:
    high porta.0
    But you are using PORTA in your code.
    Post your actual code and we will see what can be done.
    Nov 2007
    sri lanka
    dear sir
    i have some mistake
    iwant to handle portA
    go_sub1:
    go_sub2:
    go_sub3:
    go_sub1:
    high porta.0
    go_sub2:
    high porta.1
    go_sub3:
    high porta.2
    May 2007
    When performing bit write operations on PIC16s, this is something you have to watch out for.
    Reading the PORTx register reads the status of the pins, whereas writing to it will write to the PORT latch. All write operations are read-modify-write operations. Therefore, a write to a port implies that the port pins are read, this value is modified and then written to the PORT data latch.
    Many chips have analog funtions on PORTA, did you turn the ADC off?
    Nov 2007
    sri lanka
    use 16f877a
    Adc off
    can u help me.with example
    thank you
    Did you get the main program structure working?
    If it still acts funny, it's probably because the GOTO MAIN in the subroutines always goes back to the top of the program. Only SUB1 will get executed.
    What about something like this?
    GOTO MAIN              ' Skip over subroutines
    Sub1:
    high portB.0
    Sub2:
    high portB.1
    Sub3:
    high portB.2
    MAIN:
      GOSUB Sub1
      GOSUB Sub2
      GOSUB Sub3
    I would recommend starting with Port B for your testing. You can use Port A later once you have a simple program working.
  1. 18F2520 - problem configuring fuse for port B as digital port.
    By hwhisperer in forum mel PIC BASIC Pro
    Last Post: - 11th October 2010, 11:41
  2. PIC16F887 cant handle HIGH and LOW?
    By xobx in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 04:46
  3. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 08:44
  4. How many serial ports can 1 PIC handle?
    Last Post: - 2nd March 2005, 04:34
  5. Duplicating port input to port output
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 21:43
