you do not need to ask for any code, as the Hex file to load into your Pic is provided within your link ... !!!
http://www.ivica-novakovic.from.hr/H...s/IrOn-Off.hex
just copy and paste it into your programmer ... et voilą !
I know that mr .acetronics and thank you to the hint but i need orginal code to insert it inside my own bigger program that contain more functions..and it does not matter what kind of pic but the idea is how can you capture data from any remote and save it inside the micro( any pic)
There is a pretty good APP NOTE over on the Parallax Basic Stamp web site.
I tried to attach the .pdf file here but it fails.
If you google "parallax remote ir" you will get a couple of hits on IR protocol and implimenting IR comms using BASIC.
PBP is quite similar to the BASIC used in the Basic Stamp microcontroller. So it should not be too dificult to apply what is contained in those app notes to PBP.
Certainly if the Basic Stamp can do it then most any PIC can do it better
Dwight
Thank you mr.heckler ...it is realy good site and i got some good ideas from it ...and i traid to write code .. but the main proplem is that thair codecs depend on known ir protocol like sony or rc5 but my need is treating with unknown ir protocol (from any remot control) .................realy i spend 10 hour in one set on net and i failed ....thair are many projects about ir dimmer circuit depend on the same idea but the programmers execuse about orginal code and offer just hex file
Download this file. It explains all these IR stuff you need.
It is still not solved.....
