Hi shahidali55,
If your display is large and has long wires , it may well be acting as an antenna, try decoupling caps on each output line going to it, as well as any inputs, also try hooking all ground connections to a single ground connection, as ground loops often cause electronic circuits to oscillate, That is what they used to do in high end audio gear.
HTH
JS
