2 PIC's 1LCD
Results 1 to 3 of 3
Thread: 2 PIC's 1LCD
    puma's Avatar
    puma Guest
    Lightbulb 2 PIC's 1LCD
    hi,
    I need some help on this one.
    Its not a real case but it could be a real case if it where possible.
    Lets say I have an application with consists out of 2 pic's.
    And I have an 16x2 LCD or an 14x4 LCD, doesn't matter for this example.
    Then I have enough pins left on each PIC to drive an LCD parallel in 8bit mode with the lcdout command.
    Now it comes: Can I connect those 2 PIC's in parallel with the LCD and have Pic1 put info on line1 and pic2 info on line2 (in case of 16x4 lcd pic1 puts info on line 1&2 en pic 2 Puts info on line 3&4)
    If it is possible any thoughts?
    The Puma
    Dec 2003
    Wichita KS
    Hello Puma,
    Puma>>I need some help on this one.
    If it is possible any thoughts?<<
    Never thought of that.... I guess i would suggest putting diodes on both chips for the pins going to the LCD. That way there can be some protection...give it a try and tell us!
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Andy M's Avatar
    Andy M Guest
    Sounds like you might need some sort of way for the PICs to let each other know when they are sending data to the LCD. Yes, please let us know what you come up with!
  1. 2 Pics, different baud rates needed
    By peter_wiersig in forum Serial
    Last Post: - 27th February 2010, 15:51
  2. connect 2 PICs
    By drama in forum mel PIC BASIC
    Last Post: - 4th October 2007, 16:55
  3. Microcontroller with 2 way paging application problem
  4. Transceivers with 2 different PICs.
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2006, 09:31
  5. help about connecting 2 PICs
    By micro in forum mel PIC BASIC
    Last Post: - 1st January 2006, 13:52
