How to configure SPI in PICBASIC PRO?
Results 1 to 14 of 14
Threaded View
    Mar 2007
    Default How to configure SPI in PICBASIC PRO?
    I tried to configure two PIC16F877As as SPI master and SPI slave. Pls refer to schematic shown in figures in attachment. Master will send a '?' to acknowledge the slave. Then, the slave will reply with a '!'. Once master receives '!', it will start to receive data from slave, which is a '5' character. The charater will then be displayed on the LCD.
    The SPI communication between the master/slave did not work. Pin B0 of master is connected to A5/SS of slave. Pls advise if you find mistakes in the schematic as well as the source code.
    For your information, I'm using PicBasic Pro 2.47 compiler.
    Source Code (MASTER)
    ' PicBasic program to demonstrate operation of an LCD in 4-bit mode
    ' LCD should be connected as follows:
    '       LCD     PIC
    '       DB4     PortD.4
    '       DB5     PortD.5
    '       DB6     PortD.6
    '       DB7     PortD.7
    '       RS      PortD.2
    '       E       PortD.3
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    '       Vo      10K potentiometer (or ground)
    ' PicBasic Pro program to read and write to SPI slave
    ' using the synchronous serial port
    ' Connect SDI(master) to SDO(slave), SDO(master) to
    ' SDI(slave), AND SCK(master) to SCK(slave).
    ' Common Ground is required.
    ' Sends ascii "?" to request data, waits for a "!" to
    ' begin receiving data. Expect to receive "5" (without quotes)
    ' from slave and display it LCD.
    DEFINE LCD_LINES 4 'number of LCD lines
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTD
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 40
    SSPEN  VAR  SSPCON.5 'SSP Enable bit
    CKP  VAR  SSPCON.4 'Clock Polarity Select
    SMP  VAR  SSPSTAT.7 'Data input sample phase
    CKE  VAR  SSPSTAT.6 'Clock Edge Select bit
    SSPIF  VAR  PIR1.3  'SPI interrupt flag
    a  VAR  BYTE
    TRISC = 0   'set PORTC I/O
    TRISB = %11111110  'set PORTB.0 as output
    SSPEN = 1   'enable SPI pins
    CKP = 0    'clock idle low
    CKE = 0    'transmit on idle to active transition
    SSPIF = 0   'clear buffer full status
    SMP = 0    'sample in middle of data
    LOW PORTB.0
    loop:
    GoSub getdata   'initiate conversion and receive data
    LCDOut $fe, 1,
    LCDOut #a
    Pause 1000
    GoTo loop   'do it forever
    getdata:
    HIGH PORTB.0   'enable ss pin
    SSPBUF = "?"   'send ? to start conversion
    GoSub letclear   'wait for buffer to clear
    IF SSPBUF<>"!" Then getdata 'wait for reply (!)
    SSPBUF = 0   'write to SSPBUF to start clock
    GoSub letclear   'wait for receipt
    a = SSPBUF   'store received character in array
    LOW PORTB.0
    letclear:
    IF SSPIF = 0 Then letclear 'wait for SPI interupt flag
    PauseUs 25   '25uS fudge factor
    SSPIF = 0   'reset flag
    Source Code (SLAVE)
    ' PicBasic Pro SPI slave program (see SPImast.bas for connections)
    dataout  VAR      WORD
    SSPIF  VAR  PIR1.3  'interrupt flag - last bit set
    TRISC = %11011111  'set PORTC I/O
    TRISA = %11011111  'set PORTA.5 as input.
    SSPCON = %00000100  'configure SPI slave, enable SS pin
    SSPIF = 0   'clear SPI interrupt
    dataout[0] = "5"
    loop:
    SSPEN = 0   'disable/enable SSP to reset port
    SSPEN = 1
    GoSub letclear   'wait for byte received
    IF (SSPBUF <> "?") Then loop 'wait for ? to start conversion
    GoSub senddata   'send "!" and string of data
    senddata:
    GoSub letclear   'wait until buffer ready
    SSPBUF = "!"   'send reply
    SSPBUF = dataout[0]  'send variable
    letclear:
    IF SSPIF = 0 Then letclear 'wait for interrupt flag
  1. VB.net and Picbasic Pro
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 20:18
  2. Replies: 0
    Last Post: - 22nd November 2005, 13:16
  3. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 17:15
  4. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 21:19
  5. PicBasic Pro FSK Modem
    By mikep in forum mel PIC BASIC Pro
    Last Post: - 29th October 2003, 14:21
