Matrix Keypad routine - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 135
  1. #81
    I found this solution which was already in the forum, thanks
    OK NO NEED FOR THAT
    i've attach the latest version... which i thought i had posted here
    So the only thing you will have to do, is to add this simple line
    DEFINE SCAN_ONCE 1
    And this should cure the problem.
    I have added this feature once i needed to scan a keypad with a timer interrupt... which is certainly the way to go for any Push-Button/Keypad entry anyways.
    Enjoy!
  2. #82
    This is an update to the PM version of Steve's Matrix Keypad routine.
    Steve added a SCAN_ONCE option after I converted it for PM.exe. And someone recently asked for an update to it. It took me so long to do it, I forget who asked.
    Note: This is for PM only. It will not work with MPASM.
    HTH,
    Jan 2007
    Houston, TX
    Wink thanks guys
    T. Jackson & Mr. E,
    Nice work to both of you regarding Matrix Keypads!
    I have used Trents example with great success, I plan on trying out Mr. E's with a handheld Wireless panel/LCD I put together for work. I want to add a 4x4 matrix keypad to the front of the reciever case and upgrade my TXM/RSM LR LINX modules to the new LT tranciever type. I really think having the matrix keypad will expand (the crap out of) the types of commands I can send.....wall mounted reciever, robot, whatever....
    Padawan-78
  4. #84
    Jan 2007
    Houston, TX
    Red face
    Hello,
    Just an hour ago I tried to include Mr. E's Keypad.bas file in pbp folder and my local "pic_programs" folder. I DID rename the txt file and saved it to .BAS file.
    Here is the code....
    INCLUDE "KeyPad.bas"
    myvar var byte
    start:
        @ READKEYPAD _myvar
        hserout ["Key=",dec myvar,13,10]
        'LCDOUT 254,ROW1,"COMMAND", DEC MYVAR
        goto start
    Won't compile....
    I keep getting lots of "opcode expected instead of....'kb_row','kb_col', 'debounce_delay' " errors. I did read the thread about the errors found when you don't save as a .BAS file but I must not be seeing something obvious, happens to me alot on this forum.
    Mr. E could you lend a hand,
    I am using version 2.50A & PM assembler
    Padawan-78
  5. #85
    With Steve's version, you have to use MPASM.
    For PM, use the version I recently uploaded to Post#82
    hth,
    Oct 2008
    Exclamation Need help desperately!!!
    I'm doing a temperature control system. Pretty new to PIC programming. I have managed to display temperature on the LCD using an LM35 sensor and a 16 x 2 lcd with a 16F873. I want to add on a 4 x4 matrix keypad so that i can set setpoints to switch a relay and a low warning buzzer I have no idea how to program for the above mentioned add-ons. Please could someone help me. below is my code which will obviously need additions and a scematic of my circuit is attached . Please could somebody help me with this!!
    Define LCD_DREG PORTB
    Define LCD_DBIT 0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 5
    Define LCD_EREG PORTB
    Define LCD_EBIT 4
    dEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    adval var word ' Create adval to store result
    temp var word ' Create temp to store result
    temp1 var word ' Create temp1 to store result
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10000010 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %11000001 ' Configure and turn on A/D Module
    Pause 100 ' Wait 0.1 second
    loop: ADCON0.2 = 1 ' Start Conversion
    AGAIN: Pause 1
    If ADCON0.2 = 1 Then AGAIN ' Wait for low on bit-2 of ADCON0, conversion finished
    adval.highbyte = ADRESH ' Move HIGH byte of result to adval
    adval.lowbyte = ADRESL ' Move LOW byte of result to adval
    Lcdout $fe, 1 ' Clear screen
    temp=50*adval ' Conversion to Degrees
    temp=temp/100
    Lcdout "TEMP = ",DEC temp,$DF,"C" ' Display the value of temp
    temp1 = temp*18 ' Conversion to Fahrenheit
    temp1 = temp1+320
    temp1 = temp1/10
    lcdout $FE,$C0, "TEMP = ",dec temp1,$DF,"F" ' Display the value of temp
    Pause 1000 ' Wait 1 second
    Goto loop ' Do it forever
  7. #87
    Quote Originally Posted by Kalind View Post
    Schematic for keypad connection to a PIC is talked about at the beginning of this thread. If you need a schematic, draw it up... Shouldn't be that difficult at all...dontcha think?
    As far as the code goes, you've gotten this far (or have you? Ctrl-C/Ctrl-V)...
    Why not write some code, doesn't even have to be real code, just talk yourself thru it, and type it out as you talk. After you see it written down, you just might be able to write the code yourself.
  8. #88
    Oct 2008
    Question
    i have written this code. its just that im really confused and lost as to how to begin with the keypad. i kinda figured out how to hook up the keypad though. i just need help as to how to go about doing the code
  9. #89
    I am HELPING. No need for whiney PM's.
    Key word here is HELPING...not DOING.
    I think you'll find a whole lot of people around here willing to HELP...some might even be willing to DO.
    Write some code, in fact, don't even write code, just write a sequence of thoughts of how you think the program should operate. The code will follow. That's how it works. You think about something and it happens eventually.
    As far as your keypad goes, what's wrong with the code that's provided earlier in the thread? I use it...works great for me.
  10. #90
    Oct 2008
    well, i was thinking that when i push "Button A" of the keyapd, the upper setpoint will be displayed, "Button B" = Lower limit, "Button C" = Backspace, "Button D" = OK , "Button *" = alarm on/off, "Button #" = Main screen
  11. #91
    Ok, so you've defined the FUNCTIONs of the buttons...now how to you act on those functions.
    In fact, do yourself a favor and just work on adding one button at a time...
  12. #92
    Oct 2008
    thats my point. I have no idea where to begin...i was thinking maybe scan keypad first, check if A or B was pressed and if so then act upon it by prompting the user to enter a desired setpoint. once that's done, press ok and return to the main display screen. the alarm can be set on for the desired lower setpoint and once the upper setpoint has been reached, the relay should switch on. vice versa
  13. #93
    Then write some code and see how it works!
    If it doesn't work, post the code, and I'm sure somebody will help you figure it out.
  14. #94
    The first thing to do is open Mr. E's Keypad.bas and read the instructions he wrote for you.
  15. #95
    Well the answeris in mister E's code, it works very well give it a true it is very well documented and easy to use
    Walter
    Define LCD_DBIT 0
    Define LCD_RSBIT 5
    Define LCD_EBIT 4
    dEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    AGAIN: Pause 1
    temp=temp/100
    temp1 = temp1+320
    temp1 = temp1/10
    Oct 2008
    Question
    ok, now that i have e's keypad code, how do i implement the idea that i mentioned in #90?
  17. #97
    Do you have the code working?
    What happens when "A" is pressed now?
  18. #98
    InterruptHandler:
    @ READKEYPAD _MyVar
    resume
    'now your key reading is stored in MyVar
    most 16 key keypads are laid out 123A 456B 789C *0#D, so 1=1 2=2 3=3 A=4 4=5 . . . .
    You can use this as is or use a lookup routine to alias the actual port reading to what
    you want, like so:
    lookup MyVar,[0,"123A456B789C*0#D"],MyOtherVar
    now your key information stored in myOtherVar will mirror your keypad.
    so . . .
    If myothervar = A then gosub Uppersetpoint
    if MyOtherVar = b then gosub . . . .easy
  19. #99
    Oct 2008
    Hay guys and girls. I've been playing around with this coding this afternoon and i keep getting errors and when i dont nothing going as i thought it should so any chance somone could point out whats wrong please or point me in the right dirrection at least!
    My main coding:
    TRISA=%00000011
    TRISB=%00000000
    TRISC=%11111110
    ADCON0=%11000000
    ADCON1=%00000111
        '    Hardware connection
        DEFINE KEYPAD_ROW        8       ' 8 row
        define KEYPAD_ROW_PORT   PORTc   '   on PORTB
        DEFINE KEYPAD_ROW_BIT    0       '      <7:0>
        DEFINE KEYPAD_COL        4       ' 4 col
        DEFINE KEYPAD_COL_PORT   PORTc   '   on PORTA
        DEFINE KEYPAD_COL_BIT    0       '      <3:0>
        DEFINE KEYPAD_DEBOUNCEMS 200     ' debounce delay = 200 mSec
        define KEYPAD_AUTOREPEAT 1       ' use auto-repeat
    ' LCD Display
    ' Adjust these to suit your chosen LCD pinout
    DEFINE LCD_DREG PORTb 			'Define PIC port used for LCD Data lines
    DEFINE LCD_DBIT 4 			'Define first pin of portb connected to LCD DB4
    DEFINE LCD_RSREG PORTb 			'Define PIC port used for RS line of LCD
    DEFINE LCD_RSBIT 3 			'Define Portb pin used for RS connection
    DEFINE LCD_EREG PORTb 			'Define PIC prot used for E line of LCD
    DEFINE LCD_EBIT 0 			'Define PortB pin used for E connection
    DEFINE LCD_BITS 4 			'Define the 4 bit communication mode to LCD
    DEFINE LCD_LINES 2 			'Define using a 2 line LCD
    DEFINE LCD_COMMANDUS 2000 		'Define delay between sending LCD commands
    DEFINE LCD_DATAUS 50 			'Define delay time between data sent.
        '    Serial Communication definition
        DEFINE HSER_TXSTA 24h            ' enable transmit, BRGH=1
        DEFINE HSER_SPBRG 129            ' 9600 Bauds
        '    Variables definition
        myvar                    var byte
        '    ---------------------------------[Program Start]----------------------------------------------
    start:
        @ READKEYPAD _myvar
    	gosub lcddisp
        goto start
    lcddisp:
    LCDOUT $FE, 1, myvar
    pause 60
    The modified Keypad code
    TRISA=%00000011
    TRISB=%00000000
    TRISC=%11111110
    ADCON0=%11000000
    ADCON1=%00000111
    ' LCD Display
        myvar                    var byte
    start:
        @ READKEYPAD _myvar
    	gosub lcddisp
        goto start
    lcddisp:
    pause 60
    forgot to put the error code
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F876A "KEYPADTE.ASM" /l"KEYPADTE.lst" /e"KEYPADTE.err"
    Error[113] C:\PBP\PBPPIC14.LIB 2784 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2785 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2789 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2790 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2800 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2871 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2889 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2913 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2920 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2928 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\PBPPIC14.LIB 2934 : Symbol not previously defined (PORTb)
    Error[113] C:\PBP\KEYPADTE.ASM 100 : Symbol not previously defined (PORTc)
    Error[113] C:\PBP\KEYPADTE.ASM 103 : Symbol not previously defined (PORTc)
    Error[113] C:\PBP\KEYPADTE.ASM 125 : Symbol not previously defined (PORTc)
    Error[113] C:\PBP\KEYPADTE.ASM 136 : Symbol not previously defined (PORTc)
    Halting build on first failure as requested.
    BUILD FAILED: Thu Nov 20 16:00:57 2008
  20. #100
    YUP, that's what happen when you don't check the spelling of your DEFINEs. DEFINEs are case sensitive. So PORTb have to be written PORTB, and so on with all others.
  21. #101
    Oct 2008
    Cheers, so any clues as to whats wrong now? i dont get any reaction on the LCD and i get several ports flash high then low
  22. #102
    well...
    looking at your schematic bellow
    There's some problems there for sure... You don't use a 8X4 keypad
        DEFINE KEYPAD_ROW		4
        DEFINE KEYPAD_ROW_PORT   	PORTC
        DEFINE KEYPAD_COL        	3
        DEFINE KEYPAD_COL_PORT   PORTC
        DEFINE KEYPAD_COL_BIT    	4
  23. #103
    Oct 2008
    Thanks yet again mister_e! You should move in with me, that way i wouldnt have to use the net to bother yo every other day
    and yes i put the dec2 myvar on the lcdout command so all works now
    time to play with it some more!
  24. #104
    da_cure_4_u's Avatar
    da_cure_4_u Guest
    Default Scan
    I would like to scan a 4x4 keypad to use as a calculator on PIC16F88.
    anyone can help please???
  25. #105
    Try something by yourself first.
    1. Download the Keypad Include file,
    2. Find LCDOUT in your manual,
    3. Use the example I gave in POST #1 and you're almost half done if you replace HSEROUT with LCDOUT.
  26. #106
    Default 4x4 keypad on an 184520 - newbie help
    Hi all
    Please would somebody be so kind as to shed some light on the problem I am experiencing.
    I am busy re-kindling my hobby and interest in PIC programming, I think these forums are an excellent resource, somehow all roads lead back here after many a google search and reading post after post and numerous articles.
    After 3 weeks of late nights and sore eyes and a lot of reading later I have finally gotten to a stage where I have a functional (perhaps a very under-utilized PIC 18F4530).
    After having blinked LED's and read switches and getting my LCD working I would like to implement a keypad as opposed to a bank of dip switches.
    I am trying to implement the keypad.bas file submitted by mister_e (Thanks mister e ... your code looks fantastic, I'm dying to use it properly :-)
    So here's where I'm at now....
    I am trying to connect a 4 x 4 matrix keypad to my 18F4520 PIC.
    Ultimately I would like to be able to be able to type in a number, end it with a # to signify completed input and then transmit the inputted number to another pic either wired or wireless.
    The keypad layout is as follows.
    my keypad matrix
    1 2 3 A
    4 5 6 B
    7 8 9 C
    * 0 # D
    I have connected the keypad to the pic as follows.
    Keypad PIC
    Column 0 PortA.0
    Column 0 PortA.1
    Column 0 PortA.2
    Column 0 PortA.
    Row 0 PortC.0
    Row 1 PortC.1
    Row 2 PortC.2
    Row 3 PortC.3
    10K pullups set on column inputs
    100 Ohm resistors in series with rows
    When I have the above configured my LCD just produces blocks
    If I remove either the pullups and/or the series resistors I just get "Key Value" 20 continuously appearing on the LCD and if I press a key on the keypad I get the "key Value" changing on the LCD but it is not the correct value according to my keypad.
    I could also use the whole of Port A but when I tried it but had the same results :-(
    Initially I tried to connect on PortB and had the same results, so I assumed it was because I was getting inputs from pin 39 and pin 40 of the pic where the PICkit 2 is connected for ICSP.
    I have attached my code below.
    Please could someone advise as to where I am going wrong or what I could look at to fix the problem !
    I think it could be a possible CONFIG problem or coding issue in my code.
    Any help would be greatly appreciated.
    Kind regards
    Dennis
    'LCD code for 16 X 2  HD4x lcd
    'Ocsillator selections here
    OSCCON = $70            'Int CLK 8MHz
    OSCTUNE.6 = 1           'PLL 4x
    ADCON1= %00001111       '$0F = disable A/D converter
    'END of oscillator selections
    'Port IO directions and presets for port pins begin here
    'TRISA = %11111111       'All pins are outputs
    TRISA.0 = 1
    TRISA.1 = 1
    TRISA.2 = 1
    TRISA.3 = 1
    TRISB = %00000000
    'TRISC = %00000000
    TRISC.0 = 1
    TRISC.1 = 1
    TRISC.2 = 1
    TRISC.3 = 1
    TRISD = %00000000
    TRISE.0 = 0
    TRISE.1 = 0
    TRISE.2 = 0
    'End of Port IO directions and presets for port pins begin here
    'timer/oscillator defines
    DEFINE OSC 32            '4x 8MHz
    'END of timer/oscillator defines
    'variables begin here
    myvar var byte
    'LCD defines begin here
    DEFINE LCD_BITS 4 	'defines the number of data interface lines (4 or 8)
    DEFINE LCD_DREG PORTD 	'defines the port where data lines are connected to
    DEFINE LCD_DBIT 4 	'defines the position of data lines for 4-bit interface (0 or 4)
    DEFINE LCD_RSREG PORTD 	'defines the port where RS line is connected to
    DEFINE LCD_RSBIT 2 	'defines the pin where RS line is connected to
    DEFINE LCD_EREG PORTD 	'defines the port where E line is connected to
    DEFINE LCD_EBIT 3 	'defines the pin where E line is connected
    DEFINE LCD_RWREG 0 	'defines the port where R/W line is connected to (set to 0 if not used)
    DEFINE LCD_RWBIT 0 	'defines the pin where R/W line is connected to (set to 0 if not used)
    DEFINE LCD_COMMANDUS 2000 	'defines the delay after LCDOUT statement
    DEFINE LCD_DATAUS 200 		'delay in micro seconds
    'END of LCD DEFINES
    'KEYPAD 4x4 defines begin here
          DEFINE KEYPAD_ROW        4        ' 4 ROW keypad
          DEFINE KEYPAD_ROW_PORT   PORTC    ' ROW port = PORTB
          DEFINE KEYPAD_ROW_BIT    0        ' ROW0 = PORTB.4
          DEFINE KEYPAD_COL        4        ' 4 COL keypad
          DEFINE KEYPAD_COL_PORT   PORTA    ' COL port = PORTB
          DEFINE KEYPAD_COL_BIT    0        ' COL0 = PORTB.0
          DEFINE KEYPAD_AUTOREPEAT 1        ' use auto-repeat feature
    'End of KEYPAD defines
    '*********************Includes******
    include "C:\PBP\SAMPLES\KeyPad.bas"
    'Includes end here
    'Code begins here
       Pause 500       ' Wait for LCD to startup
    start:
    @ READKEYPAD _myvar
    lcdout $fe, 1
    lcdout " Key Value = ",DEC2 myvar
    goto start
  27. #107
    Default Solved !!
    My problem in the previous post here is now solved.
    The keypad is working.
    But I now am trying to solve 2 more problems
    1. I need the keypresses to reflect the correct label
    My matrix is
    1 2 3 A
    4 5 6 B
    7 8 9 C
    * 0 # D
    At the moment I get the following 1,2,3,4 as opposed to 1,2,3,A
    2. I would like to capture a number of keystrokes as I type them in for example 135 completing input with a #
    So the number stored will be the number decimal 135
    Any help or suggestions will be most appreciated.
    Kind regards
    Dennis
    For example keypress1
  28. #108
    An idea would be to use the lookup command for your translation from numbers to numbers-ASCII conversion.
    Now about the numbers to assebly in a byte. What is the range of your input?
    0-255 or 0-999?
    Hi Ioannis
    Thanks for the reply :-)
    Lookup is already implemented and working .
    My range would be anything really (inifinity ??) but I guess I could use 0 to 999
    It's like dialling on a phone ... you dial the numbers and then press the dial button :-)
    I want to type numbers in and then press the # key and * to backspace or clear last entry ...
    Kind regards
    Dennis
  30. #110
    Well, if you go for the 999 then a 0-65535 is possible as the final result needs a word variable.
    One idea untested is this:
    array   var byte[5]
    index   var byte
    i       var byte
    word_v  var word
    'Get keypress
    index=0
    loop:
    gosub key_read
    if mykey=32 then loop 'No key press returns 32
    array[index]=myvar
    index=index+1
    if index=5 then calculate_result
    goto loop
    caculate_result:
    word_var=0:mult=10000
    for i=index-1 to 0 step -1
        word_var=word_var*mult+array[i]
        mult=mult/10
    next i
    index=0
    goto display_result
    As there is the index counter, there is no need to press '#'. Numbers must be entered in 5 digit format, e.g. 00123.
    Also there is no filter if the user keys in a number greater than 65535, in which case result will be of course wrong due to overflow.
  31. #111
    Default ooops
    Hi Ioannis
    Thank you for the code example... I'm just thinking that perhaps it would indeed be more practical to use 255 as the max number, in which case I would need to declare a byte as opposed to a word ...not so ?
    Kind regards
    Dennis
  32. #112
    Yes, that is correct. Rest applies of course.
    But don't be afraid of the word variable!
    Default help with a small change
    Hi all
    The keypad code has been working very well ! Thanks mister_e!
    Initially I had to wire alter the wiring to the keypad to the PIC to get things working now in order to match the header pins for PORT B on a dev board I am building I need to alter the include file somehow to match my keypad.
    I was hoping someone could point me in the right direction for this or tell me where to change the code to match the desired pin configuration.
    Here is what I have now:
    EXISTING CONFIG (WORKING)
    Columns Rows
    ______________ _____________
    Keypad 7 6 5 4 3 2 1 0
    PIC B4 B5 B6 B7 B0 B1 B2 B3
    Here's what I would like to be
    DESIRED CONFIG
    Columns Rows
    PIC B7 B6 B5 B4 B3 B2 B1 B0
    I would appreciate any help/info
    Kind regards
    Dennis
  34. #114
    Default Here's a picture to better explain it
    Check the attached file
    Dennis
  35. #115
    Steve's keypad routines won't let you reverse the orders like that.
    But you can re-map the keys to whatever you want.
    By reversing both the columns and rows, I think it would come out like this ...
    @ READKEYPAD _myvar
    ; original keys   1  2  3  4  5  6  7 8 9 10 11 12 13 14 15 16
    LOOKUP  myvar,[0,16,15,14,13,12,11,10,9,8, 7, 6, 5, 4, 3, 2, 1],myvar
    Which should also work like this ...
    myvar = 17 - myvar
    If they don't line up right, you can change the LOOKUP to a pattern that matches.
    hth,
    Default awesome
    Thanks Darrel
    Will give it a shot and feedback results here :-)
    Dennis
  37. #117
    Default Fixed!!
    Hi Darrel
    Thanks for the assistance :-)
    The LOOKUP change was the easiest solution !
    originally I had this
    @ READKEYPAD _myvar  'read keypress variable and place in myvar
    LOOKUP myvar,[0,"123A456B789C*0#D"],myvar 'use lookup table to diplay proper keypress
    And I just changed the line to this
       LOOKUP myvar,[0,"D#0*C987B654A321"],myvar
    Thanks a million , it saves me having to redo my dev board design or re-wiring the keypad :-) YAY
    Kind regards
    Dennis
  38. #118
    Feb 2008
    Michigan, USA
    Default Fail enought times and you start to learn!
    HI all,
    I have been playing with this wonderful piece of code for many hours. Really cool code. I was having problems with one row of the keypad but the rest was working enough for me to proceed filling in the gaps and learning the lessons from the thread. I bring this up because I have been caught on it before, you would have thought I'd have learned....
    The row in question would freeze the operation of the circuit. Upon looking closely at the datasheet, I my eye caught the LOW VOLTAGE PROGRAMMING option. A faint voice in my head reminded me that we were not friends (the option, not the voice). Yep, that was it. Disabled it in meLabs programmer and... you guessed it... runs just like it was suppose to. Who'd a thought it?
    Hope that this saves someone else some head banging. Some gotchas I have to keep reminding myself about.
    Bo
  39. #119
    Feb 2008
    Michigan, USA
    Default Converting in Steve's include
    Hi all,
    I have managed to get Steve's (Mister E) KeyPad.bas to remap and do what I would like to accomplish. Thanks again Steve for writing it and you others for explaining it. Really handy!
    Here's the question: Where in KeyPad.bas would you insert the "LOOKUP myvar,... " so that you only had to do it once and not burn up a bunch of space? In my case, I would save the original, and rename the converter custom version to something appropriate.
    From what I can decipher, (which is embarrassingly meager), the include file sets up a macro if you choose to use "@ READKEYPAD _YourVar". It gets the result from the subroutine "KeypadScan".
    Am I right that the "LOOKUP..." would go just before the "ReadCol:"
    subroutine to allow the remapping to occur each time you look for a key?
    Bo
  40. #120
    Feb 2008
    Michigan, USA
    Default Appologies
    I'm sorry to the list....
    After I posted that last question, it hit me like a brick... That was being really immature... I knew what I wanted to happen, but I hung when I saw a bit of code that was confusing to me. I had an idea what might work but instead of trying to test it myself, I defaulted to asking the list. Very poor.. I should have at least tried something and done some of my own work first instead of asking others to do it for me.
    My feeble assumption proved so far to be correct, by adding the LOOKUP into what I now call KeyPadRM.bas (the RM for ReMap), and making sure to save it as a .bas, I can eliminate many redundant lines of code. The edit is at the end of Steve's code:
                until row>(KB_ROW-1)
            if (single_scan=0) AND (KEY=0) then ScanKeypad     ; Row scan finished?
      LOOKUP  Key,[0,1,2,3,10,4,5,6,11,7,8,9,12,15,14,16,13],Key ; ReMap Edit
          RETURN                                                 ; any key pressed?
    ReadCol:
        KeyTemp=kb_col_PORT>>kb_col_Bit                        ; Read Column state
        KeyTemp=KeyTemp & kEYMASK                              ; Keep only wanted bits
    JumpOverKeyScan:
    Any corrections of my understanding are welcome.
    Bo
  1. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 22:58
  2. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 13:16
  3. I2C PCF8574 4X4 Keypad routine
    Last Post: - 28th January 2007, 21:25
  4. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 03:54
  5. very basic matrix keypad question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 21:33
