![Quote](images/misc/quote_icon.png)
Originally Posted by
sean-h
Using easyhid is not that bad.
Basic steps are run up the easyhid program and set the basics like Pid/Vid and buffer size for bytes you want to send back and forth from PC to Pic.
It then by default creates two folders under a top level folder called USBProject
The first folder is PICBasicPRO
This contains the basic code you will need for your pic chip and the include files, do not rename or move this directory once it is created, work from this location.
It will create a example PBP file called USBProject.pbp
So open this up and the main program loop you are interested in is:
usbinit ' initialise USB...
ProgramStart:
gosub DoUSBIn
gosub DoUSBOut
goto ProgramStart
For receving and sending data you just need these two routines.
If you wanted to receive say 10 bytes then it does matter that your buffer is set to 64 bytes because that is the packet size that is going to be received from the PC anyway, so do not worry about this. Just tell it to jump off to that routine and as soon as data is received it will come back from that routine with the usbbuffer(0) to usbbuffer(63) filled as such.
So if your PC sent 10 bytes then the variables usbbuffer(0-9) will hold those 10 bytes, if your pc sent 20 bytes then usbbuffer(0-19) will hold those bytes.
So say you wanted to send 4bytes from your PC to the Pic and then the Pic displays it on the LCD, you could do this:
ProgramStart:
gosub DoUSBIn
LCDOUT $FE,1,usbbuffer(0),usbbuffer(1),usbbuffer(2),usbbu ffer(3)
goto ProgramStart
If you then wanted to send say two bytes back to the PC to say you received them, then just load up your usbbuffer variables and jump to the routine gosub DoUSBOut.
So to send "OK" back to the PC add this to your code.
ProgramStart:
gosub DoUSBIn
usbbuffer(0)=79 'Ascii value for O
usbbuffer(1)=75 'Ascii value for K
gosub DoUSBOut
goto ProgramStart
And thats ya simple pic code to receive and send bytes back and forth. Now you know how to get your bytes in and out, you can use them just like any other variables.
The Second Folder it creates is dependent on what you are developing in, I play with Visual Basic so it created me a Folder called VisualBasic and inside here is sample code and the files you will need, I aslo copy the file mcHID.dll from C:\Program Files\Mecanique\EasyHID\ into this folder as well to play safe.
So again for the VB side of things to send data out to the Pic via the USB Port you simply load up the Bufferout(1-64) you always send Bufferout(0)=0 as a header.
So to send 4 bytes from Visual Basic just use the following:
BufferOut(0) = 0
BufferOut(1) = 68 'Ascii Value for D
BufferOut(2) = 65 'Ascii Value for A
BufferOut(3) = 84 'Ascii Value for T
BufferOut(4) = 65 'Ascii Value for A
hidWriteEx VendorID, ProductID, BufferOut(0)
To receive Data in VB, the sample code basically sits there and waits for a recieve event to happen and when it does, it jumps off to a routine called OnRead and populates the variables BufferIn(1-64).
So you could do a simple loop to keep checking the value of BufferIn(1) and BufferIn(2) until they receive the "OK\2 back.
To see it in action set up a object called Text1.Text on your VB Form and then in your code add the following:
Text1.Text = Chr(Val(BufferIn(1)))
Text1.Text = Text9.Text & Chr(Val(BufferIn(2)))
Hope this helps.
Regards Sean.
