RS232 Sniffing
+ Reply to Thread
Results 1 to 14 of 14
Thread: RS232 Sniffing
    Default RS232 Sniffing
    I'd like to monitor a PC program communicating with a serially connected device with a simple tool, so that I can see what PC is sending and what the device is replying to PC.
    I know I can do this with another RS232 and a couple of diodes and resistors but prefer to not use an extra serial port. A simple monitoring window is better.
    Anyone that knows such a tool please?
    Default Re: RS232 Sniffing
    this worked for me to monitor ports
    https://sourceforge.net/projects/realterm/
    Bombay, India
    You might want to consider this product. I have used a very early version of it and think it might be what you're looking for. https://www.hhdsoftware.com/serial-port-monitor
    Thank you both.
    The second seems a bit more complicated but more loaded with features.
    Bombay, India
    Hi Ioannis
    The serial port monitor software sits on top of your existing serial port driver on the same PC which communicates with the device. So, you can run your PC software with your device and intercept all the traffic passing to / from the device.
    Therefore, whatever traffic passes through the serial port on the PC, it can intercept and display.
    Yes, it is a great tool! Thanks,
    one thing you could do if you don't need data in real time is LOG the traffic to file, then read it. Hyperterm can log text and so can realterm I think. Some terminal programs may be able to add time-stamp to dats logged'
    Good idea. Especially if there is a way to disciminate the Tx from Rx data stream.
    this simple circuit worked with PIC serial TTL to USB for send/rcv to PC. Just used a second USB to serial converter and actually used a 1K ohm R, then can view both sending and receiving. Open another instance of hyper-term or other terminal program. You could add 3rd USB/serial device and open another terminal prog and see separate send rcv windows
Size:  10.8 KBName:  ht1.PNG
Size:  269.5 KBName:  ht2.PNG
    Thanks amgen.
    My preference is to use a software solution than to use an extra serial port.
    Aug 2011
    Try com0com (and some of its associated programs like hub4com). It lets you create virtual ports from a single com port.
    https://com0com.sourceforge.net/
    Nice project this com0com. Will use them in Com to TCP/IP.
    But for now I wanted to monitor a real device communicationg with the PC app.
    Aug 2011
    It should do that too.
    Hub4com let's you create multiple virtual ports, so you can pipe one real port out to multiple apps
    Thanks a lot for the suggestions and links.
  1. rs232
    By rondo2 in forum General
    Last Post: - 1st July 2009, 01:06
  2. RS232 to RS485
    Last Post: - 16th October 2008, 15:37
  3. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 13:33
  4. PC to PIC via RS232
    By Martin.... in forum mel PIC BASIC
    Last Post: - 15th September 2006, 10:44
  5. Baud sniffing
    By anj in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2005, 21:56
Members who have read this thread : 12
