HSEROUT using STR modifier - length parameter as variable not working
Results 1 to 15 of 15
Threaded View
    SWITZERLAND (french speaking)
    Default HSEROUT using STR modifier - length parameter as variable not working
    Hi there,
    I'm using HSEROUT with the STR modifier and I can't find the way to set the number of characters "\n" in a variable instead.
    While this works:
    HSEROUT [STR BalBuffer\40,26,13]
    ...this doesn't:
    BalCount VAR BYTE
    BalCount = 40
    HSEROUT [STR BalBuffer\BalCount,26,13]
    It is to mention that it does compile without error in both cases.
    I didn't try this one, but according to some other post (from Bruce in 2005), DEBUG/DEBUGIN seem to accept a variable for the charater value.
    Is this a limitation for the STR modifier (= it has to be a number) in HSEROUT or is there a way to make it work with a variable?
    Roger
  1. Determining variable length (number of digits) possible?
    Last Post: - 21st December 2020, 20:05
  2. Measuring a variable freq/length pulse and generating more pulses.
    Last Post: - 18th September 2014, 09:10
  3. hserout not working with parity
    Last Post: - 24th March 2010, 13:25
  4. HSERIN for variable length string
    Last Post: - 19th February 2010, 05:58
  5. Serin2 and STR Modifier
    By _Ian in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2005, 16:25
