Hello to all
Does anyone in this knowledge comunnity ever used an MP3 player like "FN-M16P Embedded MP3 Audio Module" and did successfully controlled the player with a (any) PIC MCU.
Thanks in advance
Vicente
Hello to all
Thanks in advance
Vicente
nomada
This is real interesting. It looks to be rather straight forward to operate.
EN82fn
I have used this http://geekmatic.in.ua/pdf/Catalex_MP3_board.pdf
ebay
https://www.ebay.co.uk/itm/Wemos-YX5...0AAOSwatda0Odb
TTL 3.3-5v
Made a speaking clock with it, also used some other similar modules but not tried yours.
Just found my youtube link to it
forget what account I had used !!
Are DFPlayer and FN-16 the same one?
Anyway, here are my snippets using the DFPlayer module:
The above are part of a bigger program but you get the idea of using volume and play/stop commands.Code:'Set volume hserout [$7e,$ff,$06,$06,$00,$00,$07,$fe,$ee,$ef] 'Volume 7/30 pause 500 'Play track 3 hserout [$7e,$ff,$06,$03,$00,$00,$03,$fe,$f5,$ef] 'Play 3rd track in folder 00. Dial tone ...... hserout [$7e,$ff,$06,$03,$00,$00,$02,$fe,$f6,$ef] 'Play error tone, 2nd track in folder 00 error: hserout [$7e,$ff,$06,$03,$00,$00,$01,$fe,$f7,$ef] 'Play message, 1rst track in folder 00 ...... start1: hserout [$7e,$ff,$06,$11,$00,$00,$00,$fe,$ea,$ef]' Stop playing .......
Hello to all
Ionnis you are right, soon after I started this thread, I have found that when I ordered the FN-M16P, the module I received is identified as DFPlayer Mini SKU DFR0299 or SKU 204222 depending on the supplier.
I've tried the module and it seems to work nice (for the price), the stereo hearphones out has a very good quality not so good is the 3W powered output (mono out).
If any of you plan to use this module do not use checksum and try each module to check if returns the power-on status, if not discard the module because it will never work good.
Thank you (obrigado!) to you all for your replies and contribution - Dave Purola - aerostar - Ioannis
Vicente
nomada
Is it possible to use it with software serial port, instead of hserout?
And how big is delay?
These modules also support WAV file playback, so my idea is to load a bunch of samples, say 32 different wav files, and create music keyboard
The module does not care if you use Serout or Hserout as long the command syntax is correct.
So, the answer is yes, you can use it just fine.
https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299
Anyone implemented "query number of files" function?
I want to add this to alarm clock, as alarm tone storage, so user should get number of files, to properly choose the desired tone.
I have it running with software serial port, but facing some issues.
Based on code above:
This works, however, it requires at least 500ms pause between each statements, or they're ignored.Code:serout portc.5,t9600, [$7e,$ff,$06,$06,$00,$00,$07,$fe,$ee,$ef] pause 500 serout portc.5,t9600, [$7e,$ff,$06,$03,$00,$00,$02,$fe,$f6,$ef]
Is this normal?
also, I have read the datasheet, but can't understand, which bit, based on which logic I should change in code above, to select another track, or change volume?
for example, in this code, posted above, which selects #3, #2, #1 songs in a folder, I can clearly see
Code:hserout [$7e,$ff,$06,$03,$00,$00,$03,$fe,$f5,$ef] hserout [$7e,$ff,$06,$03,$00,$00,$02,$fe,$f6,$ef] hserout [$7e,$ff,$06,$03,$00,$00,$01,$fe,$f7,$ef]
But why there are $F5, $F6, $F7 bytes also changing at the end of the code?
Looking at the data sheet page 6, in post #1.
Play a track 7E FF 06 14 00 10 FF FD D8 EF , without checksum 7E FF 06 14 00 10 FF EF 10 FF = folder 1 track 255, The upper nibble "1" specifies the folder. The lower 3 nibbles are the track number so F1 11 would be folder 15, track 273
Volume change the 1E byte from 0 to FF to set the valume
Specify volume 7E FF 06 06 00 00 1E FE D7 EF , without checksum 7E FF 06 06 00 00 1E EF Specified volume is level 30 =0X1E
Looking at the data sheet againBut why there are $F5, $F6, $F7 bytes also changing at the end of the code?
There are to two ways to send a command, one with checksum 10 bytes and the other without checksum 8 bytes.
Thanks, to which datasheet you refer to? My module is different, sorry for confusion. I'm using this: https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299
And how to play without any folder at all? i.e. all files are just on the SD card?
See the PDF file in the first post of this thread. It looks like the same module as you have. As far as folders for mp3, I have no knowledge. Maybe you can can use 0?
Thanks! I've sorted it out and using now without checksum and it works fine.
However, the issue with slow acceptance of statements persists...
