Hi all, I am using PIC 18F26K22 and INCLUDE "DT_INTS-18.bas"
I get error: Symbol not previously defined (INT_ENTRY_H)
Any clues?
Mike
Any clues?
Mike
any hints like :-Any clues?
pbp ver = ?
dt_ints ver= ?
interrupt your trying to create = ?
code ?
or do we have to guess ?
Terribly Sorry Richard, though it might be a fuse setting
PBP ver = 2.60A
DT_INTS ver = 3.3
So far I have just a debug statement and a high/ low/ pause on PORTB.2
I added the Include and it threw the error
if you don't create at least one valid interrupt no interrupt handler is created
hence
Symbol not previously defined (INT_ENTRY_H) error occurs
the dt_ints include has nothing to work with and just can't cope
I have had some issues with the different versions of PBP so I upgraded to Vs PBPX 3.1.0.4
This program compiles just fine but it does not enter the interrupt on RX
The exact same code runs in the 18F1320 except the OSCCON is $60 for the 18F1320 and $D2 for the 18F26K22.Code:INCLUDE "modedefs.bas" include "ALLDIGITAL.pbp" INCLUDE "C:\PBP\DT_INTS-18.bas" ; Base Interrupt System INCLUDE "C:\PBP\ReEnterPBP-18.bas" ; Include if using PBP interrupts Define PULSIN_MAX 1000 DEFINE HSER_RCSTA 90h 'Hser receive status init DEFINE HSER_TXSTA 24h 'Hser transmit status init DEFINE HSER_BAUD 9600 'Hser baud rate DEFINE HSER_SPBRG 25 DEFINE HSER_CLROERR 1 DEFINE OSC 4 OSCCON =$D2 'clock speed mem1 var byte ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RX1_INT, _read_serial, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE RX1_INT ; enable external (RX) interrupts MAIN: SEROUT2 PORTB.0 ,16468,["here",cr,cr] pause 500 GOTO MAIN read_serial: hserin 250 , NoRS232,[mem1,mem1] serout2 PORTB.0,16468,["got it",cr] Pause 1000 @ INT_RETURN NoRS232: serout2 PORTB.0,16468,["No rs232",cr] @ INT_RETURN
Does anyone know where I might be needing to look?
Mike
A few things I learned about the DT_INT routines is:
1 - You must have a copy of the DT_INT and ReEnterPBP code in the file where you save your current program. PBP3 will not search the computer and create a path. Thus, I have multiple copies of the code on my computer.
2 - It is helpful to open the DT_INT in PBP3 and look at how the "RX1_INT" is structured in the code, and where it is looking for PIE, PIR, etc. The K22 family is relatively new, and as you stated, OSCCON SFR is structured differently than for older chips. You may have to alter the DT_INT itself, or alter the way you INT_LIST your IntSource.
3 - At the top of the DT_INT (I believe for the PIC12F/16F) there are multiple wsave options that you have to comment out or uncomment, depending. I don't remember the -18 requiring that, but I may be wrong. On the lower chips, you must include one of the wsave options in your variable declarations of your main code (wsave VAR BYTE $20 SYSTEM for example).
I'd wager a guess the issue you're having is #1, your interrupt routines are not in the folder you're saving your current program.
mpgmike, I have been using DT_INTS-18 for quite a while with 18F26K22 parts as soon as Microchip released them. It's been a few years now. I have never had to change anything to do with Darrels code. What are you talking about?
EN82fn
FYI: You can specify a relative path. I have a separate folder for all my includes. It is located in the same root folder of all my projects:
Here my include folder is named _IncludeCode:C:\ ---Somewhere ---MyPBPProjects ---MyIncludes ---Project1 ---Project2 ---Project3
Code:INCLUDE "..\_Include\DT_INTS-18\DT_INTS-18.bas" ' Base Interrupt System INCLUDE "..\_Include\DT_INTS-18\ReEnterPBP-18.bas" ' Include if using PBP interrupts ... INCLUDE "..\_Include\DT_INTS-14_V110\DT_INTS-14.bas" ' Base Interrupt System INCLUDE "..\_Include\DT_INTS-14_V110\ReEnterPBP.bas" ' Include if using PBP interrupts ... INCLUDE "..\_Include\ESP8266_Base.pbp" INCLUDE "..\_Include\NMEA_base.pbp" 'etc
Michel, That is exactly the way I have been doing mine for years....
EN82fn
Dave, are you using DT_INTS for RX1/RX2 interrupts? If so, how?
Mike
Mike, Here are some snipits from a program I wrote about 4 years ago:
TX485 VAR PORTB.6 '0-OUTPUT COMMUNICATIONS PORT PIN RS-485
RX485 VAR PORTB.7 '1-INPUT COMMUNICATIONS PORT PIN RS-485
TX232 VAR PORTC.6 '0-OUTPUT COMMUNICATIONS PORT PIN RS-232
RX232 VAR PORTC.7 '1-INPUT COMMUNICATIONS PORT PIN RS-232
BAUD1 CON 416 'TX/RX BAUD RATE (64000000/4/38400) - 1 (HIGH BAUD/16 BIT)
BAUD2 CON 416 'TX/RX BAUD RATE (64000000/4/38400) - 1 (HIGH BAUD/16 BIT)
BAUDCON1 = %00001000 'SET FOR 16 BIT BAUDRATE
SCRATCH = BAUD1
SPBRG1 = SCRATCH.LOWBYTE 'SET LOW BYTE OF BAUD GENERATOR
SPBRGH1 = SCRATCH.HIGHBYTE 'SET HIGH BYTE OF BAUD GENERATOR
RCSTA1 = %10010000 'ENABLE RECEIVER,CONTINUOUS
TXSTA1 = %00100100 'ENABLE TRANSMIT,HIGH BAUD
BAUDCON2 = %00001000 'SET FOR 16 BIT BAUDRATE
SCRATCH = BAUD2
SPBRG2 = SCRATCH.LOWBYTE 'SET LOW BYTE OF BAUD GENERATOR
SPBRGH2 = SCRATCH.HIGHBYTE 'SET HIGH BYTE OF BAUD GENERATOR
RCSTA2 = %10010000 'ENABLE RECEIVER,CONTINUOUS
TXSTA2 = %00100100 'ENABLE TRANSMIT,HIGH BAUD
asm
INT_Handler TX1_INT, _UARTTX1, PBP, no
INT_Handler RX1_INT, _UARTRX1, PBP, no
INT_Handler TX2_INT, _UARTTX2, PBP, no
INT_Handler RX2_INT, _UARTRX2, PBP, no
INT_CREATE ; Creates the High Priority interrupt processor
@ INT_ENABLE RX1_INT ; Enable RX UART Interrupts
@ INT_ENABLE RX2_INT ; Enable RX UART Interrupts
GOTO MAINLOOP 'JUMP OVER INTERRUPTS
UARTRX1: 'INTERRUPT SERVICE ROUTINE FOR UART RECEIVER
@ INT_RETURN
UARTTX1: 'INTERRUPT SERVICE ROUTINE FOR UART TRANSMITTER
@ INT_RETURN
UARTRX2: 'INTERRUPT SERVICE ROUTINE FOR UART RECEIVER
@ INT_RETURN
UARTTX2: 'INTERRUPT SERVICE ROUTINE FOR UART TRANSMITTER
@ INT_RETURN
EN82fn
Thanks Dave, no matter what I try on the 18F26K22 it will not jump to the interrupt. I'm ordering some different chips with 2 UARTS to give them a try.
Mike
this works for me
Code:#CONFIG CONFIG FOSC = INTIO67 CONFIG PLLCFG = OFF CONFIG PRICLKEN = OFF CONFIG FCMEN = OFF CONFIG IESO = OFF CONFIG PWRTEN = OFF CONFIG BOREN = SBORDIS CONFIG BORV = 190 CONFIG WDTEN = ON CONFIG WDTPS = 32768 CONFIG CCP2MX = PORTC1 CONFIG PBADEN = OFF CONFIG CCP3MX = PORTB5 CONFIG HFOFST = ON CONFIG T3CMX = PORTC0 CONFIG P2BMX = PORTB5 CONFIG MCLRE = EXTMCLR CONFIG STVREN = ON CONFIG LVP = OFF CONFIG XINST = OFF CONFIG DEBUG = OFF CONFIG CP0 = OFF CONFIG CP1 = OFF CONFIG CP2 = OFF CONFIG CP3 = OFF CONFIG CPB = OFF CONFIG CPD = OFF CONFIG WRT0 = OFF CONFIG WRT1 = OFF CONFIG WRT2 = OFF CONFIG WRT3 = OFF CONFIG WRTC = OFF CONFIG WRTB = OFF CONFIG WRTD = OFF CONFIG EBTR0 = OFF CONFIG EBTR1 = OFF CONFIG EBTR2 = OFF CONFIG EBTR3 = OFF CONFIG EBTRB = OFF #ENDCONFIG ;INCLUDE "modedefs.bas" ;INCLUDE"ALLDIGITAL.pbp" ;INCLUDE "HomeAutomationVars.bas" 'Open with PBP editor INCLUDE "DT_INTS-18.bas" ; Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts define OSC 8 DEFINE DEBUG_REG PORTB DEFINE DEBUG_BIT 7 DEFINE DEBUG_BAUD 9600 ' Set Debug mode: 0 = true, 1 = inverted DEFINE DEBUG_MODE 0 x var word rxflag var bit rxchar var byte ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RX1_INT , _read_serial, PBP, no endm INT_CREATE ; Creates the interrupt processor ENDASM OSCCON = $60 ; OSC 8 anselc = 0 RCSTA = $90 ' Enable serial port & continuous receive TXSTA = $20 ' Enable transmit, BRGH = 0 SPBRG = 51 ' 9600 Baud @ 8MHz, 0.16% SPBRGH = 0 BAUDCON.3 = 1 ' Enable 16 bit baudrate generator baudcon1= baudcon1&%11001111 ;invert tx/rx polarity for usb-tty adapter TRISB.7 = 0 ;DEBUG LATB.7 = 1 ;DEBUG @ INT_ENABLE RX1_INT ; enable external (RX) interrupts debug "running",13,10 Main: debug "." for x = 1 to 1000 if rxflag then Debug 13,10,"got !! asc chr ",#rxchar,13,10 rxflag=0 endif pauseus 1000 next x Goto main read_serial: rxflag = 1 rxchar = rc1reg @ INT_RETURN
this is much better , get rid of all those nasty pauses and goto's
Code:;pic18f26k22 rx1 int demo #CONFIG CONFIG FOSC = INTIO67 CONFIG PLLCFG = OFF CONFIG PRICLKEN = OFF CONFIG FCMEN = OFF CONFIG IESO = OFF CONFIG PWRTEN = OFF CONFIG BOREN = SBORDIS CONFIG BORV = 190 CONFIG WDTEN = ON CONFIG WDTPS = 32768 CONFIG CCP2MX = PORTC1 CONFIG PBADEN = OFF CONFIG CCP3MX = PORTB5 CONFIG HFOFST = ON CONFIG T3CMX = PORTC0 CONFIG P2BMX = PORTB5 CONFIG MCLRE = EXTMCLR CONFIG STVREN = ON CONFIG LVP = OFF CONFIG XINST = OFF CONFIG DEBUG = OFF CONFIG CP0 = OFF CONFIG CP1 = OFF CONFIG CP2 = OFF CONFIG CP3 = OFF CONFIG CPB = OFF CONFIG CPD = OFF CONFIG WRT0 = OFF CONFIG WRT1 = OFF CONFIG WRT2 = OFF CONFIG WRT3 = OFF CONFIG WRTC = OFF CONFIG WRTB = OFF CONFIG WRTD = OFF CONFIG EBTR0 = OFF CONFIG EBTR1 = OFF CONFIG EBTR2 = OFF CONFIG EBTR3 = OFF CONFIG EBTRB = OFF #ENDCONFIG INCLUDE "DT_INTS-18.bas" ; define OSC 8 DEFINE DEBUG_REG PORTB DEFINE DEBUG_BIT 7 DEFINE DEBUG_BAUD 9600 DEFINE DEBUG_MODE 0 x var byte bank0 flag var byte bank0 rxflag var flag.7 dotflag var flag.0 rxchar var byte ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RX1_INT , _read_serial,asm,no INT_Handler TMR1_INT , _TOCK,asm,no endm INT_CREATE ; Creates the interrupt processor ENDASM clear OSCCON = $60 ; OSC 8 anselc = 0 RCSTA = $90 ' Enable serial port & continuous receive TXSTA = $20 ' Enable transmit, BRGH = 0 SPBRG = 51 ' 9600 Baud @ 8MHz, 0.16% SPBRGH = 0 BAUDCON.3 = 1 ' Enable 16 bit baudrate generator T1CON=1 ;32mS tick TRISB.7 = 0 ;DEBUG LATB.7 = 1 ;DEBUG baudcon1= baudcon1&%11001111 ;invert tx/rx polarity for usb-tty adapter pause 2000 ;give me time to setup debug @ INT_ENABLE RX1_INT ; enable external (RX) interrupts debug 13,10 ,"listening " @ INT_ENABLE TMR1_INT x=31 while 1 if rxflag then ;Debug 13,10,"got asc chr ",#rxchar,13,10 tx1reg = rxchar ;echo back rxflag = 0 endif if dotflag then debug "." dotflag=0 endif wend end read_serial: ASM bsf _flag ,7 MOVE?BB RC1REG,_rxchar INT_RETURN ENDASM TOCK: asm DECFSZ _x,F BRA BREXIT movlw 31 bsf _flag ,0 movwf _x BREXIT BCF PIR1 ,0 INT_RETURN ENDASM
Bingo!
Thanks Richard, this linedid it!Code:anselc = 0 '0 = Digital input buffer enabled
Mike
