16F1786 issue with simple program.
Results 1 to 6 of 6
    Jan 2010
    Default 16F1786 issue with simple program.
    I try to compile this with PicBasic 3.0.7:
    'PIC16F1786
        __config _MCLRE_OFF
    for PIC16F176 but I got an error:
    [ASM ERROR] CODE_1.ASM (33) : Argument out of range (not a valid register address)
    If I compile for PIC16F690 or other, the error doesn't occur.
    I have no idea what happened.
    Default Re: 16F1786 issue with simple program.
    The 16F1786 has more than one config register while the 16F690 (and probably the "others" you've tried) doesn't.
        __config _CONFIG1, _MCLRE_OFF
    Just remember that when you include a #CONFIG/#ENDCONFIG as above it replaces ALL of the PBP default ones, reverts to the devices specific HARDWARE defaults and THEN sets the bits you include in your block. I usually copy the default PBP ones and the changed/add what I need.
    For the 16F1786 the PBP defaults are:
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON &  _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF
            __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _VCAPEN_OFF
    Jan 2014
    Try this:
             __MCLRE_OFF
    Oct 2009
    Utah, USA
    Here is one way to handle configs for multiple processsors...
        #IF __PROCESSOR__ = "16F1828"
            __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
            __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_25 & _LVP_OFF
            #endconfig
        #ELSE
            #IF __PROCESSOR__ = "16F690"
                __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
                #endconfig
            #ELSE
                #ERROR "Program does not support " + __PROCESSOR__
            #ENDIF
        #ENDIF
        #msg "compiling for target " + __PROCESSOR__
    it dosen't paste in a code window very well (due to line wrap) but you should get the idea.
    try and copy/paste it into your IDE
    Dwight
    Jan 2010
    Thank you very much HenrikOlsson and Heckler.
    I can compile now my PIC16F1786. Because you provide me a lot of information about this micro, I decided to read (finally) some information provided in PicBasic\DEVICE folder.
    Thank you again.
    Jan 2010
    I figure a HelloWorld program and works fine in Proteus Simulator.
    But I stuck when I try to read AN0 analog port.
    The PicBasic ADCIN 0, something return "0".
    No better luck when I try to explicitly read AN0, like bellow:
    'PIC16F1786
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON &  _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF
        include "MODEDEFS.BAS"
        DEFINE OSC 8
        OSCCON.6 = 1
        OSCCON.5 = 1
        OSCCON.4 = 1
        OSCCON.3 = 0
        OSCCON.1 = 1
        TRISA = %00001001    'AN0 is Analog
        TRISB = %11000000
        TRISC = %00000000
        ANSELA = %00001001 'digital; AN0 is analog
        ANSELB = %00001001
        'Configure VREF:
    '    ADCON1.1 = 0
    '    ADCON1.0 = 1 'VREF+ is connected to VREF+ pin
        ADCON1.1 = 0
        ADCON1.0 = 0 'VREF+ is connected to VDD
        ADCON1.2 = 0 ' VREF- is connected to VSS
        'ADC result
        ADCON0.7 = 1 ' 10 bits result
        ADCON0.0 = 1 ' ADC is enabled
        ADCON1.6 = 1 'FOSC/64
        ADCON1.5 = 1
        ADCON1.4 = 0
        CM1CON0.7 = 0'comparator is disabled
        CM2CON0.7 = 0'comparator is disabled
        DACCON0.7 = 0 'DAC is disabled
        'disable intrerupt:
        INTCON = 0'intrerupt is disabled
        DEFINE ADC_BITS 10       ' Set number of bits in result
        DEFINE ADC_CLOCK 3     ' Set clock source (rc = 3)
    '-[The connection between the LCD display and the microcontroller is as follows:]-
        ' Define LCD pins
        DEFINE LCD_DREG PORTC 'LCD data port
        DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
        DEFINE LCD_RSREG PORTA 'LCD register select port
        DEFINE LCD_RSBIT 2 'LCD register select bit       - pinul RS
        DEFINE LCD_EREG PORTA 'LCD enable port
        DEFINE LCD_EBIT 7 'LCD enable bit                 - pinul E
    '    DEFINE LCD_RWREG PORTC 'LCD read/write port
    '    DEFINE LCD_RWBIT 6 'LCD read/write bit
        DEFINE LCD_BITS 4 'LCD bus size 4 or 8
        DEFINE LCD_LINES 2 'Number lines on LCD
        DEFINE LCD_COMMANDUS 2000 'Command delay time in us
        DEFINE LCD_DATAUS 50 'Data delay time in us
    ;-----[Variables]----------------------------------------------------
        Thermocouple  var word
        adval	      var	word
    ;----[Initialization]-----------------------------------------------------------
    '---[Hello World]---------------------------------------------------------------
    Afisaj:
        LCDOUT $FE,1 ' Clear LCD
        LCDOUT $FE,2 ' Home cursor
        'Display initial screen
        lcdout $FE,2,"PIC16F1786",$fe, $C0,"Luxornet@2016"
    ;----[Main program loop]--------------------------------------------------------
        'ADCIN 0, Thermocouple
    '  	ADCON0 = %10000001	' Configure and turn on A/D Module
      	ADCON0.7 = 1 '10 bits result
    	pause 10
        ADCON0.2 = 0	' use channel 0
        ADCON0.3 = 0
        ADCON0.4 = 0
        ADCON0.5 = 0
        ADCON0.6 = 0
        ADCON0.0 = 1 'ADC is enabled
        ADCON0.1 = 1    ' Start Conversion   'Bit GO/DONE
    Voltmeter1:
        Pause 100
    	If ADCON0.1 = 1 Then Voltmeter1	' Wait for low on bit-1 of ADCON0, conversion finished
    	adval.highbyte = ADRESH	' Move HIGH byte of result to adval
    	adval.lowbyte = ADRESL	' Move LOW byte of result to adval
        lcdout $FE,2,"Thermocouple: ",dec adval,"   "
    GOTO Main
  1. 18F4550 issue with simple program.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 20th January 2016, 11:48
  2. Program Configuration check mark issue... maybe.
    By Szczepaniec in forum mel PIC BASIC Pro
    Last Post: - 8th November 2012, 18:17
  3. Simple LED driving issue - setup?
    By George in forum mel PIC BASIC Pro
    Last Post: - 28th March 2011, 01:54
  4. Code issue with a flashing light(simple question)
    By IAmTheAnswer in forum mel PIC BASIC Pro
    Last Post: - 8th May 2010, 11:46
  5. Help with simple program
    By mykewl in forum mel PIC BASIC Pro
    Last Post: - 31st July 2008, 08:58
