New version of Darrel Taylor's Elapsed include for 64MHz:
'* Name : Elapsed_INT-18.bas *
'* Author : Darrel Taylor *
'* Date : JUL 11, 2006 : 7/11/2010 : Dec 23, 2014 *
'* Version : 1.3 *
'* Notes : Must have DT_INTS-18.bas loaded first *
'* ver 1.2: Now works at any OSC frequency without using the prescaler *
'* ver 1.3: will work with 64MHz thanks to Sheldon *
'* New field ONEHUNDRETH is now used instead of TICKS *
DISABLE DEBUG
; syntax = Handler IntSource, Label, Type, ResetFlag?
DEFINE Elapsed_Handler TMR1_INT, _ClockCount, asm, yes
; the above define can be used in the INT_LIST macro, if desired (optional)
Ticks VAR BYTE ; Counts timer Overflows
OneHundreth VAR BYTE ; New field for 64MHz
;T1Post VAR BYTE ; Timer1 postscaler
Seconds VAR BYTE
Minutes VAR BYTE
Hours VAR BYTE
Days VAR WORD
OneHundrethChanged VAR BIT ; New field for 64MHz
SecondsChanged VAR BIT ; idicates that the value has changed
MinutesChanged VAR BIT
HoursChanged VAR BIT
DaysChanged VAR BIT
GOSUB ResetTime ; initialize the Elapsed Timer
Goto OverElapsed ; skip over the routines
' -------------- calc timer reload Constants -------------------------------
T1PS = 1 ; start with 1:1 postscaler
TimerConst = ((OSC*1000000)/4/100) ; how many timer ticks will it take
while TimerConst > 65400 ; if it's more than the timer can count
T1PS = T1PS * 2 ; double the postscaler
TimerConst = TimerConst / 2 ; halve the count
endw
TimerConst = 65536 - TimerConst + 8 ; final reload value
; ----------------- ADD TimerConst to TMR1H:TMR1L -------------------------
ADD2_TIMER macro
BCF T1CON,TMR1ON, 0 ; 1 Turn off timer
MOVLW LOW(TimerConst) ; 1
ADDWF TMR1L,F, 0 ; 1
BTFSC STATUS,C ; 1/2
INCF TMR1H,F, 0 ; 1
MOVLW HIGH(TimerConst) ; 1
ADDWF TMR1H,F, 0 ; 1
; ----------------- ADD TimerConst to TMR1H:TMR1L and restart TIMER1 ------
RELOAD_TIMER macro
ADD2_TIMER
BSF T1CON,TMR1ON, 0 ; 1 Turn TIMER1 back on (8 cycles)
; ----------------- Load TimerConst into TMR1H:TMR1L ----------------------
LOAD_TIMER macro
MOVE?CT 0, T1CON,TMR1ON
MOVE?CB 0, TMR1L
MOVE?CB 0, TMR1H
ADD2_TIMER
' ------[ This is the Interrupt Handler ]-----------------------------------
T1PS CON EXT
ClockCount:
@ RELOAD_TIMER ; Reload TIMER1
Ticks = Ticks + 1 ; each tick is 2.5ms
' IF LATD.3 = 0 THEN ' used to debug to confirm 2.5ms
' LATD.3 = 1
' ELSE
' LATD.3 = 0
' ENDIF
if ticks // T1PS = 0 THEN ' if modulas of tips (4) = 0
' IF LATD.3 = 0 THEN ' used to debug to confirm 10ms
' LATD.3 = 1
' ELSE
' LATD.3 = 0
' ENDIF
OneHundreth = OneHundreth + 1 ; each 1/100th is 10ms
OneHundrethChanged = 1
IF OneHundreth = 100 THEN
OneHundreth = 0
' Ticks = Ticks + 1
' IF Ticks = 100 THEN
' Ticks = 0
' T1Post = T1Post + 1
' IF T1Post = T1PS THEN
' T1Post = 0
Seconds = Seconds + 1
SecondsChanged = 1
IF Seconds = 60 THEN
Seconds = 0
Minutes = Minutes + 1
MinutesChanged = 1
IF Minutes = 60 THEN
Minutes = 0
Hours = Hours + 1
HoursChanged = 1
IF Hours = 24 THEN
Days = Days + 1
DaysChanged = 1
Hours = 0
@ INT_RETURN ; Restore context and return from interrupt
'-----====[ END OF TMR1 Interrupt Handler ]====-----------------------------
StartTimer:
T1CON = 1 ; 1:1, FOSC4, TMR1ON
StopTimer:
T1CON.0 = 0 ; Turn OFF Timer1
BitSave VAR BIT
ResetTime:
BitSave = T1CON.0 ; Save TMR1ON bit
@ LOAD_TIMER ; Load TimerConst
T1CON.0 = BitSave ; Restore TMR1ON bit
; T1Post = 0 ; clear the postscaler
Ticks = 0
OneHundreth = 0
Seconds = 0
Minutes = 0
Hours = 0
Days = 0
SecondsChanged = 1 ; indicate everything has changed
MinutesChanged = 1 ; so that 00:00:00 is processed
HoursChanged = 1
DaysChanged = 1
OverElapsed:
ENABLE DEBUG
New field OneHundreth (10ms) replaces Tick (2.5ms at 64MHz).
![Name: Saleae 64MHz new.PNG
Size: 22.4 KB](https://www.picbasic.co.uk/forum/attachment.php?s=d0de14a881ef5f583358bd63afee0ebe&attachmentid=7543&d=1419312636)
(Remove .TXT suffix)
Elapsed_INT-18_64MHz.bas.txt
