HELLO, I HAVE THE SAME PROBLEM YOU HAD SOLVED. PLEASE HELP ME TO COMPILE THIS CODE.
@ DEVICE pic16F876
@ DEVICE pic16F876, WDT_OFF
@ DEVICE pic16F876, PWRT_On
@ DEVICE pic16F876, PROTECT_OFF
TRISA=%11111111
TRISB=%00000000
TRISC=%00000000
PORTA=0
PORTB=0
PORTC=0
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 2
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 3
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE CCP1_REG PORTC
DEFINE CCP1_BIT 2
ON INTERRUPT GoTo KESME
ADCON1 = 7
OPTION_REG=%10000010
INTCON=%10100001
TMR0=0
T2CON = %00000110
PR2=124
SYMBOL YUKARI=PORTA.0
SYMBOL ASAGI=PORTA.1
SYMBOL ARTTIR=PORTA.2
SYMBOL AZALT=PORTA.3
SYMBOL JOG=PORTA.4
SYMBOL DUR=PORTA.5
ROLE VAR PORTC.3
LED1 VAR PORTC.1
LED2 VAR PORTC.0
MODS VAR BIT
YON VAR BIT
U VAR BYTE
W VAR BYTE
ADR VAR BYTE
SAYIH VAR BYTE
SAYIL VAR BYTE
SON VAR BYTE
SYC VAR BYTE
SNY VAR BYTE
SAYAC VAR BYTE
DUTY VAR BYTE
I VAR WORD
PERYOT VAR WORD
HAM_DUTY VAR WORD
FREKANS VAR WORD
PAUSE 200
LCDOUT $FE,1
GIRIS:
LCDOUT $FE,$83,"INVERTER"
LCDOUT $FE,$C4,"WITH PWM"
PAUSE 1500
LCDOUT $FE,1
DUTY=0:LED1=0:LED2=1
GOSUB FREKANS_HESAP
GOSUB EKRAN
GOSUB DUTY_YAZ
GOSUB PWM_ON
BASLA:
IF DUTY>0 THEN
IF JOG=0 AND YON=0 THEN
YON=1
SON=DUTY
GOTO SAG
IF JOG=0 AND YON=1 THEN
YON=0
SON=DUTY
GOTO SOL
IF DUR=0 and duty>0 THEN
GOTO DURDUR
GOSUB FREKANS_HESAP
GOSUB DUTY_KONTROL
GOSUB FREKANS_KONTROL
GOTO BASLA
FREKANS_KONTROL:
IF ARTTIR=0 THEN
WHILE ARTTIR=0:WEND
PR2=PR2-1
gosub DUTY_YAZ
IF PR2<5 THEN PR2=5
IF AZALT=0 THEN
WHILE AZALT=0:WEND
PR2=PR2+1
gosub DUTY_YAZ
IF PR2>124 THEN PR2=124
GOSUB EKRAN
DUTY_KONTROL:
IF YUKARI=0 THEN
sayac=0
DUTY=DUTY+1
IF DUTY=101 THEN DUTY=100
gosub DUTY_YAZ:GOSUB EKRAN
WHILE YUKARI=0
W=1
IF SAYAC=>50 THEN
W=0:SAYAC=50
DUTY=DUTY+1:GOSUB DELAY
GOSUB DUTY_YAZ
GOSUB EKRAN
WEND
W=0:SAYAC=0
W=0:SAYAC=0
IF ASAGI=0 THEN
sayac=0
DUTY=DUTY-1
IF DUTY=255 THEN DUTY=0
GOSUB DUTY_YAZ
GOSUB EKRAN
WHILE ASAGI=0
W=1
IF SAYAC=>30 THEN
W=0:SAYAC=30
DUTY=DUTY-1:GOSUB DELAY
GOSUB DUTY_YAZ
GOSUB EKRAN
WEND
W=0
W=0:SAYAC=0
SAG:
IF DUTY>100 THEN
ROLE=1:LED1=1:LED2=0
GOTO DUTY_ARTTIR
GOSUB DUTY_YAZ:GOSUB EKRAN
GOTO SAG
DUTY_ARTTIR:
IF DUTY=SON THEN
GOTO BASLA
GOTO DUTY_ARTTIR
DURDUR:
IF DUTY=0 THEN
GOTO BASLA
GOTO DURDUR
SOL:
IF DUTY>100 THEN
ROLE=0:LED1=0:LED2=1
GOTO DUTY_ARTTIR
GOTO SOL
DELAY: 'gecıkme
FOR I=0 TO 255:NEXT
DELAY1:
FOR I=0 TO 150:NEXT
FREKANS_HESAP:
FREKANS=62500/(PR2+1)
DUTY_YAZ:
HAM_DUTY=(PR2+1)*DUTY/25
CCP1CON.4=ham_DUTY.0
CCP1CON.5=HAM_DUTY.1
CCPR1L=HAM_DUTY>>2
PWM_ON:
CCP1CON.2=1
CCP1CON.3=1
PWM_OFF:
CCP1CON.2=0
CCP1CON.3=0
EKRAN:
LCDOUT $FE,$80,"Duty %",#DUTY
IF DUTY<100 THEN
GOSUB HANE_AL1
LCDOUT $FE,ADR,$20
lcdout $fe,$C0,"FREKANS=",#FREKANS
GOSUB HANE_AL2
HANE_AL1:
IF DUTY<100 OR DUTY>9 THEN ADR=$88
IF DUTY<10 THEN ADR=$87
HANE_AL2:
IF FREKANS>10000 THEN LCDOUT $FE,$CD,"Hz"
IF FREKANS<10000 AND FREKANS>999 THEN LCDOUT $FE,$CC,"Hz "
IF FREKANS<1000 THEN LCDOUT $FE,$CB,"Hz "
DISABLE
KESME:
IF W=1 THEN
SAYAC=SAYAC+1
IF SAYAC=101 THEN SAYAC=0
INTCON.2=0
RESUME
ENABLE
