I didn't want to make a similar topic so therefore I'm including my findings here. I'm using 16F876A and also A.4 is causing some minor problems.
Code part "Test" is working OK, so PortA.1-5 and PortB.1-5 switching on and off.
Problem occurs with "Test2" on A.4. A.4 is always LOW, meaning that corresponding LED is always ON (other 9 LED's are OK).
I have pull-up for A.4 (open drain) so, it should goes up as soon as it is set high, as it does with "Test" code.
Any idea whats is wrong or how to fix it? At the moment I don't want to change make HW changes so SW is prefered ![Wink](images/smilies/wink.gif)
Mainloop:
GOSUB Test
GOSUB Test2
GOTO Mainloop
Test:
PortA = %00000000
PortB = %00000000
PAUSE 500
PortA = %00111110
PortB = %00111110
PAUSE 500
Test2:
LED = %11111111111
GOSUB Select_LED
PAUSE 500
LED = %00000000000
GOSUB Select_LED
PAUSE 500
Select_LED:
LED = ~LED 'Invert for P-FET supply for LEDs
PortB.1 = LED.4 'LED4
PortB.2 = LED.6 'LED6
PortB.3 = LED.8 'LED8
PortB.4 = LED.10 'LED10
PortB.5 = LED.2 'LED2
PortA.5 = LED.5 'LED5
PortA.4 = LED.7 'LED7 !!!!!!!!Open drain
PortA.3 = LED.9 'LED9
PortA.2 = LED.1 'LED1
PortA.1 = LED.3 'LED3
BR,
-Gusse-
