A little Quiz game (Two players + audience) with PIC12F675
Results 1 to 9 of 9
    Aug 2011
    Guadalajara, México
    Default A little Quiz game (Two players + audience) with PIC12F675
    This is a little Quiz game requested by my little son to use in his classroom, there are 4 pushbuttons, one for each player ("Red Player" and "Blue Player") and the other two ("Correct" and "Incorrect" answer) are for the teacher. You can use a RGB LED (Red player, Blue player an Green audience) or three separate LEDs.
    The interesting part of this little and silly project is the use of an analog input to check the status of two pushbuttons.
    The schematic is included in the source code you can add a 9v bat. with a 7805 regulator and an on-off switch.
    Enjoy.
    '*  Name    : MaraTron+12F675                                   *
    '*  Author  : Ivan Rosales, Guadalajara México                  *
    '*  Notice  : Copyright (c) 2011 Ivan Rosales                   *
    '*  Date    : 27/08/2011                                        *
    '*  Notes   : Quiz Game (Two Players + Audience)                *
    '*             Vdd
    '*             | |		             PIC12F675
    '*             | |1K                    ___      Red
    '*             '-'                   -o|°  |o-   LED   Green
    '*              |            .--------o|   |o---->|-.   LED    Blue
    '*         .----o----o-------)--------o|   |o-------)--->|-.   LED
    '*         |         |       |      .-o|___|o-------)------)--->|-.
    '*       | o       | o       |      |               |      |      |
    '*       | o       | o   Red |  Blue|               |      |      |
    '* Correct |Incorrect|       |      |               |      |      |
    '*         |         |     | o    | o               |      |      |
    '*         |        | |1K    |      |               |      |      |
    '*         '----o----o-------o------o---------------o------o------'
    '*             GND
    @ Device PIC12F675,WDT_ON,PWRT_ON,PROTECT_OFF,MCLR_OFF,BOD_OFF
    ansel=%00111000     'Use GP4/AN3 (Pin 3) as analog input
    adcon0 = %00001101
    cmcon=7             'Don't use analog comparator
    trisio=%111000      '
    option_reg=0        'Enable Pull-Ups
    wpu=$FF             'Config Pull-Ups (GP3 DOESN'T have Pull-Up)
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    'Definitions
    Rojo         VAR GPIO.0
    Verde        var GPIO.1
    Azul         var GPIO.2
    Bot1         var GPIO.3
    Bot2         var GPIO.5
    Todos        var bit
    Cont         var byte
    Tiempo       var byte
    SiNo         var word
    gpio=0    'Turn off LEDs
    todos=0
    Pral:
    gosub do_adc   'Get ADC reading
    if !bot1 and !rojo and !Azul then     'If "Red" player is the fastest
    high Rojo
    gosub do_shuffle
    if !bot2 and !Rojo and !azul then     'If "Blue" player is the fastest
    high Azul
    gosub do_shuffle
    if sino=0 then                        'If the "Answer" is correct
    gpio=0
    todos=0
    if sino=1 and !todos and (rojo or azul)then    'If the "Answer" is incorrect (First player fails)
    toggle azul
    toggle rojo
    repeat
    gosub do_adc
    until sino=3
    todos=1
    if sino=1 and todos and (rojo or azul)then    'If the "Answer" is incorrect (Both players fails)
    low azul
    low rojo
    high verde                                    'Turn On Green (It's the audience turn's)
    repeat
    gosub do_adc
    until sino=3
    todos=0
    if sino=1 and verde then    'If the "Answer" is incorrect (Both players and audience fails)
    gpio=0
    repeat
    gosub do_adc
    until sino=3
    todos=0
    goto pral
    Do_ADC:
    PAUSEUS 50           ' Wait for A/D channel acquisition time
    ADCON0.1 = 1         ' Start conversion
    WHILE ADCON0.1       ' Wait for it to complete
    WEND
    sino = ADRESH>>6
    Do_Shuffle:          'Just a little dramatic effect ;)
    tiempo=50
    for cont = 1 to 32
    toggle rojo
    toggle azul
    pause tiempo
    tiempo=tiempo+5
    next cont
    Aug 2011
    Guadalajara, México
    Default Re: A little Quiz game (Two players + audience) with PIC12F675
    Ops!, there is a 1k pullup resistor missing in the schematic, so please add this to the pin 4...
    Errare humanum est
    Apr 2003
    Cambridge - UK
    Great, your code exaple is in the User Projects section, here. Thank you for taking time to post this project. We appreciate you taking time to post this.
    oldisgold's Avatar
    oldisgold Guest
    i wud like to extend it to more players [say, 4 players]. can u help me by showing how to extend ?
    Good stuff, like Lester said good code EXAPLE
    Apr 2003
    Cambridge - UK
    olisgold..
    Please, at least try. Ivan has made a great example, try to read it understand it, ask questions about the code flow and try modification yourself.
    Its really unreasonable to ask Ivan to do the work for you....and you learn nothing by that process.
    Aug 2011
    Guadalajara, México
    Dear olisgold, you can count on me if you get stuck, but I would like to see at least one try, because as lester said, it's the best way to learn.
    As a little tip, you can expand the game with diferent approaches, one could be with charlieplexed LEDs (controling them with 3 pins) and then use the 3 remaining pins for the buttons (as in the example, using them as analog inputs to read 2 buttons per pin)
    Regards.
    My English doesn't sucks, it's just fugly...
    Aug 2011
    Guadalajara, México
    mister_e, I think lester is referring to Steve Jobs (Ex-Apple)
    Rofl! Win!
