Define OSC 20 ' 20 MHz oscillator
' Alias PIC pins and registers for SD/MMC card
SD_WE Var PORTA.4 ' SD card write protect
SD_WE_TRIS Var TRISA.4 ' SD card write protect direction
SDI Var PORTB.0 ' SPI data in
SDI_TRIS Var TRISB.0 ' SPI data in direction
SCL Var PORTB.1 ' SPI clock
SCL_TRIS Var TRISB.1 ' SPI clock direction
SD_CS Var PORTB.3 ' SD card chip select
SD_CS_TRIS Var TRISB.3 ' SD card chip select direction
SD_CD Var PORTB.4 ' SD card detect
SD_CD_TRIS Var TRISB.4 ' SD card detect direction
SDO Var PORTC.7 ' SPI data out
SDO_TRIS Var TRISC.7 ' SPI data out direction
' Include the SD/MMC subroutines (found in http://melabs.com/resources/samples/pbp/sdfs3.zip)
Include "SDFS.PBP"
SDC_UseHardSPI = TRUE ' Use hardware SSP port for SPI.
ADCON1 = 15 ' All I/O pins digital
Pause 100
' FSInit initializes the card and reads all the preliminary information from it
Gosub FSInit
Serout2 PORTC.6, 84, ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a]
If (FAT_error != 0) Then Stop
' Display card directory
Gosub FINDfirst ' Find first file on card
While (FAT_error = 0)
Serout2 PORTC.6, 84, [Str FAT_FileName\11, $d, $a]
Gosub FINDnext ' Find next file on card
Wend
' This section defines a specific short (8.3) filename
' Note that spaces are use in empty elements and must be upper case for Windows
FAT_FileName[0] = "T"
FAT_FileName[1] = "E"
FAT_FileName[2] = "S"
FAT_FileName[3] = "T"
FAT_FileName[4] = "1"
FAT_FileName[5] = " "
FAT_FileName[6] = " "
FAT_FileName[7] = " "
FAT_FileName[8] = "T"
FAT_FileName[9] = "X"
FAT_FileName[10] = "T"
' Set file time to 8:30:10 and date to 1/1/2008
FAT_seconds = 5
FAT_minutes = 30
FAT_hours = 8
FAT_day = 1
FAT_month = 1
FAT_year = 28
' Open a file for write
FAT_mode = "w" ' Write mode
Gosub FSfopen ' Open file pointed to by Byte array FAT_FileName
Serout2 PORTC.6, 84, ["Open for write: ", Dec FAT_error, $d, $a]
' Write to file
FAT_src[0] = "A"
FAT_src[1] = "B"
FAT_src[2] = "C"
FAT_count = 3
Gosub FSfwrite
Serout2 PORTC.6, 84, [ "Write ", Dec FAT_error, $d, $a]
' Close file
Gosub FSfclose
Serout2 PORTC.6, 84, [ "Close ", Dec FAT_error, $d, $a]
' Open a file for read
FAT_mode = "r" ' Read mode
Serout2 PORTC.6, 84, ["Open: ", Dec FAT_error, $d, $a]
' Read and display the whole file
FAT_count = 1 ' Read 1 byte to buffer at a time
Gosub FSfread
Serout2 PORTC.6, 84, [FAT_dest[0]]
Gosub FSfread
Wend
Serout2 PORTC.6, 84, [ "Read: ", Dec FAT_error, $d, $a]
' Delete a file
' Gosub FSremove ' Delete file pointed to by Byte array FAT_FileName
' Serout2 PORTC.6, 84, ["Remove: ", Dec FAT_error, $d, $a]
' If (FAT_error != 0) Then Stop
' Rename a file
' FAT_FileName2 is new name
' FAT_FileName2[0] = "T"
' FAT_FileName2[1] = "E"
' FAT_FileName2[2] = "S"
' FAT_FileName2[3] = "T"
' FAT_FileName2[4] = "2"
' FAT_FileName2[5] = " "
' FAT_FileName2[6] = " "
' FAT_FileName2[7] = " "
' FAT_FileName2[8] = "T"
' FAT_FileName2[9] = "X"
' FAT_FileName2[10] = "T"
' Gosub FSrename ' Rename file pointed to by Byte array FAT_FileName
' Serout2 PORTC.6, 84, ["Rename: ", Dec FAT_error, $d, $a]
