Delayed output 10 secs
Results 1 to 38 of 38
    May 2009
    Montreal, QC, Canada
    Default Delayed output 10 secs
    I am relatively new at this and I need a little help.
    I am using a 16F883
    Portb with pull ups as input, portc as instantaneous output and porta as delayed output.
    When I press switch 1 (low), it will toggle portc.1 (on)
    if I maintain switch 1 (low) for 3 seconds it will branch to another section.
    if I press switch 1 again it will toggle portc.1 (off)
    So far so good, my program is working fine but I want to add porta.1 which will trigger approx 10 seconds after portc.1
    Keeping in mind that the explaination above is for 1 switch / 1 output portc / 1 output porta but it will endup having 6 of each.
    Here is my code:
    start:
        if sw1 = 0 then Bdelay1
    goto start
    Bdelay1:
        pause 25                                  ; debounce
        if sw1 = 0 then
            if ld1 = 0 or swstat = 1 then
                high ld1
                swstat = 1
                l=l+1
                if l => 5 then Bprog1
                goto bdelay1
                 low ld1
    wait1:     if sw1 = 0 then wait1
        swstat = 0
        goto start
    Thank you
    Mike
    May 2009
    Well I guess this must be a tough one as no one commented or maybe I didn't explain clearly my issue.
    I have been doing lots of browsing and searching and I figured what I might need is to use a timer with interup but I am confused. If I have 6 switches on (portb) 6 Leds on (portc) each switch trigering its respective led and then again a respective led on porta will be triggered 10 seconds later.
    Sinse there is a chance that a user press switch1, switch2, switch3 and switch4 and even possibly all 6 of them (all within 10 seconds)
    If I could have 6 timers and 6 interupt routines I would manage easily but how can I control my 6 events with just one timer?
    If anyone can help me out, I don't bite!
    Mike
    Quote Originally Posted by lilimike View Post
    I think it's just one of those, "you can't get there from here" kind of things.
    Trying to time things with pauses makes it so you can't do anything else at the same time, so 6 buttons would be difficult with the example given.
    However, if you do it a little differently, it's a piece of cake.
    Using a timer to measure even 1ms time periods, and running the main loop freely (without pauses), you can do it like this...
    <font color="#008000"><b>CLEAR
    DEFINE </b></font><b>OSC </b><font color="#800000"><b>20
    </b></font><font color="#008000"><b>INCLUDE </b></font><font color="#FF0000">&quot;AllDigital.pbp&quot;         </font><font color="#0000FF"><b><i>; Disable Analog functions
    </i></b></font><b>SW1   </b><font color="#008000"><b>VAR </b></font><b>PORTB</b>.<font color="#800000"><b>0
    </b></font><b>SW2   </b><font color="#008000"><b>VAR </b></font><b>PORTB</b>.<font color="#800000"><b>1
    </b></font><b>SW3   </b><font color="#008000"><b>VAR </b></font><b>PORTB</b>.<font color="#800000"><b>2
    </b></font><b>SW4   </b><font color="#008000"><b>VAR </b></font><b>PORTB</b>.<font color="#800000"><b>3
    </b></font><b>SW5   </b><font color="#008000"><b>VAR </b></font><b>PORTB</b>.<font color="#800000"><b>4
    </b></font><b>SW6   </b><font color="#008000"><b>VAR </b></font><b>PORTB</b>.<font color="#800000"><b>5
    </b></font><b>LED1  </b><font color="#008000"><b>VAR </b></font><b>PORTC</b>.<font color="#800000"><b>0
    </b></font><b>LED2  </b><font color="#008000"><b>VAR </b></font><b>PORTC</b>.<font color="#800000"><b>1
    </b></font><b>LED3  </b><font color="#008000"><b>VAR </b></font><b>PORTC</b>.<font color="#800000"><b>2
    </b></font><b>LED4  </b><font color="#008000"><b>VAR </b></font><b>PORTC</b>.<font color="#800000"><b>3
    </b></font><b>LED5  </b><font color="#008000"><b>VAR </b></font><b>PORTC</b>.<font color="#800000"><b>4
    </b></font><b>LED6  </b><font color="#008000"><b>VAR </b></font><b>PORTC</b>.<font color="#800000"><b>5
    </b></font><b>Counters   </b><font color="#008000"><b>VAR WORD</b></font>[<font color="#800000"><b>6</b></font>]           <font color="#0000FF"><b><i>; 6 words, for 6 buttons
    </i></b></font><b>DelayTime  </b><font color="#008000"><b>CON </b></font><font color="#800000"><b>10000             </b></font><font color="#0000FF"><b><i>; 10 seconds
    </i></b></font><b>T0IF       </b><font color="#008000"><b>VAR </b></font><b>INTCON</b>.<font color="#800000"><b>2          </b></font><font color="#0000FF"><b><i>; TMR0 overflow flag
    </i></b></font><b>X          </b><font color="#008000"><b>VAR BYTE
    </b></font><b>OPTION_REG </b>= <font color="#800000"><b>%01010100           </b></font><font color="#0000FF"><b><i>; WPU on, TMR0 1:32 prescaler, internal clk
    </i></b></font><font color="#008000"><b>PAUSE </b></font><font color="#800000"><b>50                         </b></font><font color="#0000FF"><b><i>; let everything settle
    </i></b></font><b>Main</b>:
        <font color="#008000"><b>WHILE </b></font>!<b>T0IF </b>: <font color="#008000"><b>WEND           </b></font><font color="#0000FF"><b><i>; wait for timer to overflow
        </i></b></font><b>TMR0 </b>= <font color="#800000"><b>100                   </b></font><font color="#0000FF"><b><i>; load timer for 1ms
        </i></b></font><b>T0IF </b>= <font color="#800000"><b>0                     </b></font><font color="#0000FF"><b><i>; reset the overflow flag
        </i></b></font><font color="#008000"><b>IF </b></font><b>SW1 </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>then </b></font><b>Counters</b>[<font color="#800000"><b>0</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED1
        </b><font color="#008000"><b>IF </b></font><b>SW2 </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>then </b></font><b>Counters</b>[<font color="#800000"><b>1</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED2
        </b><font color="#008000"><b>IF </b></font><b>SW3 </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>then </b></font><b>Counters</b>[<font color="#800000"><b>2</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED3
        </b><font color="#008000"><b>IF </b></font><b>SW4 </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>then </b></font><b>Counters</b>[<font color="#800000"><b>3</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED4
        </b><font color="#008000"><b>IF </b></font><b>SW5 </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>then </b></font><b>Counters</b>[<font color="#800000"><b>4</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED5
        </b><font color="#008000"><b>IF </b></font><b>SW6 </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>then </b></font><b>Counters</b>[<font color="#800000"><b>5</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED6
        </b><font color="#008000"><b>FOR </b></font><b>X </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>to </b></font><font color="#800000"><b>5                      </b></font><font color="#0000FF"><b><i>; cycle thru counters
          </i></b></font><font color="#008000"><b>IF </b></font><b>Counters</b>(<b>X</b>) &gt; <font color="#800000"><b>0 </b></font><font color="#008000"><b>THEN           </b></font><font color="#0000FF"><b><i>;  if counter is counting
             </i></b></font><b>Counters</b>(<b>X</b>) = <b>Counters</b>(<b>X</b>) - <font color="#800000"><b>1  </b></font><font color="#0000FF"><b><i>;    decrement counter
             </i></b></font><font color="#008000"><b>IF </b></font><b>Counters</b>(<b>X</b>) = <font color="#800000"><b>0 </b></font><font color="#008000"><b>THEN        </b></font><font color="#0000FF"><b><i>; if counter timed out
               </i></b></font><font color="#008000"><b>SELECT CASE </b></font><b>X                </b><font color="#0000FF"><b><i>;  turn off the appropriate LED
                 </i></b></font><font color="#008000"><b>CASE </b></font><font color="#800000"><b>0 </b></font>: <font color="#008000"><b>LOW </b></font><b>LED1
                 </b><font color="#008000"><b>CASE </b></font><font color="#800000"><b>1 </b></font>: <font color="#008000"><b>LOW </b></font><b>LED2
                 </b><font color="#008000"><b>CASE </b></font><font color="#800000"><b>2 </b></font>: <font color="#008000"><b>LOW </b></font><b>LED3
                 </b><font color="#008000"><b>CASE </b></font><font color="#800000"><b>3 </b></font>: <font color="#008000"><b>LOW </b></font><b>LED4
                 </b><font color="#008000"><b>CASE </b></font><font color="#800000"><b>4 </b></font>: <font color="#008000"><b>LOW </b></font><b>LED5
                 </b><font color="#008000"><b>CASE </b></font><font color="#800000"><b>5 </b></font>: <font color="#008000"><b>LOW </b></font><b>LED6
               </b><font color="#008000"><b>END SELECT
        NEXT </b></font><b>X
    </b><font color="#008000"><b>GOTO </b></font><b>Main
    </b>
    No Interrupts required.
    HTH,
    I should add ... the counters in the previous example are retriggerable. So the delay would be from the Last button Release.
    If the delay should be from the first press, wait 10 seconds, non-retriggerable,
    then replace the switch test lines with these ...
    <font color="#000000">    <font color="#008000"><b>IF </b></font>(<b>Counters</b>[<font color="#800000"><b>0</b></font>]=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>AND </b></font>(<b>SW1</b>=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>THEN </b></font><b>Counters</b>[<font color="#800000"><b>0</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED1
        </b><font color="#008000"><b>IF </b></font>(<b>Counters</b>[<font color="#800000"><b>1</b></font>]=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>AND </b></font>(<b>SW2</b>=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>THEN </b></font><b>Counters</b>[<font color="#800000"><b>1</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED2
        </b><font color="#008000"><b>IF </b></font>(<b>Counters</b>[<font color="#800000"><b>2</b></font>]=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>AND </b></font>(<b>SW3</b>=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>THEN </b></font><b>Counters</b>[<font color="#800000"><b>2</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED3
        </b><font color="#008000"><b>IF </b></font>(<b>Counters</b>[<font color="#800000"><b>3</b></font>]=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>AND </b></font>(<b>SW4</b>=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>THEN </b></font><b>Counters</b>[<font color="#800000"><b>3</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED4
        </b><font color="#008000"><b>IF </b></font>(<b>Counters</b>[<font color="#800000"><b>4</b></font>]=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>AND </b></font>(<b>SW5</b>=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>THEN </b></font><b>Counters</b>[<font color="#800000"><b>4</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED5
        </b><font color="#008000"><b>IF </b></font>(<b>Counters</b>[<font color="#800000"><b>5</b></font>]=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>AND </b></font>(<b>SW6</b>=<font color="#800000"><b>0</b></font>) <font color="#008000"><b>THEN </b></font><b>Counters</b>[<font color="#800000"><b>5</b></font>] = <b>DelayTime </b>: <font color="#008000"><b>HIGH </b></font><b>LED6</b>
    May 2009
    Thanks for the quick response Darrel,
    I tried your code and I feel like I am getting closer but...
    first the delay was over 1 minute so by making DelayTime CON 1500 it is close to 10 seconds. Not sure if it is because I am using the internal oscilator and it is not as accurate as it should be but this is no isue.
    Instead of turning off LEDs 1-5 after 10 seconds I need to turn on another set of Leds so I added TR1 VAR PORTA.0 up to TR6 VAR PORTA.5 and I used those in the select case and so far its all good.
    I now face the following issues:
    if I hold down any of the switches (SW1 to SW6) for 3 seconds, it should cancel the Delaytime that was going to turn on TRx and branch to a different label to do something else.
    If I press and release a switch, 10 seconds later TRx turns on, I need to be able to press and release the same switch to turn off LEDx and TRx at once.
    Another aspect I didn't mention because I will deal with it later is that when TRx turns on, if I don't manually press and release the switch to turn them off, after a set timed period (written in EEPROM) it will eventually turn off both LEDx and TRx
    I have a feeling I am going to spend a few months on this...
    first the delay was over 1 minute ... Not sure if it is because I am using the internal oscilator ...
    OK, not a problem. You didn't specify an OSC earlier so I chose 20mhz.
    Let's go with 8Mhz internal.
    Change the OSC define and add this line ...
    DEFINE OSC 8
    OSCCON = %01110001               ; 8Mhz Internal
    And change TMR0 = 100 to ...
    <font color="#000000">    <b>TMR0 </b>= <font color="#800000"><b>193                   </b></font><font color="#0000FF"><b><i>; load timer for 1ms</i></b></font>
    And put DelayTime back to 10000.
    The values for different OSC and Timer reload periods can be found easily with ...
    PicMultiCalc - (Timer Helper)
    http://www.picbasic.co.uk/forum/atta...7&d=1225550328
    My example was trying to show how to deal with 6 different timers without needing 6 Timers.
    I'm affraid the "Instead of"'s will be your job.
    May 2009
    Fair enough,
    This has brought me to a level beyong what I had expected and its given me tons of ideas for the rest.
    Thank you for your help.
    Mike
    May 2009
    Darrel,
    I was able to mix the code example you provided with my previous code and I have almost completed my project. I have one final step to acomplish and it is to trigger off LED1 to 6 based on a time period. the time period is between 1 to 12 hours and can occur only every 60 minutes from the time LEDx was set high.
    I came accros your example "Elapsed Timer" using Timer1 and I think this is suitable for what I need to do. I have saved the 3 files "DT_INTS-14.bas", "ReEnterPBP.bas" and "Elapsed_INT.bas" and used your example but I am getting the following errors:
    [224] local directive only for use in macro
    [225] undefined symbol 'iflafreg'
    [226] numeric constant or symbol name expected
    [201] ')' expected
    [300] too many errors
    Could it be that chip 16F883 is not supported with this code ?
    I am using PBP 2.50c
    Mike
    You need to use MPASM for the assembler.
    It doesn't work with PBP's default PM assembler.
    May 2009
    I did a bit of code in ASM with MPLAB but If I create a project with MPLAB using MPASM, it will not compile my .bas code. I have tried using PBP within MPLAB but its not working.
    Can you give me an overview (or a link) of how to do this?
    Mike
    If you have the latest MPLAB it could be a problem.
    See the note on this page at meLabs (01/26/2009) ...
    http://melabs.com/support/mplab.htm
    Added: If you are using MicroCode Studio, don't worry about all the steps to integrate PBP into MPLAB, you won't need them.
    Just point MCS to the correct folder, and tell it to use MPASM.
    May 2009
    I have the propper version 8.15a, it came on the PBP CD (purchased 2 weeks ago)
    If I have to use MPLAB I will manage to figure it out but if you can just point me in the right direction I would appreciate.
    Do I need to use PBP Tool Suite from within MPLAB?
    Otherwize, if I use MPASM Tool Suite how would it compile the .bas section?
    Sorry about all my questions...
    May 2009
    Its all good now!
    Mike
    May 2009
    Trying out the "Elapsed Timer" I am observing these issues:
    Beeing that I don't have an LCD module, I am trying to write the values in EEPROM and then read back using a PICKit2.
    I know the code is working because LED1 is blinking and the rate seems to be good.
    My first write is succesful
    then trying to write the value for "Seconds" is always 00
    trying to write the value for Minutes is always FF (even after a few minutes)
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INCLUDE "Elapsed_INT.bas"  ; Elapsed Timer Routines
    LED1 var portc.0
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    GOSUB ResetTime           ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer          ' Start the Elapsed Timer
    write 5,3 ; this is working fine.
      IF SecondsChanged = 1 THEN
         SecondsChanged = 0
         toggle led1
         T1CON.0 = 0
         write 0,Minutes  ; this is always showing 00
         write 1,Seconds  ; this is always showing FF
         'LCDOUT $FE,2, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
    GOTO Main
    Am I missing something?
    Mike
    May 2009
    I tried adding DEFINE WRITE_INT 1 but still getting same results
    The T1CON.0 = 0 line is turning off the Timer.
    So it never counts again.
    At the start of the program, the SecondsChanged bit is set so that programs will display the initial 00:00:00.
    So it stops counting before the first second passes.
    May 2009
    Some days I feel dumber than others and today is one of those!
    I tried joining this code with my code and things are not going so well... I have a piezo beeping on the press of the swithes and when I added this code it is more like rigning than beeping and also I have a feeling I need something short and simple but I am trying to use something big and complex.
    All I really need is to have a counter that counts the minutes up to 720 and then cycle to 0 and start over endlessly. I don't need an interupt as I can test compare by branching from the main loop (in one minute I have plenty of time to test) Accuracy is not really important + or - 10 minutes over 720 is ok. I am already using timer0 so I guess I need to use timer1 or timer2.
    Do you have any simple and quick advice or link to suggest?
    I feel I have taked already too much of your time and I apologize for that.
    Mike
    Mike
    Hi Mike,
    Welcome to My World!
    counter var byte
    minutes var word
    clear  ' zero variables at start
    loop:
    PortB  = %00000000
    TRISB  = %00000000
    counter = counter + 1
    Pause 1000
    If counter >= 60 then minutes  = minutes + 1 : counter = 0
    if minutes >= 720 then gosub action
    goto loop
    Action:
    minutes = 0
    Toggle PortB.1 ' change this to do what you need done
    A great clock this will not be, it does (should do) what you asked, you may need to juggle the numbers if you have a bunch of code to stuff in.
    May 2009
    Thank you Joe,
    Unfortunately the PAUSE 1000 within my main loop is making the response too slow.
    This is my main loop ( added your example) when I press on any of the 6 switches it needs to react faster than a second later. This is why I am thinking I probably need to use timer1.
        l=0: y=0
        WHILE !T0IF : WEND           ; wait for timer to overflow
        TMR0 = 193                   ; load timer for 1ms
        T0IF = 0                     ; reset the overflow flag
        IF (SW1=0) THEN Counters[0] = DelayTime : goto Channel1
        IF (SW2=0) THEN Counters[1] = DelayTime : goto Channel2
        IF (SW3=0) THEN Counters[2] = DelayTime : goto Channel3
        IF (SW4=0) THEN Counters[3] = DelayTime : goto Channel4
        IF (SW5=0) THEN Counters[4] = DelayTime : goto Channel5
        IF (SW6=0) THEN Counters[5] = DelayTime : goto Channel6
        FOR X = 0 to 5                      ; cycle thru counters
          IF Counters(X) > 0 THEN           ; if counter is counting
             Counters(X) = Counters(X) - 1  ; decrement counter
             IF Counters(X) = 0 THEN        ; if counter timed out
               SELECT CASE X                ; turn on the appropriate LED
                 CASE 0 : if led1 = 1 then gosub StartCharge1
                 CASE 1 : if led2 = 1 then gosub StartCharge2
                 CASE 2 : if led3 = 1 then gosub StartCharge3
                 CASE 3 : if led4 = 1 then gosub StartCharge4
                 CASE 4 : if led5 = 1 then gosub StartCharge5
                 CASE 5 : if led6 = 1 then gosub StartCharge6
               END SELECT
        NEXT X
    ;               update counter                    /
        Pause 1000
        ; trigger off if it is time
        if minutes >= 720 then minutes = 0
    GOTO Main
    Well, that in itself implies there are days when you don't feel that way ...
    Only prior instances of feeling "Smart" can make you recognize the "dumb" when it comes around.
    Let's see if we can't make tomorrow a little better.
    At first I was trying to make it easy with an example Without Interrupts.
    Then you found my interrupt program, and the Elapsed Timer.
    Combining the two has no doubt created the headaches.
    I've tried to figure out what you were doing from the previous posts, and failed.
    If I could see what you had so far, I might be able to combine things using only DT_INTS.
    Who knows?
    May 2009
    Ok so in many occasions I felt like just putting up all my code but then I felt embarassed knowing how many people wil laugh...
    But here it is.
    This is what I am trying to do:
    I have 6 switches SWx, 6 LEDs LEDx and 6 Optoisolator (which will trigger TRIACS) TRx
    Normal mode:
    if I press SW1, it will turn on LED1 and wait 10 seconds before turning on TR1.
    The 10 seconds is just to wait in case I wanted to get in program mode.
    Program mode:
    Happens if I keep SW1 pressed for about 5 seconds. LED1 will blink 11 times and the program is waiting for user input on SW1 during 5 seconds. each press of SW1 will blink LED1 once. after 3 seconds of inactivity of SW1, LED1 wil blink the amount of time SW1 was pressed during program mode. if pressed 5 times during program mode LED1 will blink 5 times and it will save value 5 in EEPROM address 0. After this, going back to normal mode, if I press SW1, LED1 will go high, 10 seconds later TR1 will go high.
    If I press SW1 again LED1 and TR1 will go low. If I don't press SW1, LED1 and TR1 will go low after 5 hours (value in EEPROM)
    My default time value is 3 hours, minimum is 1 and max is 12 (720 min.)
    At this point my code is (seams to be) working perfectly with the exception that I don't know how to test when the time is up. of course I need to keep track of 6 TR.
    I ment to narrow down my code using indexes for all ports but my testing didn't go as planned so I have everything repeated 6 times.
    PLease don't laugh
    CLEAR
    INCLUDE "AllDigital.pbp"         ; Disable Analog functions
    DEFINE OSC 8
    OSCCON = %01110001
    SW1     VAR PORTB.0
    SW2     VAR PORTB.1
    SW3     VAR PORTB.2
    SW4     VAR PORTB.3
    SW5     VAR PORTB.4
    SW6     VAR PORTB.5
    LED1    VAR PORTC.0
    LED2    VAR PORTC.1
    LED3    VAR PORTC.2
    LED4    VAR PORTC.3
    LED5    VAR PORTC.4
    LED6    VAR PORTC.5
    PZ      VAR PORTC.6               ; piezo (beep)
    TR1     VAR PORTA.0
    TR2     VAR PORTA.1
    TR3     VAR PORTA.2
    TR4     VAR PORTA.3
    TR5     VAR PORTA.4
    TR6     VAR PORTA.5
    SwStat  Var bit                  ; used to control toggle of SWx
    L       var byte                 ; count SWz time hold
    I       VAR byte                 ; general use in for next
    Counters   VAR WORD[6]           ; 6 words, for 6 buttons
    ChargeTime VAR WORD[6]           ; charging time in hours
    DelayTime  CON 10000             ; 10 seconds
    T0IF       VAR INTCON.2          ; TMR0 overflow flag
    X          VAR BYTE
    Y          var byte
    OPTION_REG = %01010100           ; WPU on, TMR0 1:32 prescaler, internal clk
    PAUSE 50                         ; let everything settle
    ;  First time use, check if Charging time is configured.                 /
    ;  if not, set defaults to 3 hours. (EEPROM 0 to 5 =3 and 6=0x25         /
    read 6,y             ; if not 0x25 then it is the first time
    if y <> $25 then
        for I = 0 to 5: write i,3: next i: write 6,$25
        l=0: y=0
               END SELECT
        NEXT X
    GOTO Main
    my code is too long, the rest is in the next message
    May 2009
    here is the rest...
    Channel1:
        pause 25                                  ; debounce
        if sw1 = 0 then
            if led1 = 0 or swstat = 1 then
                if led1 = 0 then sound pz,[123,10]: high led1
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led1: sound pz,[123,10]: pause 50: next i
                    goto Bprog1
                    goto Channel1
                low led1: low tr1: sound pz,[123,10]
            while sw1 = 0: wend
        swstat = 0
    Channel2:
        pause 25                                  ; debounce
        if sw2 = 0 then
            if led2 = 0 or swstat = 1 then
                if led2 = 0 then sound pz,[123,10]: high led2
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led2: sound pz,[123,10]: pause 50: next i
                    goto Bprog2
                    goto Channel2
                low led2: low tr2: sound pz,[123,10]
            while sw2 = 0: wend
        swstat = 0
    Channel3:
        pause 25                                  ; debounce
        if sw3 = 0 then
            if led3 = 0 or swstat = 1 then
                if led3 = 0 then sound pz,[123,10]: high led3
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led3: sound pz,[123,10]: pause 50: next i
                    goto Bprog3
                    goto Channel3
                low led3: low tr3: sound pz,[123,10]
            while sw3 = 0: wend
        swstat = 0
    Channel4:
        pause 25                                  ; debounce
        if sw4 = 0 then
            if led4 = 0 or swstat = 1 then
                if led4 = 0 then sound pz,[123,10]: high led4
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led4: sound pz,[123,10]: pause 50: next i
                    goto Bprog4
                    goto Channel4
                low led4: low tr4: sound pz,[123,10]
            while sw4 = 0: wend
        swstat = 0
    Channel5:
        pause 25                                  ; debounce
        if sw5 = 0 then
            if led5 = 0 or swstat = 1 then
                if led5 = 0 then sound pz,[123,10]: high led5
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led5: sound pz,[123,10]: pause 50: next i
                    goto Bprog5
                    goto Channel5
                low led5: low tr5: sound pz,[123,10]
            while sw5 = 0: wend
        swstat = 0
    Channel6:
        pause 25                                  ; debounce
        if sw6 = 0 then
            if led6 = 0 or swstat = 1 then
                if led6 = 0 then sound pz,[123,10]: high led6
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led6: sound pz,[123,10]: pause 50: next i
                    goto Bprog6
                    goto Channel6
                low led6: low tr6: sound pz,[123,10]
            while sw6 = 0: wend
        swstat = 0
    Bprog1:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(0) > 0 THEN Counters(0) = Counters(0) - 1
        IF Counters(0) = 0 THEN
            if y = 0 then y = 3
            if y > 12 then y = 12
            write 0,y
            for I = 1 to y: high led1:sound pz,[123,10]:pause 50:low led1: pause 50: next i
        if sw1 = 0 then
            pause 25                        ;debouce
            if sw1 = 0 then
                high led1: sound pz,[123,10]: pause 25
                y = y + 1: low led1
        goto bprog1
    Bprog2:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(1) > 0 THEN Counters(1) = Counters(1) - 1
        IF Counters(1) = 0 THEN
            if y = 0 then y = 3
            write 1,y
            for I = 1 to y: high led2:sound pz,[123,10]:pause 50:low led2: pause 50: next i
        if sw2 = 0 then
            pause 25                        ;debouce
            if sw2 = 0 then
                high led2: sound pz,[123,10]: pause 25
                y = y + 1: low led2
        goto bprog2
    Bprog3:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(2) > 0 THEN Counters(2) = Counters(2) - 1
        IF Counters(2) = 0 THEN
            if y = 0 then y=3
            write 2,chargetime(2)
            for I = 1 to y: high led3:sound pz,[123,10]:pause 50:low led3: pause 50: next i
        if sw3 = 0 then
            pause 25                        ;debouce
            if sw3 = 0 then
                high led3: sound pz,[123,10]: pause 25
                y = y + 1: low led3
        goto bprog3
    Bprog4:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(3) > 0 THEN Counters(3) = Counters(3) - 1
        IF Counters(3) = 0 THEN
            if y = 0 then y = 3
            write 3,y
            for I = 1 to y: high led4:sound pz,[123,10]:pause 50:low led4: pause 50: next i
        if sw4 = 0 then
            pause 25                        ;debouce
            if sw4 = 0 then
                high led4: sound pz,[123,10]: pause 25
                y = y + 1: low led4
        goto bprog4
    Bprog5:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(4) > 0 THEN Counters(4) = Counters(4) - 1
        IF Counters(4) = 0 THEN
            if y = 0 then y = 3
            write 4,y
            for I = 1 to y: high led5:sound pz,[123,10]:pause 50:low led5: pause 50: next i
        if sw5 = 0 then
            pause 25                        ;debouce
            if sw5 = 0 then
                high led5: sound pz,[123,10]: pause 25
                y = y + 1: low led5
        goto bprog5
    Bprog6:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(5) > 0 THEN Counters(5) = Counters(5) - 1
        IF Counters(5) = 0 THEN
            if y = 0 then y = 3
            write 5,y
            for I = 1 to y: high led6:sound pz,[123,10]:pause 50:low led6: pause 50: next i
        if sw6 = 0 then
            pause 25                        ;debouce
            if sw6 = 0 then
                high led6: sound pz,[123,10]: pause 25
                y = y + 1: low led6
        goto bprog6
    StartCharge1:
        high TR1:
    StartCharge2:
        high TR2:
    StartCharge3:
        high TR3:
    StartCharge4:
        high TR4:
    StartCharge5:
        high TR5:
    StartCharge6:
        high TR6:
    Now that's just wrong headed, I make people laugh all the time. <b>GO FOR IT !</b> You join in here, you're family.
    Like you said, you've only had PBP a couple weeks ...
    Laughing would only be Rude.
    Thanks for the code!
    I think I can do something with it.
    But first I'd like to point out the WORST Basic statement ever devised.
    PAUSE xx
    It turns an amazingly fast processor into a "thumb twiddling idiot".
    Spending most of it's time doing nothing.
    If I were that chips Boss, I'd fire it.
    Granted, there are a few instances when PAUSE is required. But if at all possible, avoid PAUSE at all costs.
    Working on it ....
    PAUSE xx
    Working on it ....
    I guess I took his 720 min out of context, pretty much thought it was a stand alone app, please allow me to take For Next, Ugh Pause, and pull up my pants , . . . "thumb twiddling idiot "!, careful Darrel, that's getting pretty close to home . . . , But Darrel <B> IS ,</b> right.
    I got this lady ... could you repeat that to her?
    Mike,
    Are you stuck with the SOUND command, or do you just want a beep from the piezo?
    I'm gonna have problems with PBP's SOUND command and interrupts.
    May 2009
    The beep doesn't have to come from the sound command, I didn't know it could be generated another way! as long as it goes beep when LEDx changes state is good.
    I will learn from this project but I have a couple of other projects I will impress you with!
    Thank you soooooo much for your help.
    Mike
    Yowwwsaaaa!
    I saw something interesting floating thru the forum's waters, and I grabbed at it.
    Ummm, excuse me ... can I give it back?
    It looked like a piece of Tuna, I didn't know there was a Hook in it!
    Oh OK, I guess not.
    So many timers and conditions and beeps,
    I'm just going to gnaw on this a little more ...
    see if I can't work that hook out of my cheek before I hit surface.
    May 2009
    I was kind of fiddling with part of your timer code and part of what I had and I was able to get all the timings, highs and lows at the right place but the beep with the sound command is really lowsy, instead of beep it goes brererererep!
    Of course If I had an scope I might see other strange things!
    You can probably just turn off the Interrupts (INTCON.7) during the beeps.
    It'll stop keeping time during the beep, but in the scope of several hours charge time, you'll never notice.
    OK, well now that you already have it working ...
    I finally got mine working too.
    This one doesn't use interrupts, and is essentially the example I gave in post#3, expanded to meet the other requirements.
    May not be any help to you, but it might give some more ideas.
    View Highlighted code
    CLEAR
    DEFINE OSC 8
    OSCCON = %01110001
    SW1     VAR PORTB.0
    SW2     VAR PORTB.1
    SW3     VAR PORTB.2
    SW4     VAR PORTB.3
    SW5     VAR PORTB.4
    SW6     VAR PORTB.5
    LED1    VAR PORTC.0
    LED2    VAR PORTC.1
    LED3    VAR PORTC.2
    LED4    VAR PORTC.3
    LED5    VAR PORTC.4
    LED6    VAR PORTC.5
    TR1     VAR PORTA.0
    TR2     VAR PORTA.1
    TR3     VAR PORTA.2
    TR4     VAR PORTA.3
    TR5     VAR PORTA.4
    TR6     VAR PORTA.5
    ;---[Adjustable delay times]------------------------------------------------
    DebounceTime   CON 25            ; (ms) button debounce time
    ChargeDelay    CON 10000         ; (ms) delay before it starts charging
    ProgDelay      CON 5000          ; (ms) time to hold button for program mode
    ProgHold       CON 3000          ; (ms) of inactivity to end Program Mode
    MaxCharge      CON 12            ; (hours) Maximum Charge Time [MAX 18]
    ProgCounter    VAR WORD[6]       ; counts buttom time to enter Program Mode
    Debounce       VAR BYTE[6]       ; debounce counters
    ChargeTime     VAR BYTE[6]       ; counts charging time (hours) in Prog mode
    ChannelStates  VAR BYTE[6]       ; Channel state flags
    ChannelState   VAR BYTE
      LastState    VAR ChannelState.0 ; state of SW pin during last loop
      Pressed      VAR ChannelState.1 ; Button has been pressed
      ProgramMode  VAR ChannelState.2 ; indicates currently in program mode
      ChargeMode   VAR ChannelState.3 ; indicates currently in charge mode
    I              VAR BYTE          ; general use in for next
    X              VAR BYTE
    TempW          VAR BYTE
    OneSecond      VAR WORD
    SecondsChanged VAR BIT
    PinState       VAR BIT
    OneSecond = 1000
    OPTION_REG = %01010100            ; WPUon, TMR0 1:32 prescaler, internal clk
    DATA @0, 3, 3, 3, 3, 3, 3         ; set default Charge Time to 3 hours
    sound pz,[123,10]                 ; beep on power-up
    ;----[Main Loop]------------------------------------------------------------
        OneSecond = OneSecond - 1           ; count off 1 second intervals
        IF OneSecond = 0 THEN               ;   for charge timers
          OneSecond = 1000
          SecondsChanged = 1
        FOR X = 0 to 5                      ; cycle thru Channels
          ChannelState = ChannelStates(X)   ; get this channels state flags
          GOSUB GetSWState                  ; get the current state of the SW
          IF PinState != LastState THEN     ; debounce the pin
             LastState = PinState
             Debounce(X) = DebounceTime
          IF Debounce(X) > 0 THEN           ; If debouncing
            Debounce(X) = Debounce(X) - 1   ;   decrement the counter
            IF Debounce(X) = 0 THEN         ;   when it gets to 0
              Pressed = !PinState           ;  button is stable, get the state
              IF Pressed THEN               ;==== Button Pressed Event =========
                IF ChargeMode THEN          ;   If we're in charge mode
                   ChargeMode = 0           ;     cancel charge mode
                   Counters(X) = 0          ;     clear the counter
                   GOSUB TriacOFF           ;   turn off the triac
                  IF ProgramMode THEN       ;---- Program Mode------------------
                    IF ChargeTime(X) < MaxCharge THEN ; limit to Max charge time
                      Counters(X) = ProgHold          ; reset Prog mode Timeout
                      ChargeTime(X) = ChargeTime(X) + 1  ; increment # of hours
                      GOSUB Beep            ; beep on each button press
                    ELSE                    ; If Max has been reached
                      sound pz,[123,10]     ;   funky beep
                      sound pz,[50,10]
                  ELSE                      ;---- Normal Mode ------------------
                    ProgCounter (X) = ProgDelay  ; start program detect delay
                    IF Counters(X) = 0 THEN      ;  if not counting yet
                      Counters(X) = ChargeDelay  ;  Set Delay before Charge mode
    '                  READ X, ChargeTime(X)      ; get charge time from EEPROM
    '                  for i = 1 to ChargeTime(X) ; beep once for each hour
    '                    GOSUB Beep               ;  so user knows current
    '                  next i                     ; charge time before it starts
                      GOSUB LEDON                ;  turn on LED
              ELSE                          ;---- button released --------------
                ProgCounter (X) = 0         ;  stop looking for program press
          IF ProgCounter(X) > 0 THEN        ;---- Program Delay counter --------
             ProgCounter(X) = ProgCounter(X) - 1
             IF ProgCounter(X) = 0 THEN     ; when it times out
               Counters(X) = 0              ;   stop the Charge Delay period
               Counters(X) = ProgHold       ;   reset Program inactivity Timeout
               ChargeTime(X) = 0            ;   clear the hour counter
               for i = 1 to 11              ;   beep 11 times as requested
                 GOSUB Beep
               next i
               ProgramMode = 1              ;   -- Enter Program Mode --
          IF Counters(X) > 0 THEN            ;---- Main Delay Timers------------
            IF ChargeMode THEN               ;** In Charge Mode, time counts
              IF SecondsChanged THEN         ;                    in seconds  **
                IF Counters(X) = 0 THEN      ;   End of Charge Time
                  GOSUB TriacOFF             ;     turn off the Triac
              Counters(X) = Counters(X) - 1  ;** Normal mode counts ms **
                IF ProgramMode THEN          ;   and already in prog mode
                  ProgramMode = 0            ;   End Programming Mode
                  GOSUB LEDOFF               ;   everything OFF
                  GOSUB TriacOFF
                  IF ChargeTime(X) > 0 THEN  ; if user entered a charge time
                    WRITE X, ChargeTime(X)   ;   save it to EEPROM
                  ELSE                       ; if user didn't enter charge time
                    READ X, ChargeTime(X)    ;   restore time from EEPROM
                    GOSUB Beep
                  next i
                ELSE                         ;---- End of delay before charge --
                  ProgCounter(X) = 0         ;   Stop looking for program press
                  GOSUB LEDOFF               ;   LED OFF
                  GOSUB TriacON              ;   Triac ON - Start Charge
                  READ  X, TempW             ; Get charge time from EEPROM
                  Counters(X) = TempW * 3600 ; seconds to charge
                  ChargeMode = 1
          ChannelStates(X) = ChannelState   ; save channels state flags
        NEXT X                              ; Do the next channel
        SecondsChanged = 0                  ; clear SecondsChanged notification
    GOTO Main
    ;----I/O for each channel---------------------------------------------------
    GetSWState:
      SELECT CASE X                ; get state of this channels pin
        CASE 0 : PinState = SW1
        CASE 1 : PinState = SW2
        CASE 2 : PinState = SW3
        CASE 3 : PinState = SW4
        CASE 4 : PinState = SW5
        CASE 5 : PinState = SW6
        END SELECT
    LEDON:
      SELECT CASE X                ; turn ON the appropriate LED
        CASE 0 : HIGH led1
        CASE 1 : HIGH led2
        CASE 2 : HIGH led3
        CASE 3 : HIGH led4
        CASE 4 : HIGH led5
        CASE 5 : HIGH led6
      END SELECT
    LEDOFF:
      SELECT CASE X                ; turn OFF the appropriate LED
        CASE 0 : LOW led1
        CASE 1 : LOW led2
        CASE 2 : LOW led3
        CASE 3 : LOW led4
        CASE 4 : LOW led5
        CASE 5 : LOW led6
      END SELECT
    TriacON:
      SELECT CASE X                ; turn ON the channels Triac
        CASE 0 : HIGH TR1
        CASE 1 : HIGH TR2
        CASE 2 : HIGH TR3
        CASE 3 : HIGH TR4
        CASE 4 : HIGH TR5
        CASE 5 : HIGH TR6
      END SELECT
    TriacOFF:
      SELECT CASE X                ; turn OFF the channels Triac
        CASE 0 : LOW TR1
        CASE 1 : LOW TR2
        CASE 2 : LOW TR3
        CASE 3 : LOW TR4
        CASE 4 : LOW TR5
        CASE 5 : LOW TR6
      END SELECT
    ;----Beep-------------------------------------------------------------------
    Beep:
      GOSUB LEDON                           ; flash LED when beeping
      sound pz,[123,10]
      GOSUB LEDOFF
      pause 50
    There are a few commented lines in the "Normal Mode" section that will beep the number of hours when entering the "Delay before Charge" time. I thought it was handy to know how long it was set for before it starts charging.
    HTH,
    May 2009
    Like I was saying I was just fiddling with my code (nothing close to final version)
    Now my code has 444 lines and yours has 234 and it does the same thing!
    Its just like when my wife tells me a story and then I tell the same story...
    This is helping me out a great deal (not my wife's stories but your version of the code) in fact everyone of your posts in this thread and in other threads have helpd me understand better.
    I can't figure out if you are 65 years old and you have done this all your life or if you are 16 and living in a bubble filled with pics but you are a master at what you are doing, you where very helpful and I appreciate everything you did. Not only for me but also for others.
    Thanks Darrel, you are the best!
    All of the above.
    16 Inside, 65 outside, and chronologically hitting the big five-OH this year.
    If I'm not playing with PICs, I'm playing video games online.
    OK, maybe it's 14 inside.
    No wifey, but I can totally relate ...
    Let me know how it all ends up.
    Excellent!
    Greetings
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Delayed output 10 secs
    Please, Mr.Darrel, put again code from #3 (and#4) ? I don't understand nothing there, and I need something like this ...in one non-retriggerable button.
    Thanks in advance !
    See post #32
    Dec 2008
    Ploiesti, ROMANIA
    Thank You !
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 12:34
  2. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 22:40
  3. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  4. Serial Output 10 Bits
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 17th May 2005, 02:14
  5. Using 4 input to control 10 output
    Last Post: - 5th November 2004, 12:08
