Hi,i want to learn how can i write on graphic LCD? How can i make custom characters? How can i make new fonts in other languages? This is may first time. I bought TS12864A-2 v1.1 graphic LCD.I use PICbasic pro 2.5 and PIC16F877A.
first of all, you need to know which controller type your LCD use, here, it seems to be a KS0108.
From there, you download the usual datasheet, and try to understand how it works.
A swear jar is recommended, not a so easy task... have done it before... still trying to recover it, or redoing it from scratch next week or so.
I can not find the complete datasheet of the LCD.could you send me a PDF file or website that can help me with graphic LCD in PICBasic(PIC projects with graphic LCD)?
Search for CrystalFontz LCD. They have the range of monochrome LCD panels with data sheets if thats what you're using.
Hi, Jerson
I'd better bet on : " SHENZHEN TECHSTAR ELECTRONICS CO.,LTD "
http://www.datasheet4u.com/download.php?id=553270
Yes ofcourse Alain. Most stuff comes from China anyway![]()
Assuming I'm right, KS0108 controller, 128x64 GLCD type, the following datasheet should be handy
http://circuit-ed.com/uplds/GDM12864B.pdf
and then maybe this link too
http://www.compsys1.com/workbench/On...ontroller.html
Maybe, but the above also have it !
http://techstarlcd.en.makepolo.com/p...w/4519176.html
this is for TS12864A-1 but it shows it's really a KS0108 controller type.
So, i'm pretty confident of my links few post above.
Hi, i think this pdf file is very useful for me,do you think so or u have something better than this?
http://www.picbasic.it/it/CRN-12864C.pdf
i found another one,what about this?
http://www.electro-tech-online.com/a..._datasheet.pdf
could you explain more about the controllers that you said about LCD's?
can i use your link?( http://circuit-ed.com/uplds/GDM12864B.pdf) to work with my LCD?
because i can't find complete datasheet of my LCD that explain everything to tell me how can i make fonts and write on LCD.
There's nothing to explain... KS0108 is not a T6963 that's it. From memory.. T6963 have built-in fonts, while KS0108 don't.
Everything is in their respective datasheet, and i'd post more than enough link to get you started with your GLCD.
I will release my own KS0108 GLCD lib here probably in a week or so.. nothing free, but will be really easy to use.
EDIT: YES you should at least use my link to circuit-ed datasheet to begin.
EDIT2: thought confirm by futz
Originally Posted by futz
Perhaps you should consider graphic LCD's with a serial interface. They cost more but communication is far easier, and as a bonus, these LCD's typically provide simple commands for circles, rectangles, multi-fonts, etc.
Just google for "serial graphic LCD"
Are Serial GLCD's a viable option when you want to sell lots of kit.
What about the need odd size units how do you cater for them?
IMHO its far cheaper to find a compiler that supports GLCD's or at least has access to routines that can use them.
So..... is that your answer to every one?
If some one makes a valid suggestion that in circumstances were the compiler does not suit the application its actually more economical to use another one for that job.
You then tell them to get lost?
don't worry with Alain, must be one of his bad days
Definitly YES !!!
IF product doesn't suit your OWN requirements ... no use to loose your time. if " Time is money " for you ...
You want what PBP doesn't offer you ... why heavily insist ???
Lots of people have asked the same question as you ... in the right Forum section. One more may decide Melabs to add GLCD to the libraries ...
Who knows ???
Now one thing is sure ... PBP allows you to create your own driver ... without too many pain !!!
Hi again,imagine that i want to write "A" on this LCD,could you send me a sample code with picbasic pro that help me to know how can i work with this LCD?
could you explain more about graphic LCD? what is X,Y and Z address? how can i write on LCD? how can i make custom fonts on LCD?
This is not PicBasicPro code, but if you look through it, you will find exactly what you are looking for.
http://www.8052.com/codelib/files/12...LCD%20demo.asm
Maybe is bad ....maybe it help you.
Code:@ Device pic16F877, HS_OSC, BOD_ON, PWRT_OFF, WDT_ON, PROTECT_OFF Define osc 20 ADCON1 = 7 trisc = $00 trisd = $00 en var portd.0 rw var portd.1 rs var portd.2 cs1 var portd.3 cs2 var portd.4 reset var portd.5 rs = 1 rw = 0 en = 0 cs1 = 1 cs2 = 1 temp var byte x var byte y var byte z var byte h var byte x = 0 y = 0 z = 0 h = 0 gosub rst pause 500 gosub brisanje gosub levo gosub nulti temp = 184 gosub komanda for z = 0 to 63 lookup z,[$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$09,$09,$09,$09,$09,$09,$89,$69,$19,$09,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$f9,$89,$89,$89,$89,$89,$89,$89,$89,$f9,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 184 gosub komanda for z = 0 to 63 lookup z,[$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$f9,$09,$09,$09,$09,$09,$09,$f9,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff,$01,$01,$01,$01,$81,$81,$c1,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$81,$e1,$f1,$e1,$81,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda gosub nulti temp = 185 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$90,$88,$86,$81,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$9f,$90,$90,$90,$90,$90,$90,$90,$90,$9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 185 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$91,$91,$91,$91,$91,$91,$91,$9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$81,$83,$83,$87,$81,$81,$81,$81,$81,$81,$80,$80,$80,$80,$80,$80,$80,$80,$9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda temp = 186 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$80,$c0,$a0,$90,$88,$84,$fc,$80,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$7c,$44,$44,$44,$44,$44,$44,$44,$c4,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 186 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$fc,$84,$84,$84,$84,$84,$84,$84,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$80,$00,$c0,$00,$80,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$f0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda temp = 187 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1f,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$20,$20,$20,$20,$20,$20,$20,$20,$3f,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 187 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1f,$10,$10,$10,$10,$10,$10,$1f,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$0a,$07,$1f,$07,$0a,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$04,$1c,$3f,$1c,$04,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z gosub levo gosub nulti temp = 188 gosub komanda for z = 0 to 63 lookup z,[$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$21,$31,$f9,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$79,$09,$09,$09,$09,$89,$79,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 188 gosub komanda for z = 0 to 63 lookup z,[$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$09,$09,$09,$09,$89,$89,$89,$89,$f9,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda gosub nulti temp = 189 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$90,$90,$9f,$90,$90,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$90,$98,$94,$92,$91,$90,$90,$90,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 189 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$90,$90,$90,$90,$90,$90,$90,$90,$9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$81,$81,$81,$81,$81,$81,$81,$81,$81,$81,$81,$81,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda temp = 190 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$fc,$04,$04,$04,$04,$04,$fc,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$c0,$40,$c0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 190 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$f8,$88,$88,$88,$88,$00,$00,$f8,$88,$88,$88,$88,$98,$00,$00,$f8,$08,$08,$08,$08,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$f8,$88,$88,$08,$00,$f8,$00,$00,$f8,$00,$08,$08,$f8,$08,$08,$00,$f8,$88,$88,$08,$00,$f8,$88,$88,$88,$f8,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda temp = 191 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$9f,$90,$90,$90,$90,$90,$9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$81,$81,$81,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 191 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$8f,$88,$88,$88,$88,$80,$80,$8c,$88,$88,$88,$88,$8f,$80,$80,$8f,$88,$88,$88,$88,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$8f,$88,$88,$88,$80,$8f,$82,$84,$8f,$80,$80,$80,$8f,$80,$80,$80,$8f,$88,$88,$88,$80,$8f,$80,$81,$86,$88,$80,$80,$80,$80,$ff],temp gosub podatak next z goto kraj '************************************************************* 'komande za GLCD * '************************************************************* rst: reset = 0 pause 1000 reset = 1 temp = $3e gosub komanda pause 100 temp = $3f gosub komanda pause 100 nulti: temp = $40'+55 gosub komanda return brisanje: for x = 0 to 7 temp = $b8 + x gosub komanda for y = 0 to 63 temp = $00 gosub podatak next y next x pause 1000 return komanda: rw = 0 rs = 0 portc = temp en = 1 pause 5 en = 0 return podatak: rw = 0 rs = 1 portc = temp en = 1 pause 5 en = 0 return razmak: temp = $00 return levo: cs1 = 0 cs2 = 1 return desno: cs1 = 1 cs2 = 0 return kraj: pause 1000 goto kraj end
Last edited by ScaleRobotics; - 6th February 2011 at 14:04. Reason: added code tags
i have copied that code to picbsic pro 2.5 but it has some errors in compiling.
Jeeze...WHATEVER you do, don't tell us what the errors you got are. Let us guess at them...no wait...Let's have a lottery, or maybe we can draw pieces of paper out of a hat and guess the errors.
But since you are using PBP 2.50, look in your manual on page 30 at the bottom, then compare those comments with every one of those LOOKUP statements in the code above...
Notice anything?
Hi, Phoenix
Really a nice screen ...
I should learn Serbian language ...
Congratulations, RobertCode:'**************************************************************** '* Name : GLCD Test.BAS * '* Author : Phoenix_1 * '* Notice : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 12/04/2010 * '* Version : 1.1 * '* Notes : Easy Pic5 Modified !!! * '* : * '**************************************************************** @ Device pic16F877a, HS_OSC, BOD_ON, PWRT_OFF, WDT_ON, PROTECT_OFF Define osc 8 ADCON1 = 7 CMCON = 7 trisB = $00 trisD = $00 en var portB.4 rw var portB.3 rs var portB.2 cs1 var portB.0 cs2 var portB.1 reset var portB.5 rs = 1 rw = 0 en = 0 cs1 = 1 cs2 = 1 temp var byte x var byte y var byte z var byte h var byte x = 0 y = 0 z = 0 h = 0 gosub rst pause 500 gosub brisanje gosub levo gosub nulti temp = 184 gosub komanda for z = 0 to 63 lookup z,[$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$09,$09,$09,$09,$09,$09,$89,_ $69,$19,$09,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff,$01,$01,$01,$01,$01,_ $01,$01,$01,$01,$01,$f9,$89,$89,$89,$89,$89,$89,$89,$89,$f9,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 184 gosub komanda for z = 0 to 63 lookup z,[$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$f9,$09,$09,$09,$09,$09,$09,_ $f9,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff,$01,$01,$01,$01,$81,$81,$c1,_ $01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$81,$e1,$f1,$e1,$81,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda gosub nulti temp = 185 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$90,$88,$86,$81,$80,_ $80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$80,$80,_ $80,$80,$80,$80,$80,$9f,$90,$90,$90,$90,$90,$90,$90,$90,$9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 185 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$91,$91,$91,$91,$91,$91,$91,_ $9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$81,$83,$83,$87,_ $81,$81,$81,$81,$81,$81,$80,$80,$80,$80,$80,$80,$80,$80,$9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda temp = 186 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$80,$c0,$a0,$90,$88,$84,$fc,_ $80,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$7c,$44,$44,$44,$44,$44,$44,$44,$c4,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 186 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$fc,$84,$84,$84,$84,$84,$84,_ $84,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$80,$00,$c0,_ $00,$80,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$f0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda temp = 187 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1f,_ $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$20,$20,$20,$20,$20,$20,$20,$20,$3f,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 187 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1f,$10,$10,$10,$10,$10,$10,_ $1f,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$0a,$07,$1f,_ $07,$0a,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$04,$1c,$3f,$1c,$04,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z gosub levo gosub nulti temp = 188 gosub komanda for z = 0 to 63 lookup z,[$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$21,$31,$f9,$01,_ $01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff,$01,$01,$01,$01,$01,_ $01,$01,$01,$01,$01,$01,$01,$79,$09,$09,$09,$09,$89,$79,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 188 gosub komanda for z = 0 to 63 lookup z,[$ff,$01,$01,$01,$01,$01,$01,$01,$01,$01,$09,$09,$09,$09,$89,$89,$89,_ $89,$f9,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff,$01,$01,$01,$01,$01,$01,$01,_ $01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda gosub nulti temp = 189 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$90,$90,$9f,$90,_ $90,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$80,$80,_ $80,$80,$80,$80,$80,$80,$80,$90,$98,$94,$92,$91,$90,$90,$90,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 189 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$90,$90,$90,$90,$90,$90,$90,_ $90,$9f,$80,$80,$80,$80,$80,$80, $80,$80,$80,$80,$ff,$80,$80,$80,$80,$80,$80,$80,_ $80,$80,$80,$81,$81,$81,$81,$81,$81,$81,$81,$81,$81, $81,$81,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda temp = 190 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$fc,$04,$04,$04,$04,_ $04,$fc,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$00,$00,_ $00,$00,$00,$00,$00,$00,$00,$00,$00,$c0,$40,$c0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 190 gosub komanda for z = 0 to 63 lookup z,[$ff,$00,$00,$00,$f8,$88,$88,$88,$88,$00,$00,$f8,$88,$88,$88,$88,$98,_ $00,$00,$f8,$08,$08,$08,$08,$00,$00,$00,$00,$00,$ff,$00,$00,$00,$f8,$88,$88,$08,_ $00,$f8,$00,$00,$f8,$00,$08,$08,$f8,$08,$08,$00,$f8,$88,$88,$08,$00,$f8,$88,$88,$88,$f8,$00,$00,$00,$00,$ff],temp gosub podatak next z temp = 0 gosub levo gosub komanda temp = 191 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$9f,$90,$90,$90,$90,_ $90,$9f,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff,$80,$80,$80,$80,$80,_ $80,$80,$80,$80,$80,$80,$80,$80,$80,$81,$81,$81,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$ff],temp gosub podatak next z temp = 0 gosub desno gosub komanda temp = 191 gosub komanda for z = 0 to 63 lookup z,[$ff,$80,$80,$80,$8f,$88,$88,$88,$88,$80,$80,$8c,$88,$88,$88,$88,$8f,_ $80,$80,$8f,$88,$88,$88,$88,$80, $80,$80,$80,$80,$ff,$80,$80,$80,$8f,$88,$88,$88,_ $80,$8f,$82,$84,$8f,$80,$80,$80,$8f,$80,$80,$80,$8f,$88,$88,$88,$80,$8f,$80,$81,$86,$88,$80,$80,$80,$80,$ff],temp gosub podatak next z goto kraj '************************************************* ************ 'komande za GLCD * '************************************************* ************ rst: reset = 0 pause 1000 reset = 1 temp = $3e gosub komanda pause 100 temp = $3f gosub komanda pause 100 nulti: temp = $40'+55 gosub komanda return brisanje: for x = 0 to 7 temp = $b8 + x gosub komanda for y = 0 to 63 temp = $00 gosub podatak next y next x pause 1000 return komanda: rw = 0 rs = 0 portD = temp en = 1 pause 1 '5 en = 0 return podatak: rw = 0 rs = 1 portD = temp en = 1 pause 1 '5 en = 0 return razmak: temp = $00 return levo: cs1 = 0 cs2 = 1 return desno: cs1 = 1 cs2 = 0 return kraj: pause 1000 goto kraj end
I just sped it a bit, as datasheet enable cycle time is specified @ 1 ms ...
Hi Alain,
It was only test for some my project .....
Yes it was slow but work and it was in my start to play with graphic display with touch screen from Mikro Elektronika.....
It cost 20EUR but there is much faster GLCD in market...
The best regards
/Robert
Hello,
May I ask some of you what designing software* you use to create the graphics?
I'm starting using a EADOGL128-6 display (http://www.lcd-module.com/products/dog.html). At the bottom of this website, there's a soft I may use.
Nevertheless, is there a program most people use?
*I'm using Windows XP
Roger
Can you post a tutorial or something like that,so I can made my own picture on GLCD?And how to put a text line,from mesurments with DS18B20?
If you just mean graphics, and not picture, here is one http://www.picbasic.co.uk/forum/cont...Nokia-3310-LCD
And a thermostat using the 3310 and a DS18B20 http://www.picbasic.co.uk/forum/show...7933#post87933
If you really need a picture then you could get one of these: http://www.picbasic.co.uk/forum/cont...D-code-example
Mikroelektronika offers it's GLCG Bitmap editor in their Free version compilers ...
nice tool to convert Bitmaps to " printable " files ...
You just have to write the " driver " to print the 8192 generated pixels ... or exactly ... the 1024 bars !
here's such file :
AlainCode:// ------------------------------------------------------ // GLCD Picture name: truck.bmp // GLCD Model: KS0108 128x64 // ------------------------------------------------------ unsigned char const truck_bmp[1024] = { 0, 0, 0, 0, 0,248, 8, 8, 8, 8, 8, 8, 12, 12, 12, 12, 12, 10, 10, 10, 10, 10, 10, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9,137,137,137,137,137,137, 137,137,137,137,137,137,137, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 13,253, 13,195, 6,252, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,255, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 240,240,240,240,240,224,224,240,240,240,240,240,224,192,192,224, 240,240,240,240,240,224,192, 0, 0, 0,255,255,255,255,255,195, 195,195,195,195,195,195, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,255,240, 79,224,255, 96, 96, 96, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 64, 64, 64, 64,128, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,255, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255,255,255,255,255, 0, 0, 0, 0,255,255,255,255,255, 0, 0, 0, 0,255,255,255,255,255, 0, 0, 0,255,255,255,255,255,129, 129,129,129,129,129,129,128, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,255, 1,248, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 16,224, 24, 36,196, 70,130,130,133,217,102,112, 160,192, 96, 96, 32, 32,160,160,224,224,192, 64, 64,128,128,192, 64,128, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 63, 96, 96, 96,224, 96, 96, 96, 96, 96, 96, 99, 99, 99, 99, 99, 96, 96, 96, 96, 99, 99, 99, 99, 99, 96, 96, 96, 96, 99, 99, 99, 99, 99, 96, 96, 96, 99, 99, 99, 99, 99, 99, 99, 99, 99, 99, 99, 99, 99, 96, 96, 96, 96, 96, 96, 96, 64, 64, 64,224,224,255,246, 1, 14, 6, 6, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,130, 67,114, 62, 35, 16, 16, 0, 7, 3, 3, 2, 4, 4, 4, 4, 4, 4, 4, 28, 16, 16, 16, 17, 17, 9, 9, 41, 112, 32, 67, 5,240,126,174,128, 56, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1,127,127,127,127,255,255,247,251,123,191, 95, 93,125,189, 189, 63, 93, 89,177,115,243,229,207, 27, 63,119,255,207,191,255, 255,255,255,255,255,255,255,127,127,127,127,127,127,127,127,255, 255,255,127,127,125,120,120,120,120,120,248,120,120,120,120,120, 120,248,248,232,143, 0, 0, 0, 0, 0, 0, 0, 0,128,240,248, 120,188,220, 92,252, 28, 28, 60, 92, 92, 60,120,248,248, 96,192, 143,168,216,136, 49, 68, 72, 50,160, 96, 0, 0, 0, 0, 0, 0, 0, 0, 0,128,192,248,248,248,248,252,254,254,254,254,254,254, 254,254,254,254,254,255,255,255,255,255,246,239,208,246,174,173, 169,128,209,208,224,247,249,255,255,252,220,240,127,255,223,255, 255,255,255,255,255,254,254,255,255,255,255,255,255,255,254,255, 255,255,255,255,255,255,254,254,254,254,254,254,254,254,254,254, 254,254,254,254,255,255,255,255,255,255,254,255,190,255,255,253, 240,239,221,223,254,168,136,170,196,208,228,230,248,127,126,156, 223,226,242,242,242,242,242,177, 32, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 3, 3, 3, 7, 7, 7, 7, 7, 15, 15, 15, 7, 15, 15, 15, 7, 7, 15, 14, 15, 13, 15, 47, 43, 43, 43, 43, 43, 47,111,239,255,253,253,255,254,255,255,255,255,255, 191,191,239,239,239,191,255,191,255,255,255,255,255,255,255,255, 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255, 255,255,255,255,127,127,127,127,255,255,191,191,191,191,255,254, 255,253,255,255,255,251,255,255,255,127,125, 63, 31, 31, 31, 31, 31, 31, 63, 15, 15, 7, 7, 3, 3, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 3, 3, 3, 11, 11, 11, 11, 7, 3, 14, 6, 6, 6, 2, 18, 19, 19, 3, 23, 21, 21, 17, 1, 19, 19, 3, 6, 6, 14, 15, 15, 7, 15, 15, 15, 11, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
Another GLCD Assistant :
http://en.radzio.dxp.pl/bitmap_converter/
