Temperature Controller using PIC16F628A
Results 1 to 35 of 35
    Oct 2008
    Default Temperature Controller using PIC16F628A
    hello friends
    i want Temperature Controller using PIC16F628A
    the sensor of the temperature controller is thermocouple
    i am a newer in PIC section
    my concept is that the output of the thermocouple is given to a amplifier
    the display might me 7-segment display
    please help me friends
    give me the circuit & code
    thanks in advance
    Quote Originally Posted by bentech4u View Post
    hello friends
    Oct 2008
    http://www.machinegrid.com/content/view/51/1/
    please see this circuit
    i want such type of circuit
    but in this circuit,there is no amplifier placed on it
    which amplifier is suitable for that..?
    and the display unit of this project is LCD..I want only 7-segment display
    so please guide me friends to make a suitable circuit & code
    thanks
    Oct 2008
    wat's the pro..?
    why R u laughing..?
    me a newer in this forum...is there any rules..?
    wat's the pro..?
    why R u laughing..?
    Post Edited out - because making fun of others in this way isn't nice, and has resulted in complaints from other forum members - Melanie.
    Oct 2008
    Wink SMS Forbidden here !!!
    The good help Number is AD 595 or MAX 6675 ...
    a link :
    http://www.emesystems.com/OL2therm.htm
    have a nice day ...
    Have you used this chip before?
    The sensor in the information you gave is not a thermocouple. Do you need a thermocouple or ...
    Yep, me too. Always something new.
    Amplifier is not needed with sensor shown.
    Search for examples on this forum.
    thanks in advance
    That is the problem. We like to help people learn. If you want the code complete given...see me outside. My bank account #0000029A
    Now, to help you, we need some info:
    What programmer do you use?
    What compiler do you use?
    Have you programmed anything into the PIC yet? If so, what? If not. Lets start with making am Led blink, then we will go from there.
    That's amazing! I've got the same combination on my luggage!
    Oct 2008
    no Me jst build a Programmer,RCD Programmer.Using that me connect the IC,it's wrking
    i have a thermocouple with chromel-Alumel
    RCD programmer with IC-Prog 1.06
    i don't have a compiler...please give me the name of a good compiler
    me just burned some simple programs..
    please give me the port info of PIC16F628
    i want an easy tutorial
    I like Pic Basic Pro.
    Oct 2008
    Pic Basic Pro is not a free tool..?
    Nope, but that is what we use here... Or the regular version of Pic Basic, a bit cheaper.
    Oct 2008
    k i got Pic Basic full version...
    then..
    is there any tutorials for that
    Wow you got it fast Teleportation exist now
    Well, there's code example on Melabs website, when you purchase PBP the manual come with, and there is this forum.
    That's more than enough code example
    Oct 2008
    k then how can i learn PIC16F628A programming easily
    explain the steps
    thanks 4 your rply
    explain the steps
    thanks 4 your rply
    Read
    the
    manual
    and
    data
    sheet
    And this will be something you need to know.
    Well really first step is to download the PIC datasheet on Microchip's website. Then you try to read most part of it.
    Read your PBP manual and try the very first LED Blink example.
    Attach some push button, LCD or whatever else fancy hardware to your PIC and try the related commands listed in the PBP manuals.
    Sure there will be some issues, when it's the case, just paste your code and schematic here and we will help you to understand what happen and why.
    Do a search within this frum with PIC16F628, sure enough, youèll find tons of code example as it was, and still, a really popular PIC model.
    Oct 2008
    What is CC5X C compiler...?
    It's another compiler type. Their demo version is limited as well.
    http://www.bknd.com/cc5x/
    And of course, not supported by this forum.
    Oct 2008
    This forum is really Great
    thanks friends
    me already downloaded CC5X C...how it works
    is there any visual developer for PIC..?
    Oct 2008
    me downloaded PIC Basic pro ful
    how to run it
    me extracted that..in that folder their is a exe file named as PBP.EXE
    me just double click on it..nothing happens
    guide me
    Oct 2008
    i already installed that
    but i don't no how can wrk with this
    also PIC Basic pro not working
    This is where you type your code. Then when you are ready, click the compile button and PBP kicks in and does its work. PBP runs in the back ground.
    Use the help file to see how to set it up.
    Hmmmm.....How does that work?
    What site did you get that from? I want a copy too.
    then..
    6 minutes from ordering to shipment to install...
    How does that work?
    You might find some more answers here...
    http://forum.allaboutcircuits.com/sh...ad.php?p=95167
    and maybe more information here...
    http://www.picbasic.org/forum/showthread.php?t=10375
    and if you Google bentech4u, you might even find some better information on the 3rd hit!
    (Warning: NSFW)
    Talking Best "Message of the year" award !!!
    guide me
    Did you Also download the registration Key ???
    ROFL ...
    Hi, Ski ... doesn't ring a bell somewhere ??? I Call that Bittorrent or Emule ...
    Mar 2010
    Default Need help with pic16f628A and DS1820
    Hi Folks,
    I am new to this forum, I am trying to design a temperature controller using pic16F628A and DS1820 (Basic idea from - http://www.guidecircuit.com/Circuit-...thermostat.htm).
    I have been trying to add dynamic temperature setting (up and down) buttons and remove the start button. but was unable to do.
    I am very new to programming the PIC micro controllers I am using MPLAB IDE v7.40 to build .asm files to .HEX, I am not sure if I can code C using this IDE, if I can please help me on how can I do it.
    I am using Real PIC simulator to test the HEX. But still the the real circuit is not working as per the design given in the site above, I am not sure if I have done some thing wrong in the circuit or it has some issue (if some one can identify the issue please point me to the same.)
    Lightbulb
    Quote Originally Posted by pvgoutham View Post
    Hi Folks,
    I am new to this forum ...
    Hi, pv
    I see TWO problems ...
    1) you weren't able to run the original project on the sim
    2) you want but can't modify the original project ...
    1) Difficult to give an answer ... but I just see the CONFIG parameters of the CPU are not given in the source ...
    so you have to set them in the CONFIG Window of MPLAB ...
    2) You're here aboard a PicBasic Forum where people eventually can understand assembler but surely not tell you what to do to modify such a program.
    you'd better join Microchip or a general Forum for asm using ... and receiving useful help.
    May be contact the project author ... too.
    Mar 2010
    Default RE: Temperature Controller using PIC16F628A
    Hi
    The Program/project ran successfully in the Real PIC simulation.
    But not on the hardware, can any one help and identify any issue with hardware.
    Regard,
    Vinay
    scary... very, very scary...
    wow...
    Dec 2008
    Ploiesti, ROMANIA
    I started to build my own temperature controller for an SMD oven I am building. Then I found this controller: http://www.omega.com/pptst/CN7500.html
    My time is worth more than $97.00...
    Mike Tripoli
  1. Help Pic16f628a
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 26th August 2008, 23:22
  2. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 18:21
  3. Help for decimal conversion
    Last Post: - 15th March 2007, 18:20
  4. temperature controller
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 24th April 2006, 20:01
  5. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 00:14
