Timer1 - frequency measurement
Results 1 to 16 of 16
    Jul 2007
    Default Timer1 - frequency measurement
    Has anyone got a sample program showing how to measure the frequency of an input, i want to measure the frequency of a transmitter.
    i'm using a pic16f870, i've been reading the information on timer1 but i don't totally understand how to accomplish what i need.
    Dan
    Quote Originally Posted by -Dan- View Post
    Dan
    Straight from the manual...
    COUNT Pin,Period,Var
    Count the number of pulses that occur on Pin during the Period and
    stores the result in Var. Pin is automatically made an input. Pin may
    be a constant, 0-15, or a variable that contains a number 0-15 (e.g. B0)
    or a pin name (e.g. PORTA.0).................
    But seriously, what frequency range are you planning on counting?
    Jul 2007
    I considered using count, but i do not no its limitations what will it count up to?.
    I want to measure in the 88-200mhz range, i doubt the pic can support this kind of range so i have got an external prescaler which will divide by 256 or 64.
    stores the result in Var. Pin is automatically made an input.........
    Does that give you a clue as to the answer?
    You're going to divide RF using an 'external prescaler'?
    Good luck with that...
    Hi, Dan
    The Web is full of Ham Freqmeters ...
    "Google is you friend."
    EPE's last edition show a nice 50 Mhz one ... w/o prescaler.
    µChip ANs show the original idea for those ones.
    just yours to choose which one !!!
    Jul 2007
    See the below image
    http://hem.passagen.se/communication/pic/fct_sch.gif
    this is a project i found that does what i wanted, but it does not explain the programming side of capturing the frequency, which i want to understand.
    I only want to learn lol
    Talking
    Looking at this ...pic. I do think PbP has not its place inside the 870 !!!
    125 Khz * 256 = ... 32 Mhz
    That link doesn't work so good for me...might for some, not for me at the moment...
    So what did you get out of this?
    Jul 2007
    What do you mean?
    and the 125khz is that the maximum frequency the 16f870 can capture?
    Timer1 can work with some pretty quick external input clocks. Check the electrical specs
    section TIMER0 AND TIMER1 EXTERNAL CLOCK REQUIREMENTS.
    Look at the specs for T1CKI High Time, T1CKI Low Time, and T1CKI Input Period.
    With a pickup coil tuned to the frequency you're measuring, and the /64 output, it should
    be pretty simple to measure your freq range.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jul 2007
    Hi Bruce,
    I've read that, but i don't totally understand it, thats why i wanted some help in getting started, i no timer1 would do what i need, but i don't no how to control timer1, i've never written a program that uses it.
    May 2008
    Italy
    Visit the given link, schematic and code available.
    http://digilander.libero.it/alfred73/eprojects.htm#1300 Mhz Frequencymeter with prescale
    Al.
    Which part are you having trouble with? I'll be happy to explain it.
    T1CON on the 16F870 only has 6-bits that control the timer. Let me know what you don't understand that's in the data sheet, and I'll do my best to explain it. It would help if you tried a few code examples, and indicated which part you're having trouble with.
    -Bruce
    tech at rentron.com
    Jul 2007
    I don't understand how i work out, what the maximum frequency timer1 could capture from that data
    The datasheet shows T1CKI High Time min is 30nS for asynch mode with a prescaler of 1:1.
    T1CKI Low Time is 30nS. And T1CKI minimum Input Period is 60nS.
    So 1/60nS = the max input clock frequency it could handle. With your max freq at 200MHz
    divided by 64, you should be well below the max clock input limit.
    Look for AN592. Microchip shows an example using an old PIC1C5x with Timer0 that counts
    up to 50MHz.
    -Bruce
    tech at rentron.com
    Jul 2007
    Look for AN592. Microchip shows an example using an old PIC1C5x with Timer0that counts
    up to 50MHz.
    Is there any examples written in picbasic pro, that you know of.
  1. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 15:07
  2. Advice on frequency measurement to 30MHz
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 04:23
  3. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 16:22
  4. frequency measurement
    By big-x in forum General
    Last Post: - 25th November 2005, 00:53
  5. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 01:24
