Write Onewire data toa I2C memory / read ASCI
Page 1 of 2 12 LastLast
Results 1 to 40 of 68
    Nov 2007
    Default Write Onewire data toa I2C memory / read ASCI
    Hi !
    I have a display with leds . If I write a text to a I2C memory (24FC512),I can read and scroll this text on leds display . But...I wish to write the result of measurement from ONEWIRE sensor DS1820 for example :
    " temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c) "
    and to read / display ASCI karacter , something like this :
    "i2cread I2CDAT , I2CCLK , $A0,adrr,[karacter]" karacter to be ASCI code
    I can not know to do this . Can somebody to help me ?
    Thank you very much !
    PS. Escuse me ! I do not know so well english .
    Jul 2007
    Bavaria
    Hi Eugeniu,
    it's not clear to me what you want to do, maybe point 4.17.7. in the manual is what you should have a look at.
    4.17.7 DIG
    DIG returns the value of a decimal digit. Simply tell it the digit number
    (0 - 4 with 0 being the rightmost digit) you would like the value of, and
    voila.
    B0 = 123 ‘ Set B0 to 123
    B1 = B0 DIG 1 ‘ Sets B1 to 2 (digit 1 of
    123)
    This allows you to separate each digit from the computed result.
    But you can also divide the word into two bytes using the .lowbyte and .highbyte modifiers and write them to the display or memory.
    HTH
    Ingo
    Nov 2007
    Quote Originally Posted by inse View Post
    Hi Eugeniu,
    it's not clear to me what you want to do, maybe point 4.17.7. in the manual is what you should have a look at......................
    I will try to explain :
    I use in this moment .....writing a text in a I2C memory ........
    for adr = 0 to 135
    lookup adr,["WELLCOM ! .......................... 5"],c
    I2cwrite I2CDAT , I2CCLK , $A0,ADR,[C]
    pause 5
    next adr
    Read text :
    i2cread I2CDAT , I2CCLK , $A0,J,[caracter]
    Use " case " for select :
    SELECT CASE CARACTER
    CASE 65: SIR_NO=4 ;A
    CASE 66: SIR_NO=9 ;B
    CASE 67: SIR_NO=14 ;C
    CASE 68: SIR_NO=19 ;D
    CASE 69: SIR_NO=24 ;E
    and .....go for select what leds are on .....
    TABLOU:
    LOOKUP OFSET,[_
    $3F,$48,$48,$48,$3F,_ ;A 0-4
    $36,$49,$49,$49,$7F,_ ;B 4-9
    $22,$41,$41,$41,$3E,_ ;C 9-14
    $3E,$41,$41,$41,$7F,_ ;D 14-19
    $41,$49,$49,$49,$7F,_ ;E 19-24
    I wish to write time to time in memory a temperature from a Onewire sensor tip DS1820 and when I read from memory to find there a ASCI CODE to can use same , in my program .
    May 2008
    Italy
    I have difficulty in understanding what you want to do! You should post the complete code to better understand what you have done and what you want to achieve.
    Remember that you cannot write and read with the same control!
    use:
    WriteDev con %10100000
    ReadDev con %10100001
    Perhaps it will solve your present problem.
    Al.
    Nov 2007
    Quote Originally Posted by aratti View Post
    Al.
    Briefly : Tell me how can write in a I2C memory result from this :
    mainloop:
    OWOut DQ, 1, [$CC, $44] ' Start temperature conversion
    waitloop:
    OWIn DQ, 4, [count_remain] ' Check for still busy converting
    If count_remain = 0 Then waitloop
    OWOut DQ, 1, [$CC, $BE] ' Read the temperature
    OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    'Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    adr = xx
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[temperature]
    pause 5
    and how can read from memory something xx,xx (ASCI CODE )
    Quote Originally Posted by Eugeniu View Post
    I too am having a bit of difficulty in understanding what you wish to achieve...
    adr = xx
    pause 5
    Is 'temperature' a byte or a word value?
    Are you wanting to get a fractional value out of the eeprom itself?
    Have you put a fractional value into that location of the eeprom?
    I2CREAD I2CDAT , I2CCLK , $A0 , adr , [ temp_read ] - would be a command line for starters...
    Nov 2007
    " i2cwrite I2CDAT, I2CCLK, $A0, adr,[I do not know what to write here ]".......
    and , to can read 2 digits and 2 decimals for example
    25,55 grade C
    25,55 grade C
    If you read the PBP manual, you'll find commands in the LCD, I2Cxxxx, SERIN/SEROUT, HSERIN/HSEROUT, and various other sections that will show you have these various commands handle digits, decimals (which PBP does NOT natively handle), numeric characters, ASCII values, etc.etc.etc. DEC DIG HEX BIN, and all sorts of other good information in there...
    May 2008
    Italy
    Split value into two separate bytes
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[Byte_integer,Byte_decimal]
    Al.
    Nov 2007
    I put all program .
    Nov 2007
    Al.
    You can see in program that I wish to do this . to write at adr. 71 2 digits , and at adr 74, other 2 ( decimals ) But how ?
    Nov 2007
    I know this , and I have used for LCD display , for serin/serout and work , but now I do not know how can use this commands for I2CXXXX. When I use one of this do not accept by MicroCode Studio .
    You don't have to store them in eeprom in anyway out of the ordinary. If you can display it using those modifiers, then store the data as the raw data. Then recover it as raw data and display it using those modifiers again. You don't have to do anything special to store it.
    Nov 2007
    Can you give me a in context example ? Please !
    Thank you !
    Just exactly what you had...
    Then read them back the same way and display them on the LCD seperately with a decimal point in between them.
    Nov 2007
    I do not use LCD , I use a 7 X 96 leds panel . With LCD is very simple ! Support all of these "DEC DIG HEX BIN,"
    Ahhh....ok....I see now...
    Well then...your answer is in post #2...
    Nov 2007
    I am sorry ! but I do not see in mind the solution for my problem .
    I say again : PLEASE ! SHOW ME IN CONTEXT EXAMPLE , in my programme.
    Ok, you can't display a byte variable directly because a byte (if larger than 9) contains more than one numeric character right?
    Nov 2007
    I must to read from memory , for example :for 25,55 (grade C ) I must to read from memory ...50 53 44 53 53 , or except " , " 50 53 53 53
    Yes, I understand, I think... A bit of a language disconnect here I think Not that your English is bad, it's not bad at all, it's far far better than my ______(insert language here)...
    Those sequences of numbers above...What are they? Is that how you have it stored? Or is that how you want to display it...
    What is 25,55? Is it 25.55? Or is it 25, then 55, and so on (I realize in Europe and other parts of the world the comma ( , ) is used in much the same way that folks in the States use the decimal point)...
    Nov 2007
    They are in ACII code . I attach it .
    Is not impportant , is a separration sign between 25(integer) and 55(2 decimals)
    Jul 2007
    Bavaria
    Hi Eugeniu,
    as I have already explained in my first post:
    use the DIG modifier to separate the single digits of your calculated temperature.
    Then simply add 48 to each digit and you will get the ASCII code.
    If temperature is 2555 for 25.55°C
    n0 = (temperature dig 0) + 48
    n0 is 48+5 = 53 = ASCII "5"
    Ingo
    Nov 2007
    Hi Eugeniu,
    Ingo
    Dear Ingo ,
    I work by many days to do this and in my mind is a black hole. Please if you wish to help me , write a example ,
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[TELL ME WHAT i MUST TO WRITE HERE ]
    I think that you now formula for temperature measurement with Onewire sensor ( one from others ) :
    If I will write :
    LCDOUT $FE, $C0, DEC TEMPERATURE
    I'll be reading 2555
    For LCDOUT and to see a comma , I use this formula :
    lcdout "temp= " , dec temperature/2 ,"," , dec2 100- (100/16)*(count_remain)," gr.C"
    , but ....If I write in EEPROM :
    When I will read it with my FORMULA :
    in " caracter "will can be read , time to time , a single sign / not a cipher
    Jul 2007
    Bavaria
    Hi Eugeniu,
    your program is a little bit hard to read without knowing Romanian (right?).
    If you want to store the temperature value in single ASCII characters, something like this might work:
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[(temperature dig 0= + 48, (temperature dig 1) + 48, (temperature dig 2) + 48, (temperature dig 3) +48]
    Add the comma where you please or add it after reading back the value.
    Correct me if I am talking bull****...
    Ingo
    Nov 2007
    Hi Eugeniu,
    Ingo
    Uffff, not work . I see or 88888888 , or 44444444 or 77777777 .......
    I'll try to write every DIG , separate . I'll tell you tomorow if work .
    Thank you very much ! Good night !
    If that's the only thing you are getting out of the temp sensor, then I'm thinking it probably meaning that your connection or your sensor probably isn't working because it's returning a value that's always max'd out for a byte variable...
    Put the sensor in some ice water and see if the reading changes...
    Get the core working first, then start adding things. You're not even sure if the sensor part is working in the first place!
    Each one of these statements might only be WRITE'ing (or READ'ing) a BYTE, not a WORD. Not sure what the rest of your code says...
    May 2008
    Italy
    You wrote:
    "LCDOUT $FE, $C0, DEC TEMPERATURE
    I'll be reading 2555 "
    Now:
    ByteInteger = TEMPERATURE/100
    ByteDecimal = TEMPERATURE-(ByteInteger*100)
    LCDOUT $FE, $C0, DEC ByteInteger,",",ByteDecimal
    You will see on your display 25,55.
    You don't need to store the comma (separator) but you will store only ByteInteger and ByteDecimal in a location that can be recalled to read back the values. Than after the reading you will add the separator as above.
    Al.
    May 2008
    Italy
    Sorry I have forgotten a Dec. Please read......
    LCDOUT $FE, $C0, DEC ByteInteger,",",DEC ByteDecimal
    Nov 2007
    Dear MEN !
    I do not use a LCD display . I have make only a comparision .
    I use in front of my program this line to write text "
    I2Cwrite I2CDAT, I2CCLK, $A0, adr,[" Temperature is _________________ "]
    late in program , in free space I wish to write DATA of temperature
    adr = 15( where is free space )
    I2Cread I2CDAT, I2CCLK, $A0, adr,[ temperature DATA ]
    In finish, I wish to can read all - text and temperature DATA as ASCI CODE such as
    Temperatura is 25,55(for example) .
    from this formula :
    program read for every adrress (j) a sign (caracter ) in ASCI Code , and this CODE i'll translate in leds on .But where I write temperature DATA , program read other signs not ASCI CODE for 25,55 ( for example )
    Now understand me ?
    I 'll try to write only text with quote and temperature DATA except quote
    Nov 2007
    Not work . Data from DS1820 temperature sensor is in binary . Do you know how can convert it in decimal and use in formula ? Except use DEC .
    May 2008
    Italy
    I assume you have grounded pin 1 , pin 2 and pin 3 of your 24LC01 chip and that you have pulled up pin 6 and pin 5 with a 4.7K resistors (see page 85 of the manual)
    Just use the following code:
    'set these variable
    Celsius VAR BYTE [32]
    Fix text in the array
    Celsius[0]=84
    Celsius[1]=101
    Celsius[2]=109
    Celsius[3]=112
    Celsius[4]=101
    Celsius[5]=114
    Celsius[6]=97
    Celsius[7]=116
    Celsius[8]=117
    Celsius[9]=114
    Celsius[10]=32
    Celsius[11]=105
    Celsius[12]=115
    Celsius[13]=32
    Celsius[14]=0
    Celsius[15]=44
    Celsius[16]=0
    Now in your program you read temperature from your device and you have the value in the variable TEMPERATURE!
    write:
    Celsius[14] = TEMPERATURE/100
    Celsius[16] = TEMPERATURE - (Celsius[14]*100)
    So you will have the integer part of your value in Celsius[14] and the decimal part in Celsius[16]. Celsius[15]=44 is your separator.
    Now write to your memory at address 0
    adr=0
    I2CWRITE I2CDAT, I2CCLK, WriteDev , adr,[ Str Celsius\32]
    PAUSE 10
    Now if your hardware works properly, you should have stored in your memory the string and the values.
    To recall them back:
    adr=0
    I2CREAD I2CDAT, I2CCLK, ReadDev , adr,[ Str Celsius\32]
    Pause 10
    At this point you send the array to your display
    For A0=0 to 16
    single byte (Celsius[A0]) can be sent to your display
    Next A0
    If you need to store more than on single value you have to increment your Address (adr) by a multiple of 32, and with two values you have filled one page (64 bytes)
    Al.
    Nov 2007
    QUOTE=aratti;
    I use this display NOW , and scroll a simple text , but a long text , what is writing in a 24FC512 menory . It has pins 1,2,3,4 and 7 to ground .
    'set these variable
    What doing this ?
    I use a long text ......with caps.letters only ( you can see this in my programe ).
    Celsius[0]=84 = T
    Celsius[1]=101 = e
    Celsius[2]=109 = m
    Celsius[3]=112 = p
    Celsius[4]=101 = e
    Celsius[5]=114 = r
    Celsius[6]=97 = a
    Celsius[7]=116 = t
    Celsius[8]=117 =u
    Celsius[9]=114 =r
    Celsius[10]=32 = blank
    Celsius[11]=105 = i
    Celsius[12]=115 = s
    Celsius[13]=32 = blank
    Celsius[14]=0 this is not 0
    Celsius[15]=44 = ,
    Celsius[16]=0
    write:
    adr=0
    PAUSE 10
    Look back in message , I must to use only this formula , only one .
    I2Cread I2CDAT , I2CCLK , $A0 , J ,[caracter]
    adr=0
    Pause 10
    For A0=0 to 16
    Next A0
    Thank you !
    Red face
    Either there is still a serious language barrier here or you're not getting what we're trying to say... In either case, I wish I spoke whatever language you speak so we could get this all straightened out a lot faster...
    And is it working the way you want it to work?
    What doing this ?
    Shouldn't have to use 2 different 'codes' for reading and writing to an I2C eeprom. PBP handles the Read/Write bit (bit0 in the 'code') for you. Should only need to use $A0 when addressing a standard 24xxxxx serial eeprom.
    I use a long text....with caps.letters only (you can see this in my programe)
    Are you storing the entire string, along with the temperature data in the eeprom or just the temperature?
    That may be so, but to store a temperature, with a whole part and a fractional part, along with any other characters, you are going to need more than one byte of storage and will need more than one I2CWRITE command...
    Nov 2007
    skimask;64321 Either there is still a serious language barrier here or you're not getting what we're trying to say... In either case, I wish I spoke whatever language you speak so we could get this all straightened out a lot faster...
    I am from Bucharest , ROMANIA .
    It work OK with a simle text . But I wish to add in the fututre more options such : temperature out , temperature in house , time , date ...
    Of course , I use this " $A0 "
    I wish to store only result ( I think that I understand exactly what you say ??)
    Is not important how many I2Cwrite command will be use ,if PIC16F876 support lenght of code . Important is to can used only one command I2Cread to read all - text and data -
    Those 2 comments contradict themselves...
    -----Is not important how many I2CWRITE command will be use, if PIC support length of code----
    Tells me that you can use I2CWRITE as many times as you need as long as the PIC has enough code space left...
    ----Important is to can used only one command I2CREAD to read all - text and data -----
    Tells me that you MUST read everything you write with one single command.
    Which one is it?
    Nov 2007
    It's true .
    And this is true .
    Which one is it?
    Is not a contradict . I write in memory at diversely address and time sequents, and read all address once .
    Ok, so if I am to understand this correctly, at the moment, you have:
    A PIC
    A one-wire temp sensor (model number???)
    A 24FC512 serial eeprom
    A handful of 5x7 LED matrix display units
    An LCD for testing (not to be used in the 'final project')
    Correct so far?
    USA - Arizona
    Don't mean to jump in the middle of everything here, but let me see if I can summarize perhaps what you want to do.
    You want to write both "TEXT" and digits to the EEPROM using one (or several) I2CWRITE command; and you want to read them, again, using one I2CREAD command correct?
    If this is so, I think you really want to revisit what ARATTI said on post #32. Using the STR, [Str Celsius\32], modifier allows to access a whole string (array) which is what you want to do. Let me note though, that this would be an awfull waste of resources. Storing the numeric value in the EEPROM is good, but all additional processing and characters do not need to be on EEPROM.
    Quote Originally Posted by languer View Post
    He did mention in post #35 that he only wants to store/retrieve the temp results only, not the whole string. But I agree, he should re-visit post #32, as well as post #2, #8, #23, and #25.
    And now that he has an LCD to play with, should re-visit those posts along with trying different methods of displaying numbers on the LCD to get a good idea on how those commands and/or modifiers actually work. Then build up to displaying the results using those modifiers to a 5x7 LED matrix.
  1. I2C Master/Slave 16F88/16F767 working code
  2. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  3. HARDWARE I2C SAMPLE CODE question
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
