Ti Dac 7553
Results 1 to 6 of 6
Thread: Ti Dac 7553
    Arvada Colorado
    Default Ti Dac 7553
    I've got a big one here. I can't get the TI DAC output to change. Here is my test code:
    INTCON = %00000000 ' Enable TMR0 interrupts
    INTCON2 = %10000000 ' ENABLES PORTB PULL UPS
    'T0CON = %11010101 ' ENABLES TM0 AND SET PRESCALER
    RCON = %00000000 ' IPEN RCON.7 INTERUPT PRIORITY LEVEL DISABLED
    ADCON0 = %00000000 ' ATOD CH 4 CONVERTER ENABLED
    ADCON1 = %01111111 ' All digital = 01111111
    ADCON2 = %10000110 ' RIGHT JUST RESULT 0 TAD FOSC/64
    OSCCON = %01101101 '
    VOUTB VAR WORD
    LOOP:
    toggle porta.7
    voutb = %0011010111111011
    HIGH PORTB.5
    PAUSEUS 2
    low portb.5
    shiftout portb.3,portb.2,5,[voutb\16]
    HIGH PORTB.5
    PAUSEUS 2
    low portb.5
    pause 1
    HIGH PORTB.5
    PAUSEUS 2
    low portb.5
    HIGH PORTA.0
    PAUSE 5
    LOW PORTA.0
    pause 5
    goto loop
    PIC is running fine. 4 MHz internal clock right on time. Getting good bit stream and clock pulse.
    Problem. I cannot get pin 18 PortA.7 to toggle or respond to HIGH or LOW pin commands. I tied on a pull up resistor, now it will not go low. Either way the DAC isn't listening. Just stays at mid scale so long as the CLR not pin is low.
    Arvada Colorado
    Default Files to are helpfull
    Here is the schematic
    Arvada Colorado
    Default Dac Pdf
    Here is the spec sheet on the DAC
    http://focus.ti.com/lit/ds/symlink/dac7553.pdf
    Sorry for the hodge podge
    Default dac
    you may have to set port a.7 to output,
    just use .......
    high portA.7 .......early-on
    amgen
    Arvada Colorado
    Default Config reg 30001
    I had it set to XT instead of INTRC. I had to set it in the configuration programmer menu drop down though. I thought I had it set correctly in the code. Oh well I'll start working on getting the DAC to respond now. I'll post any problems I encounter.
    Arvada Colorado
    Default DAC port adr
    VOUTB = 1000xxxxxxxxxxxx
  1. I am confuse
    By timseven in forum mel PIC BASIC
    Last Post: - 23rd October 2009, 15:49
  2. PIC18F4525 to DAC (PCF8591P) I2CWrite too fast?
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 4th April 2008, 08:16
  3. i2c with a dac
    By fabritio in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 17:13
  4. Bluetooth wireless with PIC / HSERIN / DAC
    By rpatel in forum mel PIC BASIC Pro
    Last Post: - 20th December 2004, 22:13
  5. 10 bit pwm as dac
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 30th June 2004, 15:12
