output port issues driving LEDs
Results 1 to 7 of 7
    Dec 2006
    Default output port issues driving LEDs
    With a 16F690 and PBP, I’m having a problem driving simultaneous port outputs which are connected to LEDs via individual 2k Ohm resistors to ground.
    With this first bit of code, I can illuminate one or two LEDs as one would expect.
    Trisc = %00000000
    Portc = %00000001 ‘ lights the first LED
    Pause 1000
    Portc = %00000011 ‘ lights both LEDs
    Now, the below code SHOULD do the same thing as the above code which is
    light the first LED then light the second LED while not turning off the first LED.
    Nope, the first LED gets extinguished.
    Trisc = %00000000
    Portc.0 = 1 ‘ lights the first LED
    Pause 1000
    Portc.1 = 1 ‘ the first LED goes dark and the second LED lights!!!!
    I have found some other older posts that talk of this same issue but they were running several LEDs with one dropping resistor which turned out to be their problem.
    I have a separate resistor for each LED.
    HELP!
    Bob
    May I suggest that 2K ohms is way to high a value? Use something more like 300 ohms.
    Quote Originally Posted by p15218 View Post
    Pause 1000
    It's the never ending problem.
    OK well, it will end for you when you add this to your program ...
    ANSEL = 0
    But for us, it will never end. The word will never get out. "Turn off the Analog ports".
    Microchip is a cruel vicious company bent on driving us crazy by ENABLING analog functions by defualt.<hr>
    Sorry, I was watching the political convention on Tivo and felt like being over-dramatic for no reason at all.
    Yes, but has anyone noticed that they're not even sensibly enabled 'by default'? Posted by videophone onto a big screen from the back of a dodgy hotelroom in Kansas).
    FYI: The reason this happens;
    Pause 1000
    is because you're using a read-modify-write type command with Portc.0=1
    so when the PortC is read on the 2nd Portc.1=1, Portc.0 is read again, and
    it's read as zero, since A/D is enabled, so it goes low on the next port bit
    change.
    Melanie: What the heck are you doing in Kansas...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2006
    Del Rio, TX, USA
    What I don't understand is: Why do so many people miss this? Thinking back to my PIC infancy, it is this very thing which I can recall learning. The first step in any program. Setting up the ports to work they way I want. Analog, Digital, Input, Output, Pull-up, CCP, .... Whatever. It's plastered everywhere! I could hardly read a post, manual, datasheet, PIC book, etc. without seeing this problem and the solution.
    I'm done. Stepping down. Deep breath.
    SteveB
    No, not in Kansas... I was just making fun of the convention following Darrels comment... though I was in Southern California for a short while a month back... baby-sitting of all things - Don't ask!!!
  1. Microcontroller with 2 way paging application problem
  2. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  3. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  4. Port A Issues
    Last Post: - 21st June 2005, 21:07
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
