Char. LCD and 18F452 on 20 MHz not work
Results 1 to 12 of 12
    Jul 2008
    Default Char. LCD and 18F452 on 20 MHz not work
    Char. LCD and 18F452 on 4 MHz working, but on 20 MHz not work.
    Please help me.
    define LCD_BITS 4
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 6
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 7
    DEFINE LCD_LINES 4
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    LCDOUT $FE,1,"HELLO WORLD"
    Did you tell PBP that you are using 20 mhz
    DEFINE OSC 20
    Jul 2008
    DEFINE OSC 20
    Yes mackrackit.
    And OSC = HS
    But PBP not compile 18f452 to hex, MPASM compiling to hex. And MPASM compiling on (default) 4 MHz only.
    Quote Originally Posted by samettin View Post
    Yes mackrackit.
    MPASM is required for 18s.
    How do you know it is doing 4 MHz? Did you change the congig (*.inc) to HS?
    Jul 2008
    I m sorry, i changed my message
    I did change OSC to HS.
    LCD vorking with 18F452 on 4 MHz xtal and osc config = XT.
    Problem is, if PLL enable with 4 MHz XTAL, or 20 MHz with osc config=HS then.
    Could you post all of the code and config, not what you think the configs are set for, but a copy paste of the *.inc.
    Might want to also keep in mind that the PLL doesn't work above 10Mhz. The max speed of the PIC is 40Mhz (10 x 4xPLL). Try as you might, you won't get the PIC to run at 160Mhz! (It would be nice, but it won't work )
    Jul 2008
    My english is bad, sorry
    With this code problem is finish.
    Xtal = 20 MHz
    Osc Config = HS
    Need first code:
    LCDOUT $FE,1
    after initialising lcd:
    But PAUSE and PAUSEUS working at value/5.
    Example:
    PAUSE 5000
    working to 1 Second.
    I edited in "pbppic18.lib" also PAUSE problem is finish.
    with 4 MHz xtal pauseus macro.
    ;* PAUSEUS    : Pause n microseconds at 4MHz                    *
    ;* Input      : R0 + 1, W = microseconds                        *
    ;* Output     : None                                            *
    ;* Notes      : minimum 19us                                    *
          if (OSC == 4)
      LIST
    PAUSEUS clrf	R0 + 1		; 1
    PAUSEUSL addlw	-23		; 1 Subtract overhead
                 movwf   R0                        ; 1
    	movlw	-4		; ********changed -1 to -4***********
    	bnc	pauseush	             ; 1 / 2
    	nop			; 1
    pauseusloop CLRWDT?NOP		; 1
    	addwf	R0, F		; 1
    	bc	pauseusloop	; 1 / 2
    	nop			; 1
    pauseush addwf	R0, F		; 1
    	decf	R0 + 1, F	; 1
    	btfsc	R0, 0		; 1 / 2
    	bra	$ + 2		; 2 / 0
    	btfss	R0, 1		; 1 / 2
    	bra	pauseusdone	; 2 / 0
    	bra	$ + 2		; 0 / 2
    	nop			; 0 / 1
    pauseusdone return		; 2 + 3 (call + setup)
      NOLIST
    Thanks for your interesting.
    Best regards.
    Jul 2008
    160Mhz?
    Sorry i dont see.
    With 4 MHz and PLL 4X4 = 16 MHz.
    20 MHz is without PLL. This osc conf. is XT.
    160Mhz?
    Sorry i dont see.
    Thought you said it was set for HS. XT will not work. Me thinks.
    It's good enough. Don't worry about it...
    Not understanding this statement.
    Problem or No Problem?
    Example:
    PAUSE 5000
    Which leads me to believe that either you config statements are 'taking effect' or your PIC is actually running on the internal 4Mhz clock vs. the external 20Mhz oscillator.
    Jul 2008
    No problem
  1. 18F452 and 8-bit LCD
    By exelanoz in forum mel PIC BASIC Pro
    Last Post: - 15th December 2009, 07:57
  2. with 40 MHZ osc serin2 not work
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 13th August 2006, 22:56
  3. Replies: 5
    Last Post: - 5th February 2006, 16:51
  4. How do I get DATA @ to work with a 18F452?
    Last Post: - 2nd February 2006, 10:35
  5. Why doesn't my code for 18f452 work on 18f252?
    By senojlr in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2005, 02:42
