Oscillator stops when touching with a wire
Results 1 to 24 of 24
    Default Oscillator stops when touching with a wire
    Good evening all,
    I've made a RS485 network of 16 remote devices (16F886) and 1 master (18F2620) all running Picbasic pro. Everything runs perfectly, however, when i touch the ground or one of the inputs with a non connected wire (to connect an input with the ground for example), the clock stops running (wire is only connected on one side).
    I've tried to change the capacitors of the xtal (changed it between 15pf and 22pf) but the result remains the same.
    PIC's are configured in HS mode.
    Any ideas how to solve this?
    Many thanks !!
    Wilbert
    Quote Originally Posted by Wilbert Ingels View Post
    Good evening all,
    Many thanks !!
    Wilbert
    How about decent cap's across Vdd and Vss?
    Do you have a pull up on MCLR?
    AND
    1.make sure LVP is set to OFF on both
    2.make sure ALL Vss & Vdd are connected.
    If both run @5V, it shouldn't be a Brown-Out reset or... sort of.
    Thanks for the replies !
    Just to come back on the below feedback:
    - Caps are used to stabilize power supply (100nf and 10mf) and also every PIC has a 100nf cap on the power supply pin
    - MCLR has a pull-up resistor
    - LVP set to off
    Other ideas what it could be?
    I can post the network drawing (Eagle file) but i'm not sure if i can attach files ...
    Many thanks for helping me with this !!
    Wilbert
    Also the 2 VSS pins are connected ...
    How good / stable is you power supply?
    Some additional information:
    - The processor doesn't reset but stops in my opinion. I've used debug information on a serial port. On each startup, an appropriate message is sent (which i don't receive when this problem occurs). I'm also displaying variables and when the processor continues, he still has the right values.
    - Most of the cases, information on the RS485 network triggers the processor to continue.
    Dave,
    Good point, it's a lab power supply so i didn't had any doubt about it ... I'm going to check it now !
    Thanks !
    Wilbert
    And how is the brown out fuse set?
    Checked Power supply -> OK
    Added additional caps -> problem remains
    Changed Power supply -> problem remains
    Changed cables -> problem remains
    Even when i touch VDD with a none connected cable (15 cm), i see the clock stopping on multiple processors ...
    Configuration bits:
    device pic16F886, hs_osc, wdt_on, mclr_on, lvp_off, protect_off, cpd_on
    Bombay, India
    Hello Wilbert
    I wonder if you have a firmware issue here. Have you handled the case when the data stream is corrupted? Perhaps your firmware is hanging on data corruption. The symptoms you describe could be due to this.
    Jerson
    Hello Jerson,
    My first impression was also having a firmware issue. So i made a modification of the firmware so the only thing the controller is doing is listening to the RS485 bus and every 250ms reading PORTC of the controller when i put the controller in initialization mode through the RS485 bus. Every time he checks PORTC, a led flashes. This works perfectly, he read and understand commands from the RS485 bus, the led flashes but when i touch the ground with a non connected wire, the led stop flashing. When i connect a fixed wire to the ground, every thing works fine and the clock doesn't stop touching inputs ...
    So now i made a second modification, only a flashing led, and guess what, the clock doesn't stop what makes me think again something is wrong in my code ...
    This is my code:
    '* Name : Module_O *
    '* Author : Wilbert Ingels *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 19/11/2007 *
    '* Version : 1.0 *
    '* Notes : New Hardware 16F886 *
    'include "modedefs.bas"
    DEFINE OSC 20
    'define I2C_SLOW 1
    'TRISC = %11111111 'PORTC is an input
    TRISB = %11111111
    TRISA = %11111111
    CCP1CON = 0 ' DISABLE CAPTURE COMPARE MODULE
    ADCON1 = 15
    'CMCON = 7
    ANSEL=0
    ANSELH=0
    'OSCCON = %01110111
    data @0,"3","8","4","I","E" ' Device address
    define DEBUG_REG PORTA
    define DEBUG_BIT 1
    define DEBUG_BAUD 115200
    define DEBUG_MODE 0
    define DEBUGIN_REG PORTA
    define DEBUGIN_BIT 1
    define DEBUGIN_MODE 0
    'Variables and constants
    TxD var PORTA.3 ' Transmit pin RS232
    RxD var PORTA.2 ' Receive pin RS232
    command var byte ' Storage for command
    i var byte ' Storage for loop counter
    temp var word ' Storage for temperature
    DQ var PORTC.0 ' Alias DS1820 data pin
    DQ_DIR var TRISC.0 ' Alias DS1820 data direction pin
    RS485_mode var PORTA.0 ' Mode for RS485 chip (send or receive)
    RS485_SR var PORTA.1 ' RS485 send/receive pin
    led_blue var PORTA.5
    onewire var PORTB.4
    RS9600 con 84
    RS19200 con 16416
    Buffer_size2 con 6 'Number of bytes received from RS485 bus
    RS485string var byte(buffer_size2)
    Module_ID var Byte(4)
    x var byte
    y var byte
    z var byte
    u var byte
    v var byte
    s1 var byte
    s2 var byte
    w1 var word
    mode var byte 'L->Live Mode,I->Initialization mode
    mode_ID var byte 'N->New module,E->Existing module
    sda var PORTB.0 ' I2C bus
    rcl var PORTB.1
    'Initialization
    mode = "L" 'mode="L" -> live mode, mode="I" -> initialization mode
    input Rxd 'RxD RS232 is an input
    low RS485_mode 'RS485 receive mode
    low PORTA.4 'Second pin of the blue led
    read 4,mode_id 'Mode_ID
    read 3,x
    read 2,y
    read 1,z
    read 0,u
    if mode_id<>"E" then 'ID is new and must be generated
    gosub test_module_type
    mode_id="N"
    for i=0 to 2
    random w1 'generate random ID
    if w1.byte0<>255 and w1.byte0<>0 then 'Random value if ok
    module_id[i]=w1.byte0
    else 'Random value is not ok
    Module_id[i]=171 'Random value (My bithday )
    next i
    serout2 TxD,RS19200,[13,10,"New Module ID: ",dec module_id[0]," ",dec module_id[1]," ",dec module_id[2]," ",module_id[3]," ",mode_id,13,10]
    else 'It's an existing ID
    Module_ID[3] = x 'copy ID from Eeprom into RAM
    Module_ID[2] = y
    Module_ID[1] = z
    Module_ID[0] = u
    serout2 TxD,RS19200,[13,10,"Startup ",Module_id[3],y,z,u,13,10]
    'Start Main Routine
    loop:
    if mode="L" then 'bus is in Live mode
    gosub rs485_receive
    if mode="I" then 'bus is in Initialization mode
    gosub rs485_receive_init 'check if broadcast messages are received
    gosub check_inputs 'during initialization, inputs needs to be checked
    goto loop
    'Subroutines
    ' Test which type of module it is
    test_module_type:
    input PORTB.0
    input PORTB.1
    if PORTC=255 then 'intput module
    'serout2 TxD,RS19200,[13,10,"I'm an input module ",13,10]
    Module_ID[3] = "I"
    else 'output module
    if PORTB.0=1 and PORTB.1=1 then 'then i'm an output module
    'serout2 TxD,RS19200,[13,10,"I'm an output module ",13,10]
    TRISC = %00000000 'PORTC is an output
    PORTC=0
    i2cwrite sda,rcl,%01000000,0,[0],module_error
    'serout2 TxD,RS19200,[" and I've Dimmer functionality ",13,10]
    Module_ID[3] = "D"
    goto end_module
    module_error:
    'serout2 TxD,RS19200,[" and I've Relais functionality ",13,10]
    Module_ID[3] = "O"
    end_module:
    'serout2 TxD,RS19200,[13,10,"Undefined module (B0 and B1 <>1, C<>255) ",13,10]
    x=255 'module is invalid
    ' RS485
    rs485_receive: 'receive routine when in Live mode
    low RS485_mode 'receive mode
    debugin [WAIT("ST"),rs485string[5],rs485string[4],rs485string[3],rs485string[2],rs485string[1],RS485string[0]] 'wait untill a message comes in starting with "ST"
    'serout2 TxD,RS19200,[DEC rs485string[5]," ",dec rs485string[4]," ",dec rs485string[3]," ",dec rs485string[2]," ",dec rs485string[1],13,10]
    if rs485string[5]=Module_id[3] and rs485string[4]=Module_id[2] and rs485string[3]=Module_id[1] and rs485string[2]=Module_id[0] then 'message is for this module
    if Module_id[3]="I" then 'input module
    if RS485string[1]="I" then 'instruction read inputs is received
    high led_blue
    y=PORTC
    pause 4
    s1=y
    s2=0
    gosub rs485_send
    low led_blue
    if module_id[3]="D" or module_id[3]="O" then 'output module
    PORTC = rs485string[1]
    high led_blue
    pause 4
    s1="K"
    s2=0
    gosub rs485_send
    low led_blue
    if rs485string[5]=0 and rs485string[4]=0 and rs485string[3]=0 and rs485string[2]=0 then 'broadcast message is received
    'serout2 TxD,RS19200,["Data received L ",RS485string[0],RS485string[1],13,10]
    Gosub check_init
    rs485_send:
    high RS485_mode 'send mode
    debug Module_ID[3],Module_ID[2],Module_ID[1],Module_ID[0],s1,s2
    rs485_receive_init: 'recive routine when in initialization mode
    debugin 250,rs485_cont,[WAIT("ST"),rs485string[5],rs485string[4],rs485string[3],rs485string[2],rs485string[1],RS485string[0]] 'wait untill a message comes in starting with "ST"
    'serout2 TxD,RS19200,["Data received I ",RS485string[0],RS485string[1],13,10]
    'serout2 TxD,RS19200,["Broadcast received ",RS485string[0],RS485string[1],13,10]
    gosub check_init
    goto init_end
    rs485_cont:
    'here code when timeout
    init_end:
    check_init:
    if rs485string[1]="I" and rs485string[0]="I" then 'initialization mode activated
    mode="I" 'main routine will do a different loop
    high led_blue
    serout2 TxD,RS19200,[13,10,"Init mode ",mode,13,10]
    if rs485string[1]="L" and rs485string[0]="L" then 'live mode activated
    mode="L" 'main routine will do a different loop
    low led_blue
    serout2 TxD,RS19200,[13,10,"Live mode ",mode,13,10]
    check_inputs: 'during initialization, inputs needs to be checked
    if module_id[3]="I" then 'Module is an input Module
    low led_blue
    serout2 TxD,RS19200,["Check inputs ",mode,13,10]
    x=PORTC
    if x<>255 then 'Input button is pressed
    s1=x
    s2=mode_id 'E->existing,N->New
    gosub rs485_send
    serout2 TxD,RS19200,["RS485send ",13,10]
    if module_id[3]="D" or module_id[3]="O" then 'Output module (Dimmer or digital Output)
    x=PORTB.2
    if x=0 then 'initialization button is pressed
    s1=0
    gosub rs485_send
    high led_blue
    Dave,
    You're right, it is a firmware problem. The clock is not stopping but following is happening:
    This is the instruction causing problems:
    debugin 50,rs485_cont,[WAIT("ST"),rs485string[5],rs485string[4],rs485string[3],rs485string[2],rs485string[1],RS485string[0]]
    When a not connected wire is touched to one of the connection, a small spike is generated on the RS485 bus. This what i think that happens than: The Debugin receives 1 bit and is endless waiting for the other bits to come. I've the impression that the timeout only works if a full byte is received.
    Is my statement correct? How can this be resolved?
    Many thanks !
    Bombay, India
    Wilbert
    Good snooping. The glitch is causing your firmware NOT to see the ST sequence. So, you go on waiting till you catch it .... and guess what -- it doesnt come again!
    A better technique would be to
    1. Wait for byte1=S
    2. Wait for byte2=T
    3. Process packet
    I hope you can fix this yourself.
    Jerson
    in the 485_receive part of your code you have a debugin without a wait value. I would put timeouts in all your serial communication calls just to be safe.
    Another thing you can do is output some debug messages to the serial port showing where the program is. Once it locks up you can look at the last message and see where the code was when it died.
    Tim Barr
    Hi Tim and Jerson,
    I'm working in 2 modes: Live mode and initialization mode. In live mode, the processor will wait endless untill he receives "ST" with instructions from the bus master. In initialization mode, he will look at his inputs and also looks if broadcast information is received on his RS485 bus.
    I've tried your suggestions but he's still going into a endless loop when a spike arrived on the bus. It looks like when one bit arrives, the timeout value doesn't count untill a full byte is arrived. He only succeed to release (via timeout) when information flows again on the RS485 bus (and bytes are being received).
    It seems that timeout only works when full bytes arrives. If a single bit (spike) arrives on the RS485 network, the debugin timeout statement is not working ...
    Does serin2 works different than Debugin (-> timeout bit versus byte)?
    Any other suggestions?
    Many thanks guys !!
    Wilbert
    Why not "SERIN" all of your characters into a 'sliding buffer string' and keep that in a tight loop. You can keep track of it and keep checking if the beginning of that 'sliding buffer string' contains the "ST" that you're looking for. When it does, you save the data and act on it accordingly.
    That way, you should be able to avoid the timeout and glitch problems that you're having.
    I thought I had a good idea for you...lost it...can't find it again
    Hey Skimask,
    Thanks for your reply !
    I'm still struggling how to do it. If i use a tight loop with timeout which receives character by character, i'm afraid if only one bit is send (my famous glitch ), the timeout statement won't work and the endless loop will start (untill additional information is received)
    I'm going to try it and will keep you in touch. If you remember you other suggestion, you're more than welcome
    Take care
    Wilbert
    If i look in the manuel on page 135 (serin2) "if the serial input pin stays in the idle state during the timeout time, the program will exit the SERIN2 command and jump to label". In my case, the input pin doesn't stay idle because it received one glitch ...
    Same for Debugin on page 58 ...
    Hum, i don't see it yet how i can solve it
    Pull-up or pull-down resistor is an easy to test Solution?
    Sep 2003
    Vermont
    It sounds like static electricity is the culprit here. I understand touching an input, but the ground should be somewhat immune to the phenomena. It sounds like there is a ground loop in the connections. Look for multiple lines connected to ground in the same run of cable. Touching one will cause an imbalance. So if the shield is connected to ground, and another line in the cable is, this could cause a problem. The simplest fix is to not connect the shield on one end of the cable. While it sounds counter intuitive, it might be the cause, or one of them.
    Ron
    The fix might be something as simple as:
    loop:
    datagood = 0
    SERIN2 (((your code here with the shortest timeout possible, timeoutlabel, etc.etc....)))
    datagood = 1
    goto overtimeoutlabel
    timeoutlabel: if datagood = 0 then goto loop  'data was bad, try again
    overtimeoutlabel: continue code here....
    if it does glitch, you check 'datagood'. If datagood is 0, then it glitched or didn't receive what you wanted and try again
    Aside from that, I agree with the other guys, ya gotta find the root cause of the glitches...
    Hey Guys,
    Thanks for the feedback !
    Yesterday, i've changed the RS485 chips. I was using SN75176 and i've changed them for MAX481 and the glitched are gone. It seems that SN75176 is more sensible and thus in my case less usable in my application. The MAX481 untill now never gave one glitch. I'm working now on the timing aspects because these seems different between SN75176 and MAX481.
    I've also went into more detail in how PBP works. I understand the little drawbacks (in terms of serial communication) of the language better now but i must say that, the longer i work with PBP, the more enthusiastic i am. It is a great language and a fantastic tool.
    Take care
    Wilbert
  1. 1 Wire Search Routine
    By Dave in forum Code Examples
    Last Post: - 4th March 2016, 07:39
  2. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 02:30
  3. 24c16 vs 24lc256 and serial wire identification
    By inspired4real in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 17:37
  4. Looking for low Wattage heater wire
    By jmgelba in forum Off Topic
    Last Post: - 21st November 2005, 18:22
  5. RPM with wire and PIC
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 14th December 2004, 20:42
