A help with Write/Read a I2C memory
Results 1 to 26 of 26
    Nov 2007
    Default A help with Write/Read a I2C memory
    Hello !
    My name is Eugen , from Romania - Bucharest . I am a new in use PBP . Please help me to know where I wrong . I have a Pic16F877 , and I wish to write a one or two texts as connstant , and variables as hours , minutes , seconds (these are not writes in my example), on a I2C memory type 24FC512 ,Read memory and display on a LCD with 2X16 lines:
    define LOADER_USED 1
    define OSC 4
    INCLUDE "Modedefs.bas"
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    SDA VAR PORTC.4
    SCL VAR PORTC.3
    J var word
    i var word
    c var byte
    I=0
    J=0
    ADCON1 = 7
    TRISB = 0
    start:
    DISABLE INTERRUPT
    FOR i = 0 TO 20
    I2cwrite SDA, SCL,$A0,I,["TEXT1",VARIABILA1,"TEXT2",VARIABILA2]
    pause 30
    NEXT i
    for J = 0 to 20
    i2cread SDA, SCL,$A0,J,[C]
    pause 30
    lcdout $FE,1
    LCDOUT $FE,$80,"INCERCARI"
    LCDOUT $FE,$C0+j ,c
    pause 400
    next J
    pause 400
    Enable
    goto start
    Thenk you very much !
    Mar 2008
    Texas, USA
    Instead of "TEXT1", use [#T,#E,#X,#T,#1...etc]
    Don't overwrite your buffer.
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Nov 2007
    Quote Originally Posted by JD123 View Post
    Do not work .
    "I2cwrite SDA, SCL,$A0,I,[#T,#E,#X,#T,# ]" = "bad expression "
    Thanks !
    Mar 2008
    Texas, USA
    Oops, my bad... that's for serial stuff.
    Try:
    text var byte[5]
    test[4] = "T"
    test[3] = "E"
    test[2] = "X"
    test[1] = "T"
    test[0] = "1"
    I2cwrite SDA, SCL,$A0,I,[char test\5, {your other data to send} ]
    I don't know if the array is sent out lowest ([0]) or highest ([4]) first. Reverse array asignments if it comes out backwards.
    I2cwrite SDA, SCL,$A0,I,[ "T" , "E" , "X" , "T" , "1" ].....
    should also work. (not 100% sure, haven't tried myself, but it should work)
    What you originally had was an embedded string, which PBP doesn't natively handle. ( "TEXT1" ). A byte array of characters as noted in the post preceeding can be used as a string, but is not really a 'string' as far as PBP is concerned.
    Nov 2007
    I have tried again , and in other kinds , and do not work .
    Nov 2007
    [QUOTE=skimask;53213]I2cwrite SDA, SCL,$A0,I,[ "T" , "E" , "X" , "T" , "1" ].....
    What you originally had was an embedded string, which PBP doesn't natively handle. ( "TEXT1" ). A byte array of characters as noted in the post preceeding can be used as a string, but is not really a 'string' as far as PBP is concerned.[/QUOTE
    I used this and not work .Read and display step by step only " T " ,first karakter .
    test var byte[5]
    test[4] = "T"
    test[3] = "E"
    test[2] = "X"
    test[1] = "T"
    test[0] = "1"
    ADCON1 = 7
    TRISB = 0
    TRISC = 0
    start:
    DISABLE INTERRUPT
    scriere:
    FOR i = 1 TO 20
    I2cwrite SDA, SCL,$A0,I,["T","E","S","T","1"]
    pause 30
    NEXT i
    Quote Originally Posted by Eugeniu View Post
    Well, that code isn't going to work in a loop like that. Why would it?
    Get rid of the loop on the write.
    Hi, something like the following will work.
            EEP1    con %10100000 ' First EEPROM A<2:0>=Gnd
            Addr    var word
            ByteA   var byte
            ByteB   var byte
            PAUSE 50
                addr=0
                BYTEA="A"
                byteb="B"
                I2CWRITE SDA,SCL,EEP1,ADDR,[bYTEA," TEXT1",BYTEB," TEXT2"]
                PAUSE 10
           FOR ADDR=0 TO 13
                I2Cread SDA,SCL,EEP1,ADDR,[bYTEA]
                hserout [BYTEA]
                next
            @ GOTO $
    in your first example, try to change to..
    <font color="#000000">        @ __CONFIG _XT_OSC &amp; _WDT_ON &amp; _PWRTE_ON &amp; _BODEN_ON &amp; _LVP_OFF
            <font color="#000080">DEFINE </font>OSC 4
            <font color="#000080">INCLUDE </font>&quot;Modedefs.bas&quot;
            <font color="#000080">DEFINE </font>LCD_DREG PORTB
            <font color="#000080">DEFINE </font>LCD_DBIT 4
            <font color="#000080">DEFINE </font>LCD_RSREG PORTB
            <font color="#000080">DEFINE </font>LCD_RSBIT 3
            <font color="#000080">DEFINE </font>LCD_EREG PORTB
            <font color="#000080">DEFINE </font>LCD_EBIT 2
            SDA <font color="#000080">VAR </font>PORTC.4
            SCL <font color="#000080">VAR </font>PORTC.3
            J <font color="#000080">VAR WORD
            </font>i <font color="#000080">VAR WORD
            </font>c <font color="#000080">VAR BYTE
            </font>variabila1 <font color="#000080">VAR BYTE
            </font>variabila2 <font color="#000080">VAR BYTE
            </font>variabila1=&quot;A&quot;
            variabila2=&quot;B&quot;
            i=0
            J=0
            ADCON1 = 7
            TRISB = 0
    start:
            <font color="#000080">I2CWRITE </font>SDA, SCL,$A0,i,[&quot;TEXT1&quot;,variabila1,&quot; TEXT2&quot;,variabila2]
            <font color="#000080">LCDOUT </font>$FE,1
            <font color="#000080">LCDOUT </font>$FE,$80,&quot;INCERCARI&quot;
            <font color="#000080">LCDOUT </font>$FE,$C0
            <font color="#000080">FOR </font>J = 0 <font color="#000080">TO </font>12
                <font color="#000080">I2CREAD </font>SDA, SCL,$A0,J,[c]
                <font color="#000080">LCDOUT </font>c
                <font color="#000080">NEXT </font>J
            @   <font color="#000080">GOTO </font>$
    Nov 2007
    Write code lines please , what have you in your mind .
    Corect my lines .
    Thank you !
    Nov 2007
        lcdout $FE,1
        LCDOUT $FE,$C0
        for J = 0 to 20
            LCDOUT c
            next
    In this situation the fist karakter is write in the same place , first possition .
    no it works here, look at post #10
    Nov 2007
            @ GOTO $
    I have write your code ..and display " ATEXT1 BTEXT2 " BUT NOT ALL TOGETHER -alternately . If will be remain all karakters on the display -ALL WILL BE OK !
    Addr var word
    ByteA var byte
    ByteB var byte
    PAUSE 50
    addr=0
    BYTEA="A"
    byteb="B"
    I2CWRITE SDA,SCL,$A0,ADDR,[bYTEA," TEXT1",BYTEB," TEXT2"]
    PAUSE 10
    reading:
    FOR ADDR=0 TO 13
    I2Cread SDA,SCL,$A0,ADDR,[bYTEA]
    lcdout $FE,1
    LCDOUT $FE,$C0+addr ,ByteA ' HERE I WRITE " +ADDR " BECOSE HE WRITE IN THE SAME PLACE
    pause 300
    next
    pause 400
    Enable
    goto scriere
    POST #10, not #9
    anyways, look what your actual code do...
    FOR ADDR=0 TO 13
    lcdout $FE,1  ' it always clear your LCD and return to home
    LCDOUT $FE,$80,"INCERCARI" ' it always draw this line
    LCDOUT $FE,$C0+addr ,ByteA '  and finally here, it will only draw a single character, because you ALWAYS clear the WHOLE lcd with $FE,1
    pause 300
    next
    hence why i've move most LCDOUT BEFORE the FOR/NEXT loop.... twice.
    Nov 2007
    POST #10, not #9
    FOR ADDR=0 TO 13
          I understand that  : in this line " byTEA is a new variable where PBP put what read at "ADDR"  I have change with "C" and is the same .
          Aha , I will delete this line !! .....and WORK !!
          yes , I wish this .
    pause 300
    next
    I understand , I have make changes in programs and now it work !
    Thank you very much for all help ! Have you only a happy days !
    Grreeeeeeeeeeeeeat! Enjoy!
    Mar 2008
    Texas, USA
    "Have you only a happy days !"
    Quote of the day.
    ah come on... read first post
    Quote Originally Posted by POST #1
    Chances are that our friend is not English, and try to do it's best... as i do each days since i'm here.... and yes i do tons of mistakes here and there, in each and every of my over 4,800 posts.
    Time to raise Melanie's post once again
    http://www.picbasic.co.uk/forum/showthread.php?t=4583
    Mar 2008
    Texas, USA
    mister-e, tong-in-cheek, you know that. I would have stuck with helping him but my job called me away. Thanks for jumping in. It's best anyway, as I'm working on alot of I2C code right now and this kind of evolved into an LCD issue, which is not in the front of my mind.
    Talking
    You just provided one example for me and probably tons of other users + spelling mistake . Tongue-in-cheek... for me, French Quebecer, it doesn't mean anything... but thanks Wikipedia...
    Tongue-in-cheek is a term that refers to a style of humour in which things are said only half seriously, or in a subtly mocking way. It is related to satire and irony.
    I learn something new everyday Thanks!
    Mar 2008
    Texas, USA
    LOL!!! "tong", I just noticed that!
    sounded more chinese to me
    ni hao!
    Nov 2007
    Apologize for my english, please ! Do not be angry .
    Eugeniu
    Don't worry Eugeniu, there's a lot of people here, including me, who aren't english. We do our best and that's it. Your question was clear enough for me.
    Don't be afraid and don't give up!
    Nov 2007
    Thank you , again ! My misyakes was very simple , for others , that "COLUMB EGG " but , I have lost a day , and my mind and eyes do not want to see they .
  1. I2C Master/Slave 16F88/16F767 working code
  2. HARDWARE I2C SAMPLE CODE question
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  4. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 13:55
  5. I need help with i2c memory
    By -c3- in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 19:57
