Multiple if then optimization
Results 1 to 36 of 36
    Jan 2008
    Selm, Germany
    Wink Multiple if then optimization
    Hi Gurus of Picland,
    Iīm building a Lambdatester that flattens somewhat out the hard jump in output voltage between lean and rich.
    wrote a code that works. Fine, and fast enough because theres hardly need for speed.
    Way of simple code for Picdummies like me .
    But if an oldschool mechanic like me looks at it even he knows that theres plenty room for codesaving.
    You Gurus fall down your chairs laughing and crying at the same time, I know.
    '* Name : Analogbargraph1(16F628A).BAS *
    '* Author : M.David *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 28.02.2008 *
    '* Version : 1.0 *
    '* Notes : needs 12F675 for Lambdatesting device and LCD 1X16 *
    '* : input 0.1 - 1.1 Volts in GPIO.0 *
    '* : needs ADCserout(12F675).bas *
    ' DEFINITIONS
    @__config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    Include "modedefs.bas"
    CMCON=%00000111
    Uin var word
    B0 VAR word ' Cnt is a word variable
    inputData var word ' variable to receive data into
    ' START OF MAIN PROGRAM
    CMCON = 7 ' RA0-RA3 are digital I/O
    TRISA = 0 ' PORT A is output
    TRISB = 1 ' RB0 is Input others output
    Serin PORTB.0,N2400,B0
    B0 = 100 * B0
    Uin = B0 / 207
    gosub bargraph
    Pause 5
    bargraph:
    if Uin < 10 then LCDOUT $FE,1,"TOO LOW"
    if (Uin > 10) and (Uin <= 15 ) then
    LCDOUT $FE,1,255
    if (Uin > 15) and (Uin <= 19 ) then
    LCDOUT $FE,1,255,255
    if (Uin > 19) and (Uin <= 24 ) then
    LCDOUT $FE,1,255,255,255
    if (Uin > 24) and (Uin <= 29 ) then
    LCDOUT $FE,1,255,255,255,255
    if (Uin > 29) and (Uin <= 34 ) then
    LCDOUT $FE,1,255,255,255,255,255
    if (Uin > 34) and (Uin <= 43 ) then
    LCDOUT $FE,1,255,255,255,255,255,255
    if (Uin > 43) and (Uin <= 53 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255
    if (Uin > 53) and (Uin <= 62 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255
    if (Uin > 62) and (Uin <= 72 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255
    if (Uin > 72) and (Uin <= 81 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255
    if (Uin > 81) and (Uin <= 86 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255
    if (Uin > 86) and (Uin <= 91 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255
    if (Uin > 91) and (Uin <= 96 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255,255
    if (Uin > 96) and (Uin <= 100 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255,255,255
    if (Uin > 100) and(Uin <= 105 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255,255,255,255
    if (Uin > 105) and(Uin <= 110 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255,255,255,255,255
    if Uin > 110 then
    LCDOUT $FE,$C0,"TOO RICH"
    END ' End of program
    on the other hand it works and shows how good and fast the combination of pics and PBP works.
    Any Ideas? maybe case select or lookdown or whatever?
    sincerely
    Mugel
    The Obvious Command is ... SELECT CASE
    Note here you check Twice your values ... a better test arrangement looks like :
    IF Value < 19
    IF Value < 24
    IF Value < 29
    also can be used ...
    IF Value < 10 THEN LCDOUT $FE, 1, "TOO LOW"
    LOOKDOWN2 Value , < ,[ 10,15,19,24,29, ....], NbPatterns
    LCDOUT $FE, 1, REP 255\ NbPatterns
    Which is ... Somewhat shorter ( from the listing point of view ...)
    North Norfolk UK
    hi Mugel,
    I don't know where all the gurus are today, but in thier absence I glanced at your post and thought you might like to take a look at the >select case< command. As all your conditions are sequentially discrete then this might be worth considering.
    The trouble with long lists of if..thens are that once the condition is met (let say at the begginning of the list) then the program continues to chunder through all the remaining if...thens, whereas select case will exit at >end case< once the condition is met. Be careful though if your conditions are not discrete ,then you will have to arrange the cases in order of preference.
    As to code space, I cannot remember but you could quickly swap the code over and see which is smaller.
    Duncan
    Sep 2007
    USA, CA
    Quote Originally Posted by duncan303 View Post
    The trouble with long lists of if..thens are that once the condition is met (let say at the beginning of the list) then the program continues to chunder through all the remaining if...thens, whereas select case will exit at >end case< once the condition is met. Be careful though if your conditions are not discrete ,then you will have to arrange the cases in order of preference.
    Duncan
    The way around this is to nest them, and put the largest value at the top. For instance, instead of this...
    if a < 5 then...
    endif...
    if a < 10 then...
    endif...
    You do this for nesting:
    if a < 10 then
    if a < 5 then
    code here...
    code here...
    or this for simple and fast testing:
    if a < 10 then
    code here...
    goto SkipTests
    if a < 5
    code here...
    SkipTests:
    Using this method skips all of the IF's if the most extreme condition isn't true. All of this depends upon the assumption that the value of "a" isn't changed within any of the conditional statements.
    Default 1 old mechanic to another
    Hi Mugelpower,
    Have you tried Darrel's Bargraph routine?
    http://www.picbasic.co.uk/forum/showthread.php?t=2359
    North Norfolk UK
    Quote Originally Posted by tenaja View Post
    I am curious if this would compile with the list that Mugel has created, some 20 nested if…then...Else’s on a 16F device?
    Duncan
    Sep 2007
    USA, CA
    It should. I believe it just uses goto's, no stack use.
    Jan 2008
    Selm, Germany
    Cool 20 if then
    yes the 20 if then work, no problem. Assembling took maybe 3 times longer then those blinky codes and it uses nearly 3/5 of the code space in my 16F628..but works flawlessly.
    to Joe:
    oh man I tried to use DTs bargraph routines but only got the error "coulndīt open bargraph.bas" or something. Copied it in a "dozen" directories around the main PBP main and my project directories...didnīt work, always the same error.
    But I uses DTs instant interrupt blinky program and that worked....so I donīt know a bone about how to work around "include" problems.
    On the other my bargraph is quite crude with its big bars....but a fine bargraph isnīt an option here...way to hard to see while driving the car or bike, you need only sort of lean/rich tendencies and the lambda sensor it VERY jumpy around the stochiometric area.
    8 leds would do but I did it mainly because of 3 reasons:
    1.: I COULD do it.......with a little help of my friends....greetings to you all!
    2.: One of my employees is sort of colour blind and wanted something to recocnize
    without colours.
    3.: we do a lot around sportscars engines and we test drive them mainly when the sun shines and a LED bargraph is hard to read while driving 100km/h in corners and the sun shining all over....
    Yeah......Iīm telling junk. Here in Germany the sunīs just a rumour you know, seen last time in june 2007 or so....
    Jan 2006
    Istanbul
    Here it is
    982 words
    <font color="#008000">@__config _XT_OSC &amp; _WDT_ON &amp; _MCLRE_ON &amp; _LVP_OFF &amp; _CP_OFF
    </font><font color="#000080"><b>INCLUDE </b></font><font color="#008000"><b>&quot;modedefs.bas&quot;
    </b></font><font color="#000080"><b>DEFINE </b></font>OSC <font color="#FF0000"><b>4
    </b></font>Uin        <font color="#000080"><b>VAR WORD
    </b></font>B0         <font color="#000080"><b>VAR WORD </b><i>' Cnt is a word variable
    </i></font>InputData  <font color="#000080"><b>VAR WORD </b><i>' variable to receive data into
    </i></font>RepNo      <font color="#000080"><b>VAR BYTE
    </b><i>' START OF MAIN PROGRAM
    </i></font>CMCON = <font color="#FF0000"><b>7 </b></font><font color="#000080"><i>' RA0-RA3 are digital I/O
    </i></font>TRISA = <font color="#FF0000"><b>0 </b></font><font color="#000080"><i>' PORT A is output
    </i></font>TRISB = <font color="#FF0000"><b>1 </b></font><font color="#000080"><i>' RB0 is Input others output
    </i></font>Main:
         <font color="#000080"><b>SERIN </b></font>PORTB.<font color="#FF0000"><b>0</b></font>,N2400,B0
         B0 = <font color="#FF0000"><b>100 </b></font>* B0
         Uin = B0 / <font color="#FF0000"><b>207
         </b></font><font color="#000080"><b>GOSUB </b></font>Bargraph
         <font color="#000080"><b>PAUSE </b></font><font color="#FF0000"><b>5
    </b></font><font color="#000080"><b>GOTO </b></font>Main
    Bargraph:
    <font color="#000080"><b>LCDOUT </b></font><font color="#FF0000"><b>$fe</b></font>,<font color="#FF0000"><b>1      </b></font><font color="#000080"><i>'Valid for all cases.
    </i><b>SELECT CASE </b></font>Uin
     <font color="#000080"><b>CASE IS </b></font>&lt; <font color="#FF0000"><b>10
          </b></font><font color="#000080"><b>LCDOUT </b></font><font color="#008000"><b>&quot;TOO LOW&quot;
     </b></font><font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>10 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>15
          </b></font>RepNo = <font color="#FF0000"><b>1
          </b></font><font color="#000080"><b>GOSUB </b></font>RepLCD
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>15 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>19
          </b></font>RepNo = <font color="#FF0000"><b>2
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>19 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>24
          </b></font>RepNo = <font color="#FF0000"><b>3
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>24 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>29
          </b></font>RepNo = <font color="#FF0000"><b>4
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>29 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>34
          </b></font>RepNo = <font color="#FF0000"><b>5
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>34 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>43
          </b></font>RepNo = <font color="#FF0000"><b>6
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>43 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>53
          </b></font>RepNo = <font color="#FF0000"><b>7
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>53 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>62
          </b></font>RepNo = <font color="#FF0000"><b>8
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>62 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>72
          <font color="#000080"><b>GOSUB </b></font>LCD2
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>72 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>81
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>81 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>86
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>86 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>91
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>91 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>96
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>96 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>100
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>100 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>105
     <font color="#000080"><b>CASE IS </b></font>&gt; <font color="#FF0000"><b>105 </b></font><font color="#000080"><b>AND IS </b></font>&lt;= <font color="#FF0000"><b>110
     <font color="#000080"><b>CASE ELSE
          LCDOUT </b></font><font color="#FF0000"><b>$FE</b></font>,<font color="#FF0000"><b>$C0</b></font>,<font color="#008000"><b>&quot;TOO RICH&quot;
    </b></font><font color="#000080"><b>END SELECT
    </b></font>RepLCD:
        <font color="#000080"><b>WHILE </b></font>RepNo &gt; <font color="#FF0000"><b>0
              </b></font><font color="#000080"><b>LCDOUT </b></font><font color="#FF0000"><b>255
              </b></font>RepNo = RepNo - <font color="#FF0000"><b>1
        </b></font><font color="#000080"><b>WEND
       </b></font><font color="#000080"><b>RETURN
    </b></font>LCD2:
        <font color="#000080"><b>LCDOUT </b></font><font color="#FF0000"><b>$FE</b></font>,<font color="#FF0000"><b>$C0
    </b></font>
    Btw:
    Select case produces 100 words more!
    So, if you go with your IF..THENs, it will be approx. 882 words, but select case provides a clean look.
    Talking ....
    Another way
    '* Version : 1.0 *
    '  569 Lines
    ' DEFINITIONS
    @      __config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    'CMCON=%00000111
    NbPatterns	var Byte
    Uin 		var word
    B0 = 100 * B0
    Uin = B0 / 207
    bargraph:
    IF Uin < 10 THEN LCDOUT $FE,1,"TOO LOW" : GOTO Show
    IF Uin > 110 THEN LCDOUT $FE,1,"TOO HIGH" : GOTO Show
    LOOKDOWN2 Uin , < [ 11,16,20,25,30,35,44,54,63], NbPatterns
    IF Uin > 62 THEN
    LOOKDOWN2 Uin , < [ 63,73,82,87,92,97,101,106,111], NbPatterns
    LCDOUT $FE, 1, REP 255\ 8
    LCDOUT $FE, $C0, REP 255\ NbPatterns
    Show:
    Pause 5
    569 Words ...
    Last edited by Acetronics2; - 3rd March 2008 at 09:51. Reason: CMCON : Double definition ....
    Jan 2008
    Selm, Germany
    Default Sting!
    Hey Girls & Guys,
    seems I poked into a bees nest.... I will try those codes in the evening (10 hrs from now).
    Youre really helpful.
    How about a code for extern interrupt that triggers a 1 ms high port after a delay found in a lookdown/case/if then row list? from 3 to 600 Hz of course......to get a constant phase shift between trigger and output.....
    Its oughta be real fast!! 20MHz 16F628A preferred
    "On interrupt" gets 180° phase shift (maximum limit) at 200 Hz.....
    I dunno how to integrate a variable delay into DTs instant interrupts....
    Smile
    Quote Originally Posted by Mugelpower View Post
    Could you explain that better ???
    You're asking for a PBP written electronic ignition here ...
    don't you think you abuse ... just a little bit !!!
    Have an eye here ... : http://a110.free.fr/SPIP172a110/arti...?id_article=23
    Ok, assembler ... but kit or scratch realizable, and the forum offers a Huge help ...
    PS: I'm working on a full PBP version ... but Assembler interrupts can't be avoided !!!
    Jan 2008
    Selm, Germany
    Red face Ignition help
    Hi Acetronics,
    yeah, in Principle thats that. BUT: thats french (ARGL-GARG!!) and I donīt understand 2% of it.
    And: I have to modify the code it myself fromtime to time which could only be done if Iīm knowing quite a lot about the code. Man, thats a BIG FISH to swallow for an oldschool mechanic. Learning programming, trying to avoid asm, learning that asm couldnīt be avoided...... ARGL-GARG !
    Wink
    Generally speaking ...
    Using PbP do not "protect" you from learning assembler ...it's a real "plus" to see the ASM result of your programming ...
    and overall understand what's really happening, and how ...
    Now about Ignition ... it's simple: you have an asm program to use with MPLAB , and a " Table generator " program ( in QBasic or, more recently EXCEL), just to load your timing values.
    So, there are special knowledge of assembler needed ...
    For French ... aha ... just think I spent a year in Berlin ( Yr 1990 ), and had to dig out my German school knowledge ... Euuuuhhhh, I'm also an old Mechanics ( and Thermics ) guy ...
    Just Follow the scheme and components list ... you'll have done 90% of the work. ... on the Forum, we ALSO Compute tables for ... how to tell it ??? .... E.T.s ?
    You also have this link ... in English :
    http://www.transmic.net/index.htm
    But ... not so good as ours ... yeah !!!
    PS for Sayzer ...: I found a Turkish > French / French > Turkish free dictionnary on the Web; I do Hope you appreciate the effort ( LoL ...)
    Jan 2008
    Selm, Germany
    Wink english link
    Hi Acetronics,
    youve been to Germany? thats been a dark time I guess.....haha.
    I already Knew the CDI transmic link but they have only the .hex file GRRRR....!
    I found this too:
    http://www.angelfire.com/ia/lfb/Pgbosch.html
    but thats way more code and unneccessary extra sparks.
    and by the way.....isnīt it more fun to get to the finish by ourselfs?
    We'll have to close this Ignition thread ... Because HS ...
    a last one ...
    http://denis.tauvel.free.fr/index.htm
    << youve been to Germany? thats been a dark time I guess.....haha. >>
    no,no ... was a wonderful year ... indeed !!! Berliners are really smart people !
    nbpatterns var byte:uin var word:cmcon=7:trisa=0:trisb=1
    main: serin portb.0,n2400,uin:uin=(uin*100)/207:lcdout $fe,1,"TOO ":if uin<10 then lcdout "LOW":goto show
    IF Uin > 110 THEN LCDOUT "HIGH": GOTO Show
    lookdown2 uin,<[11,16,20,25,30,35,44,54,63],nbpatterns:lcdout $fe,1,rep 255\nbpatterns
    if uin > 62 then
    lookdown2 uin,<[ 63,73,82,87,92,97,101,106,111], NbPatterns
    lcdout $fe,1,rep 255\ 8,$fe, $c0, rep 255\ nbpatterns
    Show:     Pause 5:goto main
    13 LINES!
    Jan 2008
    Selm, Germany
    Default code minimum
    Hi Skimask,
    yeah will try that too, never worked around the lookdown commands...will see how it works
    sincerely
    Mugel
    Talking
    13 LINES!
    Hi, Ski
    That's way too hard for my old eyes !!! Lol ...
    at second look ... I've seen that somewhere before, but Where ??? ...
    Hi, Ski
    Might even be a few words shorter on code!
    Or at least a few colons longer.
    Jan 2006
    Istanbul
    13 lines is not the case ;
    But, it is only 2 words smaller then Alain's.
    Come on Ski, saved 2 words only ???
    Quote Originally Posted by sayzer View Post
    It's monday! What'd you expect?
    Wait 'till DT comes online...
    Figure maybe down to...what...25 words total?
    Jan 2008
    Selm, Germany
    Talking Test Result
    Welcome dear ladies and gentlemen to todays code shrinking contest!
    Now I testet all 3 programms and have to tell the outcome:
    1.: Dear Mr. Sayzer, theres a small bug in your code, it shows only "Too High" or "Too Low"
    2.: Dear Mr. Acetronic: Excellent work, runs flawlessly.
    3.: Dear Mr. skimask: Full OK also !
    Applause to all three contestants.
    Besides: tons (ok kilos) of learning opportunities for me.
    Thanks you Gurus!
    Mugel
    CASE IS >19 AND IS <= 24
    Does the AND in the CASE IS actually work?
    I thought the CASE could only take one parameter to work on...
    Thanks for the vote of confidence ski.
    But sadly, all I could muster was a slim 335 words
    <font color="#000000"><b>CMCON </b>= <font color="#800000"><b>7                </b></font><font color="#0000FF"><b><i>' Disable Comparators
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>DEBUG_BAUD </b><font color="#800000"><b>2400   </b></font><font color="#0000FF"><b><i>'Debug baud rate
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>DEBUGIN_REG PORTB </b><font color="#0000FF"><b><i>'Debugin pin port
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>DEBUGIN_BIT </b><font color="#800000"><b>0     </b></font><font color="#0000FF"><b><i>'Debugin pin bit
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>DEBUGIN_MODE </b><font color="#800000"><b>1    </b></font><font color="#0000FF"><b><i>'Debugin mode: 0 = True, 1 = Inverted
    </i></b></font><b>Uin       </b><font color="#008000"><b>VAR WORD
    </b></font><b>B0        </b><font color="#008000"><b>VAR BYTE
    </b></font><b>BarCount  </b><font color="#008000"><b>VAR BYTE
    </b></font><b>BarValue  </b><font color="#008000"><b>VAR WORD
    </b></font><b>MsgAddr   </b><font color="#008000"><b>VAR WORD
    </b></font><b>Carry     </b><font color="#008000"><b>VAR </b></font><b>STATUS</b>.<font color="#800000"><b>0        </b></font><font color="#0000FF"><b><i>; Hardware carry flag
    </i></b></font><font color="#008000"><b>GOTO </b></font><b>Main                     </b><font color="#0000FF"><b><i>; Jump over data
     </i></b></font><b>BarSteps</b>:  <b>POKECODE   </b><font color="#800000"><b>10</b></font>,<font color="#800000"><b>15</b></font>,<font color="#800000"><b>19</b></font>,<font color="#800000"><b>24</b></font>,<font color="#800000"><b>29</b></font>,<font color="#800000"><b>34</b></font>,<font color="#800000"><b>43</b></font>,<font color="#800000"><b>53</b></font>,<font color="#800000"><b>62</b></font>,<font color="#800000"><b>72</b></font>,<font color="#800000"><b>81</b></font>,<font color="#800000"><b>86</b></font>,<font color="#800000"><b>91</b></font>,<font color="#800000"><b>96</b></font>,<font color="#800000"><b>100</b></font>,<font color="#800000"><b>105
    </b></font><b>_BarSteps   </b><font color="#008000"><b>CON </b></font><b>EXT           </b><font color="#0000FF"><b><i>; create a PBP constant that points to the Table
     </i></b></font><b>TooLow</b>:  <b>POKECODE </b><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>1</b></font>,<font color="#FF0000">&quot;TOO LOW &quot;</font>,<font color="#800000"><b>0
    </b></font><b>_TooLow   </b><font color="#008000"><b>CON </b></font><b>EXT             </b><font color="#0000FF"><b><i>; PBP constant pointing to the &quot;Too Low &quot; string
     </i></b></font><b>TooRich</b>: <b>POKECODE </b><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>$C0</b></font>,<font color="#FF0000">&quot;TOO RICH&quot;</font>,<font color="#800000"><b>0
    </b></font><b>_TooRich  </b><font color="#008000"><b>CON </b></font><b>EXT             </b><font color="#0000FF"><b><i>; PBP constant pointing to the &quot;Too Rich&quot; string
    </i></b></font><b>FlashSize </b><font color="#008000"><b>CON </b></font><b>EXT
    </b><font color="#008000"><b>ASM
       </b></font><font color="#000080">ifdef BSR
    FlashSize = 2                 </font><font color="#0000FF"><b><i>; 18F has byte addressing (2)
       </i></b></font><font color="#000080">else
    FlashSize = 1                 </font><font color="#0000FF"><b><i>; 12F/16F has words (1)
       </i></b></font><font color="#000080">endif
    </font><font color="#008000"><b>ENDASM
    </b></font><b>MidChar   </b><font color="#008000"><b>CON </b></font><b>EXT             </b><font color="#0000FF"><b><i>; MidChar is the border between
    </i></b></font><font color="#000080">@MidChar = 8 * FlashSize      </font><font color="#0000FF"><b><i>; 8 char segments of the 1x16 LCD being used
    </i></b></font><b>Main</b>:
        <font color="#008000"><b>DEBUGIN </b></font>[<b>Uin</b>.<b>LowByte</b>]     <font color="#0000FF"><b><i>; Serial Input
        </i></b></font><b>Uin </b>=  <b>Uin </b>*/ <font color="#800000"><b>124         </b></font><font color="#0000FF"><b><i>; same as (* 100 / 207)
        </i></b></font><font color="#008000"><b>LCDOUT </b></font><font color="#800000"><b>$FE</b></font>, <font color="#800000"><b>2             </b></font><font color="#0000FF"><b><i>; LCD Home Cursor
        </i></b></font><font color="#008000"><b>FOR </b></font><b>BarCount </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>TO </b></font>(<font color="#800000"><b>15 </b></font>* <b>FlashSize</b>) <font color="#008000"><b>STEP </b></font><b>FlashSize
            </b><font color="#008000"><b>IF </b></font>(<b>BarCount </b>= <b>MidChar</b>) <font color="#008000"><b>THEN LCDOUT </b></font><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>$C0  </b></font><font color="#0000FF"><b><i>; Second half of 1x16 LCD
            </i></b></font><b>PEEKCODE </b>(<b>_BarSteps</b>+<b>BarCount</b>),<b>BarValue       </b><font color="#0000FF"><b><i>; Get BarValue from Table
            </i></b></font><b>R0</b>.<b>LowByte </b>= <b>Uin</b>.<b>LowByte </b>- <b>BarValue
            </b><font color="#008000"><b>IF </b></font><b>Carry </b><font color="#008000"><b>THEN                                </b></font><font color="#0000FF"><b><i>; Uin &gt;= BarValue
                </i></b></font><font color="#008000"><b>LCDOUT </b></font><font color="#800000"><b>255                               </b></font><font color="#0000FF"><b><i>;  show a Full char
            </i></b></font><font color="#008000"><b>ELSE                                         </b></font><font color="#0000FF"><b><i>; Uin &lt; BarValue
                </i></b></font><font color="#008000"><b>LCDOUT </b></font><font color="#FF0000">&quot; &quot;                               </font><font color="#0000FF"><b><i>;  show a blank
            </i></b></font><font color="#008000"><b>ENDIF
        NEXT </b></font><b>BarCount
        R0</b>.<b>LowByte </b>= <b>Uin</b>.<b>LowByte </b>- <font color="#800000"><b>10                    </b></font><font color="#0000FF"><b><i>; if Uin &lt; 10
        </i></b></font><font color="#008000"><b>IF </b></font>!<b>Carry </b><font color="#008000"><b>THEN </b></font><b>MsgAddr </b>= <b>_TooLow </b>: <font color="#008000"><b>GOSUB </b></font><b>ShowMsg
        R0</b>.<b>LowByte </b>= <b>Uin</b>.<b>LowByte </b>+ <font color="#800000"><b>145                   </b></font><font color="#0000FF"><b><i>; if Uin &gt; 110
        </i></b></font><font color="#008000"><b>IF </b></font><b>Carry </b><font color="#008000"><b>THEN </b></font><b>MsgAddr </b>= <b>_TooRich </b>: <font color="#008000"><b>GOSUB </b></font><b>ShowMsg
    </b><font color="#008000"><b>GOTO </b></font><b>Main
    </b><font color="#0000FF"><b><i>;=============================================================================
    </i></b></font><b>ShowMsg</b>:
        <b>PEEKCODE MsgAddr</b>, <b>B0
        </b><font color="#008000"><b>IF </b></font><b>B0 </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>THEN RETURN
        LCDOUT </b></font><b>B0
        MsgAddr </b>= <b>MsgAddr </b>+ <b>FlashSize
    </b><font color="#008000"><b>GOTO </b></font><b>ShowMsg
    </b>
    cheers,
    Jan 2008
    Selm, Germany
    Smile Its Guru time
    Hi Darrel,
    looks impressive to me like a motorcycle to a small boy.....
    Whats this command:
    Uin = Uin */ 124 ; same as (* 100 / 207)
    the above means two mathematic orders in one? something like shifting bits?
    there would be a small mistake but thats totally acceptable because the bargraph is that crude which is really fine enough.
    will test that of course although there should be no need.....
    regards
    Mugel
    The */ operator first multiplies the 2 values (Uin * 124).
    Then it discards the low byte, and returns the rest.
    So effectively, it divides the result by 256, without having to do the divide part.
    100 / 207 = 0.48309178
    124 / 256 = 0.484375 ; not exact, but pretty close
    You're correct that there are small differences between the 2 formulas, but the error is less than +/- 1. And, you will never see a difference with the resolution of a 16 block bargraph.
    And, there probably is a need to test it.
    I was using a 16F877 with a 4x20 LCD. Could have missed something for your 16F628A and 1x16 LCD.
    Question
    Hi, Darrel
    Could you tell us for LCD Initialization at powerup ...If Uin first value is > 10 ... I do not see any ???
    you just suppose exhaust is air filled ???
    I'm not sure what you mean Alain.
    If the first value is > 10, it will just draw the bargraph like normal.
    It doesn't do anything until a serial byte is received.
    Hi,Darrel
    What I ment is you initialize the LCD ... ONLY if the value is < 10 ... ( when writing TOO LOW )
    What if you stop the engine and start it again ??? ... first value will be > 10 , due to the exhaust gases still in the exhaust tubing ... and I do not see any LCDOUT $FE,1 in this figure.
    Exhaust gases might still be in the tubing, but I wonder how quickly the sensor will cool off and not make a decent output. In my experience, those things cool off fairly quick. But then again, the 3/4 wire ones heat up pretty fast too...
    Jan 2008
    Selm, Germany
    Talking Lambda probes
    Hi Guys,
    now thats stuff Iīm into ! Those lambda probes are reacting pretty fast when hot, about the whole scale from too lean to too rich in half a second . Reliable results will be in after about half a minute with a cold engine starting when using 4 wire probes, 2 minutes or more with one wire probes and those one wire probes without heating are useless for idle control, heats too low. You can see lots of hidden stuff like choke or accelerator pump work or fuel cutoff when stepping off the gas. Funny to watch but most times absolut neccessary for the first setup.
    Oh, you mean the "Clear Screen".
    Since it writes to all 16 characters on each pass, I used "Home Cursor" ($FE,2) instead of "Clear Screen" ($FE,1) to prevent blinking of the display during updates.
    Or, if you're referring to the Power-On initialization that gets rid of the black blocks and makes the LCD work in the first place .... Mugel didn't have any specific initialization sequences in his original program and reported it to be working. So I assumed his display didn't need it.
    The first character sent to the LCD will cause PBP to initialize the display (if it hasn't already). It doesn't have to be $FE,1.
    Feb 2003
    Salt Lake City, Utah USA
    A Different Approach (317 Words ... without most of Darrel's amazing methods, which means there is room for more codesavings)
    ;@__config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    CMCON=%00000111
    DEFINE DEBUG_BAUD 2400   'Debug baud rate
    DEFINE DEBUGIN_REG PORTB 'Debugin pin port
    DEFINE DEBUGIN_BIT 0     'Debugin pin bit
    DEFINE DEBUGIN_MODE 1    'Debugin mode: 0 = True, 1 = Inverted
    ;DEFINE OSC 4
    xB0 var byte     ; SERIAL IN IS A BYTE SO MAKE IT A BYTE
    ;inputData var word ' variable to receive data into
    MAIN:
    DEBUGin [xB0]
    ;B0 = 100 * B0  ; why do these two lines?  B0 is already a Byte so work with Bytes
    ;Uin = B0 / 207  ;
    LCDOUT $FE, 1
    If xB0 < 21 then
        LCDOUT "TOO LOW"
        GOTO OUT
    IF xB0 < 34 then BARGRAPH1
    IF xB0 < 42 then BARGRAPH2
    IF xB0 < 52 then BARGRAPH3
    IF xB0 < 63 then BARGRAPH4
    IF xB0 < 73 then BARGRAPH5
    IF xB0 < 92 then BARGRAPH6
    IF xB0 < 112 then BARGRAPH7
    IF xB0 < 131 then BARGRAPH8
    LCDOUt $FE, $C0
    IF xB0 < 152 then BARGRAPH9
    IF xB0 < 170 then BARGRAPH10
    IF xB0 < 181 then BARGRAPH11
    IF xB0 < 191 then BARGRAPH12
    IF xB0 < 201 then BARGRAPH13
    IF xB0 < 210 then BARGRAPH14
    IF xB0 < 220 then BARGRAPH15
    IF xB0 < 230 then BARGRAPH16
    goto OUT
    BARGRAPH16:
    gosub p255
    BARGRAPH15:
    gosub p255
    BARGRAPH14:
    gosub p255
    BARGRAPH13:
    gosub p255
    BARGRAPH12:
    gosub p255
    BARGRAPH11:
    gosub p255
    BARGRAPH10:
    gosub p255
    BARGRAPH9:
    gosub p255
    LCDOUT $FE, $80   ; line 1
    BARGRAPH8:
    gosub p255
    BARGRAPH7:
    gosub p255
    BARGRAPH6:
    gosub p255
    BARGRAPH5:
    gosub p255
    BARGRAPH4:
    gosub p255
    BARGRAPH3:
    gosub p255
    BARGRAPH2:
    gosub p255
    BARGRAPH1:
    gosub p255
    OUT:
    Pause 5
    goto MAIN
    p255:
    lcdout 255
    [disclaimer] untested [/disclaimer]
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Arrow
    Good one Paul.
    Completely different way, and saved 18 words.
    And you're right. The multiplication uses a lot of code space.
    So I thought I'd remove it from my last version too and see what happened.
    268 words
    </i></b></font><b>Uin       </b><font color="#008000"><b>VAR BYTE
     </i></b></font><b>BarSteps</b>:  <b>POKECODE   </b><font color="#800000"><b>22</b></font>,<font color="#800000"><b>33</b></font>,<font color="#800000"><b>41</b></font>,<font color="#800000"><b>51</b></font>,<font color="#800000"><b>62</b></font>,<font color="#800000"><b>72</b></font>,<font color="#800000"><b>91</b></font>,<font color="#800000"><b>111</b></font>,<font color="#800000"><b>130</b></font>,<font color="#800000"><b>151</b></font>,<font color="#800000"><b>169</b></font>,<font color="#800000"><b>180</b></font>,<font color="#800000"><b>190</b></font>,<font color="#800000"><b>200</b></font>,<font color="#800000"><b>209</b></font>,<font color="#800000"><b>219
    </i></b></font><b>CountLength  </b><font color="#008000"><b>CON </b></font><b>EXT
    </b><font color="#000080">@CountLength = 15 * FlashSize
    </font><font color="#0000FF"><b><i>;=============================================================================
        <font color="#008000"><b>DEBUGIN </b></font>[<b>Uin</b>]             <font color="#0000FF"><b><i>; Serial Input
        </i></b></font><font color="#008000"><b>FOR </b></font><b>BarCount </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>TO </b></font><b>CountLength </b><font color="#008000"><b>STEP </b></font><b>FlashSize
            </b><font color="#008000"><b>IF </b></font>(<b>BarCount </b>= <b>MidChar</b>) <font color="#008000"><b>THEN LCDOUT </b></font><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>$C0  </b></font><font color="#0000FF"><b><i>; Second half of 1x8 LCD
            </i></b></font><b>R0</b>.<b>LowByte </b>= <b>Uin </b>- <b>BarValue
            </b><font color="#008000"><b>IF </b></font><b>Carry </b><font color="#008000"><b>THEN                                </b></font><font color="#0000FF"><b><i>; Uin &gt; BarValue
            </i></b></font><font color="#008000"><b>ELSE                                         </b></font><font color="#0000FF"><b><i>; Uin &lt;= BarValue
        R0</b>.<b>LowByte </b>= <b>Uin </b>- <font color="#800000"><b>22                            </b></font><font color="#0000FF"><b><i>; if Uin &lt; 22
        R0</b>.<b>LowByte </b>= <b>Uin </b>+ <font color="#800000"><b>29                           </b></font><font color="#0000FF"><b><i>; if Uin &gt; 227
    </b><font color="#008000"><b>RETURN
    </b></font>
    Jan 2006
    Istanbul
    Good one Paul.
    "TOO " is used twice. This could be arranged to save a few words more.
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 15:18
  2. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 15:13
  3. Multiple PIC programming
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 23:47
  4. Multiple PIC's with 1 crystal
    By puma in forum Schematics
    Last Post: - 20th March 2007, 17:02
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 22:07
