Simple 4 channel DMX controller
Results 1 to 20 of 20
    Oct 2007
    The Netherlands
    Default Simple 4 channel DMX controller
    'simple 4 channel DMX controller
    'reads 4 potmeters to control 4 lights
    '08-02-08 Kees Reedijk
    @ DEVICE PIC16F88, MCLR_OFF, HS_OSC, WDT_ON, LVP_OFF, PWRT_ON
    DEFINE  OSC 20             ' 20MHZ crystal
    DEFINE  ADC_BITS        8  ' Set number of bits
    DEFINE  ADC_CLOCK       3  ' Set clock source
    DEFINE  ADC_SAMPLEUS    50 ' Set sampling time
    DEFINE HSER_SPBRG 4   ' 250 KBaud
    RCSTA=%01010000 '9 bit data,usart disabled
    TXSTA=%01100101 'Enable transmit, BRGH=1, 9 bit data
    PORTA=    %00000000
    TRISA=    %00001111
    PORTB=    %00100000
    TRISB=    %00000100
    ANSEL=    %00001111
    CMCON=    %00000111
    DMX           VAR PORTB.5   'DMX output to SN75176 bus driver
    level1        VAR BYTE
    level2        VAR BYTE
    level3        VAR BYTE
    level4        VAR BYTE
    CLEAR
    loop:
        ADCIN 0,level1    'read level potmeters
        ADCIN 1,level2
        ADCIN 2,level3
        ADCIN 3,level4
        LOW  DMX
        PAUSEUS 100
        HIGH DMX
        PAUSEUS 12
        RCSTA.7=1     'usart enabled
        HSEROUT [0,level1,level2,level3,level4]
        PAUSE 10
        RCSTA.7=0     'usart disabled
    GOTO loop
    Feb 2003
    Sydney, Australia
    Very nice.
    One thing to be aware of is the DMX spec says there must be a minimum of 24 channels in a DMX message, so some cheaper devices might not be able to receive the dmx channels correctly.
    One option is to send out 20 '0's at the end of the HSEROUT statement.
    bill
    Quote Originally Posted by bcd View Post
    Very nice.
    bill
    So, if I understand your comment correctly, this simple implementation really works (aside from the 24 channel minimum that you mentioned) ?
    I don't know how DMX works, don't know the actual protocol, never used it, never had a need to use it (can't be too crazy hard as long as a guy reads the protocol documentation thoroughly).
    BUT, every once in awhile, about once or twice a year, usually before Christmas, a few new folks log on here, and make a big to-do out of this, that, and the other thing, and can't get a DMX controller to work.
    I guess I'm just wondering what the big deal was...after all, if code above works, well, jeeze, that's not so tough...
    This is the Transmit end of the DMX system.
    The "big deal" comes on the Receiving end.
    It's struggling to PWM some large number of channels at the same time it's receiving the DMX data at 250Kbaud.
    Seems to be a favorite "First Time" project.
    eggman,
    Short, sweet, and to the point.
    Very nice indeed.
    It's struggling to Dim some large number of channels at the same time it's receiving the DMX data at 250Kbaud.
    I suppose it would be a struggle, for the noob, trying to keep the RCREG from overflowing, while performing other tasks.
    At any rate, I'm bookmarking it. It may 'only' be the TX end, but reverse engineering some useful RX code doesn't look too difficult.
    Sep 2003
    INDIA
    Default Re: Simple 4 channel DMX controller
    This thread code looks goofed up any chances of including a txt file for the benefit of others.
    Thanks.
    Check it now.
    Sep 2003
    INDIA
    Thanks DAVE.
    May 2008
    Italy
    The vertical scroll bar is missing in the code area! So I can see only the few initial Lines of the code.
    From what i understand reading the various Posts, it seems I am the only one with this problem.
    Al.
    Is anyone else missing the scroll bars? I can see them.
    I see them fine.
    maybe is your browser Al. Try some other, Opera for instance. I test it and seems a little faster that IE9.
    May 2008
    Italy
    Ok thanks. Problem seems to be with ipad browser, I can see it with firefox.
    Al.
    Aug 2010
    Maryland, USA
    Hi Al. assuming your iPad is like my iPhone, have you tried to "2 finger scroll" in the code window? On my phone I get no bars, but I can scroll the code windows using 2 fingers.
    -Bert
    May 2008
    Italy
    Tank you Bert for the tip. 2 finger scroll in the code window works fine.
    Cheers
    Al.
    Jan 2012
    _Isthissoftwareworks the same wayhserin ?
    The DMX protocol uses 250k baud RS-485. There are some start pulses and such that need to happen. That what the HIGH/LOW DMX and pauses are doing. Here's an app note from Microchip that explains a bit more about it http://ww1.microchip.com/downloads/e...tes/01076A.pdf
    http://www.scalerobotics.com
    What is language? Basic?, C?, mikrobasic? Please help-me! thanks
    Depends which one you are talking about. The first post example is in PicBasic (check out www.melabs.com for software). The application note example for AN1076 is in assembly: http://www.microchip.com/stellent/id...pnote=en527825
    thanks!!!!
    personally... i hate the DMX protocol... but i'm sure their is a reason for it...
    running at 250K baud is going to be fun for anyone new...
    I recommend double buffering the data and using interrupts both for the USART and the ADC...
  1. DMX receive issue
    By NoahLD in forum mel PIC BASIC Pro
    Last Post: - 27th August 2014, 13:51
  2. 4 Channel Thermostat using PID loops
    By malc-c in forum Code Examples
    Last Post: - 18th March 2013, 10:17
  3. 4 pin 4 x 4 keypad interface using pic basic pro
    By dunlao_john in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 05:21
  5. Simple 4 line LCD display with 18F4550
    By pic-ker in forum Code Examples
    Last Post: - 9th April 2007, 02:58
