5x5 display 16f648a
Results 1 to 7 of 7
    Default 5x5 display 16f648a
    Saw a 5x5 display on you tube, daughter liked it so decided to make one.
    there was no code for it, so here it is in PBP.
    '* Christmas stocking stuffer for Andi from dad
    '* 5x5 home made led display
    '* pic 16F648A
    '* December 2007
    '* by: Nomad (DSobelman(at)hotmail(dot)com)
    ' USE ALL CAPS for now, will add lower case or lower case conversion to caps later
    ' very limited character set for now (no time to add the rest right now)
    ' added space at beginning of data, project was skipping first character
    data " ANDREA ROCKS # MERRY CHRISTMAS MUNCHKIN #"
    @ DEVICE pic16F648A, INTRC_OSC_NOCLKOUT
    '@ DEVICE pic16F648A, HS_OSC
    ' osc setting
    @ DEVICE pic16F648A, WDT_OFF
    ' Watchdog Timer
    @ DEVICE pic16F648A, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F648A, MCLR_OFF
    ' Master Clear Options (Internal)
    @ DEVICE pic16F648A, BOD_OFF
    ' Brown-Out Detect
    @ DEVICE pic16F648A, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE pic16F648A, CPD_OFF
    ' code protect
    @ DEVICE pic16F648A, PROTECT_OFF
    'data protect
    defines:
    'define osc 20
            PORTB = 0 'turn off all
            PORTA = 0
            TRISB = 0 'all output
            TRISA = 0
            CMCON = 7 'disable comparators
    Variables:
    row var byte
    col var byte[8] 'was originally going to do scrolling on 8x8 but didn't have a board
    x var word  'how many random patterns in random sub
    temp var word 'temp var for random HAS TO BE WORD (random doesn't work with byte)
    rowx var byte[5] 'store constant for each row
    char var byte    ' index for lookup
    lettermark var BYTE 'pointer to eeprom address
    letter var byte 'temp for ascii convert
    clear
    constants:   'rows numbered 1-5, single each row out
    rowx[1] = 1
    rowx[2] = 2
    rowx[3] = 4
    rowx[4] = 8
    rowx[5] = 16
    start:
    GOSUB READ_STRING   'READ EEPROM DATA
    gosub get_char      'GET CHARACTER DATA
    gosub display_run   'DISPLAY CHARACTER
    gosub rand_disp     'SHOW RANDOM BLINKY STUFF (THEY LIKE BLINKY STUFF)
    goto start          'DO IT AGAIN WITH NEXT LETTER OVER AND OVER
    rand_disp:     'generate random noise on display
    for x=1 to 5  'dispplay "x" random patterns (full 5x5(8x8) patterns)
    random temp    'make random number
    pauseus 50
    PORTA = temp   'put out on porta (only uses low byte?)
    random temp    'make row random number
    pauseus 50
    PORTB = temp   'put out on portb
    pause 20       'how long to show pattern
    next x         'next pattern
    display_run:        'show characters
    PORTA=0             'turn off all leds
    PORTB=0
    PAUSE 50             'forgot why this is here
    for temp = 1 to 1000 'how many full character loops (how long to display character)
    for row = 1 to 5      '5 loops, one for each row
    porta = 0             'turn rows off (kill ghosting)
    portb = col[row]      'put out row data for row(x)
    PAUSEUS 100           'settle
    porta = rowx[row]     'turn on row
    pauseus 100           'settle
    next row              'do again for each row to show full character
    next temp             'show character again (refresh/scan/whatever you wish to call it)
    read_string:        'read data (message) from eprom
    lettermark = lettermark + 1  'go to next eeprom address
    IF LETTERMARK > 255 THEN     ' if at end  hmmm don't think I need this anymore
    LETTERMARK = 0                'was testing
    READ LETTERMARK, LETTER      'read byte from eprom, assign to letter
    IF LETTER = $FF THEN         'check for end of message
    LETTERMARK = 0                'if end, reset eeprom pointer, make a space character
    LETTER = $20
    PAUSEUS 500
    find_index: ' use lookdown to change ascii to a sequential index to keep lookup small
    LOOKDOWN LETTER,["- #ABCDEFGHIJKLMNOPQRSTUVWXYZ"],CHAR
    get_char:   ' get each of the row's data with index from converted ascii
    LOOKUP char,[$00,$00,$0A,$0E,$1E,$0E,$1C,$1F,$1E,$1E,$11,$0E,$07,$09,$08,$11,$11,$0E,$0E,$0E,$1E,$0E,$1F,$00,$11,$11,$11,$11,$1F],col[1]
    LOOKUP char,[$00,$00,$1B,$11,$09,$10,$0A,$10,$10,$10,$11,$04,$02,$0A,$08,$1B,$19,$11,$09,$11,$09,$10,$04,$0A,$11,$11,$0A,$11,$02],col[2]
    LOOKUP char,[$1F,$00,$04,$1F,$0E,$10,$0A,$1E,$1C,$16,$1F,$04,$02,$0C,$08,$15,$15,$11,$0E,$15,$0E,$0E,$04,$0A,$0A,$15,$04,$1F,$04],col[3]
    LOOKUP char,[$00,$00,$1B,$11,$09,$10,$0A,$10,$10,$12,$11,$04,$0A,$0A,$08,$11,$13,$11,$08,$12,$0A,$01,$04,$0A,$04,$1B,$0A,$04,$08],col[4]
    LOOKUP char,[$00,$00,$0A,$11,$1E,$0E,$1C,$1F,$10,$1E,$11,$0E,$0E,$09,$0E,$11,$11,$0E,$08,$0D,$09,$0E,$04,$0E,$00,$11,$11,$04,$1F],col[5]
    will have to extend the character set and add serial to change the message. but this was just for a quick toy, so I didn't do any of that.
    If you add 2 more rows and make it a 5x7 display, I've got a set of lookup tables already made up for the complete ASCII character set, should plug right into what you've got going.
    Originally, I used the character tables for a 122x32 graphic LCD, and now I'm using it on a 130x130 4K color Nokia knockoff LCD (in addition to a 16x2 LCD, all at the same time!).
    I'll post them here when I get a chance...
    Jul 2007
    Question Nokia Lcd
    Hi Skimask,
    I would like to know where you are getting your Nokia color LCD from?
    Thanks!
    J-P
    Quote Originally Posted by GrandPa View Post
    Hi Skimask,
    Thanks!
    J-P
    Sparkfun for the first couple along with the breakout boards, eBay for the rest.
    Got a few of the connectors from Mouser (I think, don't remember), going to send off and have a few breakout boards made for myself.
    I've also got a rather LONG search set up on eBay that shows only the compatible phones which use that particular display and only those particular displays.
    Copy the following into the search bar and hit enter:
    nokia -6620 -6230 -6061 -3220 -73* -n9* -52* -77* -6500 -57* -53* -88* -6101 -6126 -6265 -6680 -e6* -6288 -n7* -6133 -8600 -6300 -6230i -6010 -5610 -9300 -3310 -5110 -8810 -n8* -3250 -5500 -6111 -6280 -8850 -6120 -3360 -6360 -6600 -3230 -8210 -e90 -n93 -e5* -1110 -8910
    Took me awhile to figure out which ones work and which ones don't. And then there's the problem with the different controllers, Philips vs. Epson. Minor differences in programming. Try to do anything out of the ordinary, either one or the other won't work. I'm using the Epson command set right now, but can't get the scrolling to work, which leads me to believe I've got a Philips controller. Not sure what's going on, but I really don't care either, 'cause it works great in the basic modes.
    And here they are, 3 lookup lines, split them up as you see fit. ASCII characters $0-$7E.
    The first 32 are 'special characters', as indicated below.
    All characters are in 5 byte groups, one byte per VERTICAL line on the display, 5x7 format. The bottom bit in each character is usually blank except for those characters which 'drop below the line'.
    lookup5x7_0: '0-31
    lookup alphachar , [ _
    $80,$80,$80,$80,$80,$c0,$c0,$c0,$c0,$c0,$e0,$e0,$e 0,$e0,$e0,$f0,$f0,$f0,$f0,$f0,$f8,$f8,$f8,$f8,$f8, $fc,$fc,$fc,$fc,$fc,$fe,$fe,$fe,$fe,$fe,$ff,$ff,$f f,$ff,$ff,_ '0-7 1-8 lines
    $fe,$83,$81,$83,$fe,$fe,$c3,$c1,$c3,$fe,$fe,$e3,$e 1,$e3,$fe,$fe,$f3,$f1,$f3,$fe,$fe,$fb,$f9,$fb,$fe, $fe,$ff,$fd,$ff,$fe,$fe,$ff,$ff,$ff,$fe,_ '8-14 battery charge levels
    $ff,0,0,0,0,$ff,$ff,0,0,0,$ff,$ff,$ff,0,0,$ff,$ff, $ff,$ff,0,0,0,0,0,$ff,0,0,0,$ff,$ff,0,0,$ff,$ff,$f f,0,$ff,$ff,$ff,$ff,$ff,0,0,0,$ff,$ff,$ff,0,$ff,$f f,$81,$81,$81,$81,$81,_
    $c3,$c3,$c3,$c3,$c3,$e7,$e7,$e7,$e7,$e7,$c0,$80,0, $1,$3,$f9,$f3,$e7,$cf,$9f,$3,$1,0,$80,$c0,$9f,$cf, $e7,$f3,$f9 ] , alphadata '15-31 block fillers of varying density
    lookup5x7_1: '32-81
    0,0,0,0,0,0,0,79,0,0,0,7,0,7,0,20,$7F,20,$7F,20,36 ,42,$7F,42,18,19,19,8,$64,98,54,73,85,34,80,0,5,3, 0,0,28,34,65,0,0,0,0,65,34,28,20,8,62,8,20,8,8,62, 8,8,0,80,48,0,0,_ '32-44
    8,8,8,8,8,0,96,96,0,0,32,16,8,4,2,62,81,73,69,62,0 ,66,$7F,64,0,66,97,81,73,70,33,65,69,75,49,24,20,1 8,$7F,16,39,69,69,69,53,60,74,73,73,48,1,$71,9,5,3 ,_ '45-55
    54,73,73,73,54,6,73,73,41,30,0,54,54,0,0,0,86,52,0 ,0,8,20,34,65,0,20,20,20,20,20,0,65,34,20,8,2,1,81 ,9,6,50,73,73,65,62,$7E,17,17,17,$7E,$7F,73,73,73, 54,_ '56-66
    62,65,65,65,34,$7F,65,65,34,28,$7F,73,73,73,65,$7F ,9,9,9,1,62,65,73,73,$7A,$7F,8,8,8,$7F,0,65,$7F,65 ,0,32,64,65,63,1,$7F,8,20,34,65,$7F,64,64,64,64,$7 F,2,12,2,$7F,_ '67-77
    $7F,4,8,16,$7F,62,65,65,65,62,$7F,9,9,9,6,62,65,81 ,33,94 ] , alphadata '78-81
    lookup5x7_2: '82-126
    Lookup alphachar , [ _
    $7F,9,25,41,70,70,73,73,73,49,1,1,$7F,1,1,63,64,64 ,64,63,31,32,64,32,31,61,64,56,64,63,99,20,8,20,99 ,7,8,$70,8,7,97,81,73,69,67,$7F,65,65,0,0,2,4,8,16 ,32,_ '82-92
    0,0,65,65,$7F,4,2,1,2,4,64,64,64,64,64,0,1,2,4,0,3 2,84,84,84,$78,$7F,72,68,68,56,56,68,68,68,32,56,6 8,68,72,$7F,56,84,84,84,24,8,$7E,9,1,2,$C,82,82,82 ,62,_ '93-103
    $7F,8,4,4,$78,0,68,$7D,64,0,0,32,64,68,61,$7F,16,4 0,68,0,0,65,$7F,64,0,$7C,4,24,4,$78,$7C,8,4,4,$78, 56,68,68,68,56,$7C,20,20,20,8,8,20,20,24,$7C,$7C,8 ,4,4,8,_ '104-114
    72,84,84,84,32,4,63,68,64,32,60,64,64,32,$7C,28,32 ,64,32,28,60,64,48,64,60,68,40,16,40,68,$C,80,80,8 0,60,68,$64,84,76,68,8,52,65,0,0,0,0,$7F,0,0,_ '115-124
    0,0,65,52,8,0,8,4,8,4 ] , alphadata '125-126
    Thanks some more to play with. lol. I was using mister e's picmulticalc to draw out the 5 rows for my display, worked nice.
    Quote Originally Posted by nomad View Post
    I'm in the process of adding a whole load of extra 'characters', call them 'graphics' characters, little airplanes, cars, etc, sort of animations if you will, consecutive characters which will end up resembling things like that airplane flying by, car driving, slot machine graphics, stuff like that. They'll take up the rest of the ASCII set from 128-255, and if I run out of room, change the byte to a word, add a couple of if/then's, and go with it. I'll re-post the whole thing when I get done with it all.
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 20:07
  2. Replies: 2
    Last Post: - 14th July 2008, 22:11
  3. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 13:12
  4. Replies: 14
    Last Post: - 26th September 2007, 05:41
  5. graphics display
    By adlinsystems in forum mel PIC BASIC Pro
    Last Post: - 12th June 2004, 12:53
