Compiled OK with line...
pbpw -p16f876a sample -v
Lots of embedded comments to tell you what's happening...
Enjoy
' Sample.BAS
' Target Processor PIC16F876A-04
' Write value '1234' to internal EEPROM
' When Button Pressed Read EEPROM value and Display on LCD
' CPU Hardware Layout
' PortA.0 - Unused - Set to INPUT
' PortA.1 - Unused - Set to INPUT
' PortA.2 - Unused - Set to INPUT
' PortA.3 - Unused - Set to INPUT
' PortA.4 - Unused - Set to INPUT
' PortA.5 - Unused - Set to INPUT
' PortB.0 - Button - Connect between this PIC Pin and Vss (0v)
' - uses internal PICs pull-up's
' PortB.1 - Unused - Set to OUTPUT
' PortB.2 - LCD - RS
' PortB.3 - LCD - E
' PortB.4 - LCD - DB4
' PortB.5 - LCD - DB5
' PortB.6 - LCD - DB6
' PortB.7 - LCD - DB7
' PortC.0 - Unused - Set to OUTPUT
' PortC.1 - Unused - Set to OUTPUT
' PortC.2 - Unused - Set to OUTPUT
' PortC.3 - Unused - Set to OUTPUT
' PortC.4 - Unused - Set to OUTPUT
' PortC.5 - Unused - Set to OUTPUT
' PortC.6 - Unused - Set to OUTPUT
' PortC.7 - Unused - Set to OUTPUT
' PIC Defines
@ DEVICE pic16F876A, XT_OSC ' System Clock Options
@ DEVICE pic16F876A, WDT_ON ' Watchdog Timer
@ DEVICE pic16F876A, PWRT_ON ' Power-On Timer
@ DEVICE pic16F876A, BOD_ON ' Brown-Out Detect
@ DEVICE pic16F876A, LVP_OFF ' Low-Voltage Programming
@ DEVICE pic16F876A, CPD_OFF ' Data Memory Code Protect
@ DEVICE pic16F876A, PROTECT_OFF ' Program Code Protection
@ DEVICE pic16F876A, WRT_OFF ' Flash Memory Word Enable
' Hardware Defines
' LCD Display
Define LCD_DREG PORTB ' Port for LCD Data
Define LCD_DBIT 4 ' Use upper 4 bits of Port
Define LCD_RSREG PORTB ' Port for RegisterSelect (RS) bit
Define LCD_RSBIT 2 ' Port Pin for RS bit
Define LCD_EREG PORTB ' Port for Enable (E) bit
Define LCD_EBIT 3 ' Port Pin for E bit
Define LCB_BITS 4 ' Using 4-bit bus
Define LCD_LINES 2 ' Using 2 line Display
Define LCD_COMMANDUS 2000 ' Command Delay (uS)
Define LCD_DATAUS 50 ' Data Delay (uS)
' Button Inputs
ButtonPRESS var PortB.0 ' Push Button
' EEPROM
MemoryA DATA @0,0 ' The TWO memory locations for saving WORD variable
MemoryB DATA 0 ' Both Preset to Zero
' RAM Assignments & Variables
WORDVariable var WORD ' Just a WORD variable we're going to use
' Start Program
' Set-up Hardware
TRISA=%00111111 ' All available PortA is Input
' Remember it's still in ANALOG Mode
TRISB=%00000001 ' All PortB is Output - except
' B.0 = Button
TRISC=%00000000 ' All PortC is Output
CMCON=%00000111 ' Disable Comparators
CVRCON=%00000000 ' Disable Reference Module
OPTION_REG.7=0 ' Enable Weak Pull-Up's
Pause 2000 ' Wait for LCD to settle
' Save Value into EEPROM
WORDVariable=1234
LCDOut $FE,1,"Writing=",#WordVariable ' Tell user what we're doing...
WRITE MemoryA,WORDVariable.HighByte ' Save one Byte from Word to EEPROM Location 0
WRITE MemoryB,WORDVariable.LowByte ' Save other Byte from Word to EEPROM Location 1
Pause 2000 ' Just a pause so you can read what's on the LCD
' Prompt for Button Press
PromptLoop:
LCDOut $FE,1,"Press Button..."
While ButtonPRESS=1:Wend ' Wait here until Button Pressed
READ MemoryA,WORDVariable.HighByte ' Reconstruct Word variable from EEPROM
READ MemoryB,WORDVariable.LowByte
LCDOut $FE,1,"Reading=",#WORDVariable ' Display Result
While ButtonPress=0:Wend ' Wait here as long as finger is on Button
Goto PromptLoop
