2x16 lcd not working with pic16f72
Results 1 to 5 of 5
    Mar 2007
    Mumbai-INDIA
    Smile 2x16 lcd not working with pic16f72
    hi,
    I am new to PBP, I have made small test board for testing my codes using pic16f72 and I have written following code to test 2x16 lcd but it doesnt seem to be working. All I see is black squares.
    My test board with 16f628+lcd with default LCD wiring is working fine and I have tested my few codes On it.
    COULD SOMEBODY PLS POINT OUT WHAT IS THAT I AM MISSING ?
    'PIC16F72
    DEFINE OSC 10 ' Set the Xtal frequency
    TRISB=%00000011
    TRISA=%00000000
    ' ** Declare LCDOUT Defines **
    DEFINE LCD_DREG PORTB 'LCD data port
    DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTB 'LCD register select port
    DEFINE LCD_RSBIT 2 'LCD register select bit
    DEFINE LCD_EREG PORTB 'LCD enable port
    DEFINE LCD_EBIT 3 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    PAUSE 2000
    MAIN:
    LCDOUT $FE, 1 'LCD CLR
    LCDOUT $FE, $80, " LINE 1 "
    LCDOUT $FE, $C0, " LINE 2 "
    PAUSE 100
    GOTO MAIN
    Thanks in advance
    vu2iia
    PBP's default Oscillator config for the 16F72 is XT.
    For 10mhz, you'll need HS.
    Mar 2007
    Mumbai-INDIA
    Smile About 2x16 lcd not working with pic16f72
    THANKS DARREL YOU POINTED out THE RIGHT PROBLEM, LCD IS WORKING NOW
    REGARDS
    VU2IIA
    www.vu2iia.blogspot.com
    manisg84's Avatar
    manisg84 Guest
    Post Re: 2x16 lcd not working with pic16f72
    I am also trying to progrma PIC16f72 with LCd jhd162A, but it is not working
    here is my code, anybody suggest where i did the mistake. i am using 4mhz hs oscillator.
    #include <P16f72.inc>
    LCD_DATA EQU PORTC ; PORTC FOR LCD DATA PINS
    LCD_CTRL EQU PORTB ; PORTB SFR register
    TRISA EQU 85h ; TRISA SFR register
    TRISB EQU 86h ; TRISB SFR register
    TRISC EQU 87h ; TRISC SFR register
    STATUS EQU 03h ; STATUS SFR register
    PORTA equ 05
    R1 EQU 21
    R2 EQU 22
    ORG 00
    goto START
    LDELAY
    MOVLW .200 ; 250MS DELAY
    MOVWF R2
    LOOP3 MOVLW .250
    MOVWF R1
    LOOP4 NOP
    NOP
    DECFSZ R1, F
    GOTO LOOP4
    DECFSZ R2, F
    GOTO LOOP3
    SDELAY
    MOVLW .100 ; 250MS DELAY
    MOVWF R2
    LOOP1 MOVLW .250
    MOVWF R1
    LOOP2 NOP
    NOP
    DECFSZ R1, F
    GOTO LOOP2
    DECFSZ R2, F
    GOTO LOOP1
    LCD_INIT
    BCF LCD_CTRL,3
    CALL LDELAY
    MOVLW 0X38
    CALL COMMAND
    CALL LDELAY
    MOVLW 0X0E
    CALL COMMAND
    CALL READY
    MOVLW 0X01
    CALL COMMAND
    CALL READY
    MOVLW 0X06
    CALL COMMAND
    CALL READY
    MOVLW 0X81
    CALL COMMAND
    CALL READY
    MOVLW A'M'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'O'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'N'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'I'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'C'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'A'
    CALL DATADISPLAY
    CALL READY
    MOVLW 0X88
    CALL COMMAND
    CALL READY
    MOVLW A'M'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'O'
    CALL DATADISPLAY
    MOVLW A'N'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'I'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'S'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'H'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'A'
    CALL DATADISPLAY
    CALL READY
    MOVLW 0XC3
    CALL COMMAND
    CALL READY
    MOVLW A'E'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'L'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'E'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'C'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'T'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'R'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'O'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'N'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'I'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'C'
    CALL DATADISPLAY
    CALL READY
    MOVLW A'S'
    CALL DATADISPLAY
    COMMAND MOVWF LCD_DATA
    BCF LCD_CTRL,1
    BCF LCD_CTRL,2
    BSF LCD_CTRL,3
    CALL SDELAY
    BCF LCD_CTRL,3
    DATADISPLAY MOVWF LCD_DATA
    BSF LCD_CTRL,1
    BCF LCD_CTRL,2
    BSF LCD_CTRL,3
    CALL SDELAY
    BCF LCD_CTRL,3
    READY BSF STATUS,5
    MOVLW 0xFF
    MOVWF TRISC
    BCF STATUS,5
    BCF LCD_CTRL,1
    BSF LCD_CTRL,2
    BACK BSF LCD_CTRL,3
    CALL SDELAY
    BCF LCD_CTRL,3
    BTFSC LCD_DATA,7
    GOTO BACK
    BSF STATUS,5
    MOVLW 00
    movwf TRISC
    BCF STATUS,5
    START BSF STATUS,5 ; Select Bank 1
    MOVLW b'00000000' ; PORTA as output
    MOVWF TRISA
    MOVLW b'00000000'
    MOVWf TRISB
    MOVLW b'00000000'
    MOVWF TRISC ; PORTC as output to LCD
    BCF STATUS,5 ; Select bank0
    CALL LCD_INIT
    Default Re: 2x16 lcd not working with pic16f72
    Quote Originally Posted by manisg84 View Post
    ... here is my code, anybody suggest where i did the mistake. ...
    You didn't use PicBasic Pro ...
  1. My LCD code is not working...
    By kvrajasekar in forum mel PIC BASIC
    Last Post: - 7th December 2008, 05:41
  2. Play with LCD on PICDEM
  3. Simple LCD code not working..
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 28th April 2008, 13:55
  4. SOUND makes LCD quit working
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 18th April 2008, 14:12
  5. Need help with LCD number display.
