HSERIN doesn´t work
Results 1 to 5 of 5
    Jul 2007
    Default HSERIN doesn´t work
    Hallo,
    I´m new here and I need some help.
    I´m using a PIC16F873a in a handswitch. There I send and receive via UART some information.
    Sending works fine. But I´m not able to receive some data.
    The signal lays on the RX-Port. Thats correct.
    Is there something wrong in my code?
    I want to receive some characters (CHR(101), CHR(105), CHR(106))
    ' Säulentastatur medifa MXT-Steuerung
    ' PIC 16F873 für Tastenauswertung
    ' (c) 2007 by WURM IT Solutions
    ' [email protected]
    ' Tel.: +49 2721 9279070
    ' Controller: PIC 16F873A / 4MHz Resonator
    ' Modell: medifa MOT 601700
    ' Bus: RS485 / 19200 Baud / Half duplex
    ' Software-Revision: V1.0 05.07.2007 Inbetriebnahme
    ' Definitionen
    define osc 4
    include "modedefs.bas"
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 19200 ' 19200 Bauds
    DEFINE HSER_CLOERR 1
    ' Port-Definitionen
    adcon1 = 7 'Ports auf digital
    p1 var porta.0
    p2 var porta.1
    p3 var porta.2
    p4 var porta.3
    p5 var porta.5
    p6 var portc.0
    p7 var portb.7
    p8 var portb.6
    p9 var portb.5
    p10 var portb.4
    ELEIN var portc.1
    s1 var word
    s2 var word
    s3 var word
    s4 var word
    s5 var word
    s6 var word
    s7 var word
    s8 var word
    s9 var word
    s10 var word
    s11 var word
    s12 var word
    s13 var word
    s14 var word
    s15 var word
    s16 var word
    s17 var word
    s18 var word
    Bus_out var byte
    Bus_out_alt var byte
    zaehler var word
    Bus_in var Byte
    busrw var portc.5
    ' Ports als Ein- bzw. Ausgang
    input porta.3
    input porta.5
    input portc.0
    input portb.7
    input portb.6
    input portb.5
    output porta.0
    output porta.1
    output porta.2
    output portc.1
    output portc.5
    ' Hauptprogramm
    high ELEIN 'EL-Folie und Display beim Start ausschalten
    'pause 5000
    'high busrw 'für senden = high, für empfangen = low
    Schleife:
    low busrw
    repeat
    hserin [Bus_in]
    until Bus_in = 101 or Bus_in = 105 or Bus_in = 106
    if Bus_in = 101 then gosub Taste
    if Bus_in = 105 then gosub Power_on
    if Bus_in = 106 then gosub Power_off
    goto Schleife
    Taste:
    low ELEIN 'Test
    ' Ebene 1 abfragen S2, S1, S14, S13, S8, S7
    low p10
    s1=0
    s2=0
    s3=0
    s4=0
    s5=0
    s6=0
    s7=0
    s8=0
    s9=0
    s10=0
    s11=0
    s12=0
    s13=0
    s14=0
    s15=0
    s16=0
    s17=0
    s18=0
    high p3
    low p2
    low p1
    if p4 = 1 then s2 = 1
    if p5 = 1 then s1 = 1
    if p6 = 1 then s14 = 1
    if p7 = 1 then s13 = 1
    if p8 = 1 then s8 = 1
    if p9 = 1 then s7 = 1
    ' Ebene 2 abfragen S4, S3, S16, S15, S10, S9
    low p3
    high p2
    low p1
    if p4 = 1 then s4 = 1
    if p5 = 1 then s3 = 1
    if p6 = 1 then s16 = 1
    if p7 = 1 then s15 = 1
    if p8 = 1 then s10 = 1
    if p9 = 1 then s9 = 1
    ' Ebene 3 abfragen S6. S5. S18. S17. S12. S11
    low p3
    low p2
    high p1
    if p4 = 1 then s6 = 1
    if p5 = 1 then s5 = 1
    if p6 = 1 then s18 = 1
    if p7 = 1 then s17 = 1
    if p8 = 1 then s12 = 1
    if p9 = 1 then s11 = 1
    low p3
    low p2
    low p1
    ' Bus_out ausgeben
    Bus_out = 099
    zaehler = 0
    if s1 = 1 then Bus_out=001:zaehler = zaehler + 1
    if s2 = 1 then Bus_out=002:zaehler = zaehler + 1
    if s3 = 1 then Bus_out=003:zaehler = zaehler + 1
    if s4 = 1 then Bus_out=004:zaehler = zaehler + 1
    if s5 = 1 then Bus_out=005:zaehler = zaehler + 1
    if s6 = 1 then Bus_out=006:zaehler = zaehler + 1
    if s7 = 1 then Bus_out=007:zaehler = zaehler + 1
    if s8 = 1 then Bus_out=008:zaehler = zaehler + 1
    if s9 = 1 then Bus_out=009:zaehler = zaehler + 1
    if s10 = 1 then Bus_out=010:zaehler = zaehler + 1
    if s11 = 1 then Bus_out=011:zaehler = zaehler + 1
    if s12 = 1 then Bus_out=012:zaehler = zaehler + 1
    if s13 = 1 then Bus_out=013:zaehler = zaehler + 1
    if s14 = 1 then Bus_out=014:zaehler = zaehler + 1
    if s15 = 1 then Bus_out=015:zaehler = zaehler + 1
    if s16 = 1 then Bus_out=016:zaehler = zaehler + 1
    if s17 = 1 then Bus_out=017:zaehler = zaehler + 1
    if s18 = 1 then Bus_out=018:zaehler = zaehler + 1
    if zaehler > 1 then Bus_out = 099
    if s1 = 1 and s2 = 1 then Bus_out = 098
    high busrw
    HSEROUT [Bus_out]
    low busrw
    ' Sub POWER_ON
    Power_on:
    low ELEIN
    ' Sub POWER_OFF
    Power_off:
    high ELEIN
    Default HSERIN is not 'complete'
    I think you will find that HSERIN is not a fully self contained command for sending or receiving data through the UART. You must manually manage the CREN bit and probably more for reliable results.
    I had many intermittent problems with that command so I gave up and now only use DEBUG, SERIN or SERIN2 which have the advantage they can be assigned to any pin.
    HTH
    Brian
    wurm,
    Do you have pins 2 and 3 connected together on the 75176? (!RE/DE)
    Dec 2005
    RS485 half-duplex is usually single master, multiple slaves with slaves transmitting only after being requested to do so by the master. Is this the code for a slave? If so, could the problem be on the other end?
    Jul 2007
    So thanks for your answers.
    I`ve found out the problems.
    I have two SP485 drivers in the layout and one was connected as receiver and one as sender.
    Then the bus doesn´t work correctly.
    The second problem was solluted by setting and resetting cren register.
    Best regards,
    Wurm
  1. Hserin with Instant Interrupts.
    By ronjodu in forum Serial
    Last Post: - 30th December 2014, 20:17
  2. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 11:58
  3. HSERIN problem
    By eggman in forum mel PIC BASIC Pro
    Last Post: - 6th October 2007, 21:31
  4. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 15:42
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 12:03
