PIC18F2550 Newbie
Results 1 to 10 of 10
    Apr 2007
    Default PIC18F2550 Newbie
    I'm quite new to microcontrollers, but have completed a successful project on a PIC16F628A. I need to eventually have USB capability and want to learn the PIC18F2550. To start simply, I wired a circuit with an LED and used a 20Mhz crystal with the following code:
    DEFINE OSC 20
    loop:
    High PORTA.0 ' Turn on LED connected to PORTA.0
    Pause 500 ' Delay for .5 seconds
    Low PORTA.0 ' Turn off LED connected to PORTA.0
    Goto loop ' Go back to loop and blink LED forever
    This works but the LED blinks twice as fast as it should. I haven't yet run across anything in the Datasheet that would account for this. I'm sure I'm missing something simple. Any input is appreciated.
    Jeff
    Quote Originally Posted by JeffnDana View Post
    define OSC 20
    loop:
    Jeff
    Is it running 2x as fast as it should be or 2.4x as fast as it should be?
    Mar 2005
    Iowa, USA
    Try DEFINE capitalized.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Quote Originally Posted by rhino View Post
    GOOD call!
    I was going for the misconfigured PLL myself...but yours is much better...
    Apr 2007
    Actually, in my code DEFINE is capitalized. Sorry for that, not sure why it isn't capitalized in my post.
    Mar 2005
    Iowa, USA
    hmmm.... I'm stumped. Might want to look into what Skimask says about the PLL. Check out this LINK. You may have to tell us your PBP version, IDE, MPASM version, programmer, social security #, mother's maiden name, etc.
    Ryan Miller
    Hello. I had similar timing issues with a 18F2510. In my case, the timing was slower than it should be with a 4MHZ resonator. Within MPLAB I changed the watchdog postscaler from 1:128 (DEFAULT) TO 1:8. This seemed to correct the problem. I noticed the 2550 defaults to 1: 32768. Maybe you can try this route
    Apr 2007
    Thumbs up
    I got it working thanks to all of you. I'm using MicroCode studio and changed the configuration settings from the Compile and Program dialog. While changing the watchdog postscaler setting I noticed that the Oscillator mode was set to HSPLL. When I set this to HS the timing was correct. According to the datasheet there is a postscaler adjustment for the PLL setting (1/2, 1/3, etc) so I assume I would change that if the mode were HSPLL. If I understand it correctly, I would want to use HSPLL when using the USB functionality.
    Thanks again,
    Jeff
    Thanks again,
    Jeff
    The HSPLL can be used anytime, whether using USB or not. Use the HSPLL, and you can get 48Mhz internal at the PIC, while only having to design for a 12Mhz crystal/oscillator. Makes circuit design just that much easier than trying to get a 48Mhz crystal to work on a sloppy design.
    Apr 2007
    Thanks for the info skimask, that's good to know.
  1. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 09:56
  2. PIC Newbie
    By azmax100 in forum Schematics
    Last Post: - 23rd February 2007, 04:52
  3. PIC18F2550 and GSM modem
    By zach in forum GSM
    Last Post: - 28th November 2006, 09:01
  4. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 09:01
  5. PIC18F2550 ICSP - newbie
    By icicle in forum Off Topic
    Last Post: - 9th August 2005, 22:41
