Write and Read from eeprom
Results 1 to 24 of 24
    Jun 2006
    Default Write and Read from eeprom
    I have the below code (one part of code).
    My problem is when turn off the power and after turn on again , don't save the value P in the eeprom always.Why;
    I use 16f88
        P VAR WORD	          'value of the divider
        FLAG VAR BYTE
        READ 3,FLAG
        IF FLAG = 55 THEN
        READ 1,P.BYTE0        ' Divider
        READ 2,P.BYTE1
    	P= 256	        	  ' value of the divider
    '************************** CHOICE OF THE DIVIDER ***********************
    PREDIV:
    	LCDOUT $FE,1,"*    DIVIDER   *"
    	LCDOUT $FE,$C0,"     P = ",#P
    LOOP:
        BUTTON PLUS,0,10,5,B1,1,PICK	    ' Goes to PICK if press the button
    	BUTTON BMENU,0,255,0,B4,1,MEN
    	PAUSE 100
    	GOTO LOOP
    PICK:
        IND = IND + 1
    	IF IND< 9 THEN CHOIX
    	IND= 0
    	GOTO CHOIX
    CHOIX:
        LOOKUP2 IND,[1,10,16,32,40,64,80,128,256],P
    	WRITE 3 , 55
    	WRITE 1 , P.BYTE0      	            ' SAVE The VALUE OF P
    	WRITE 2 , P.BYTE1
        PAUSE 100
    	GOTO MAIN
    Yassou Niko!
    If the power is taken before the Write commands, then it is possible to loose the values. When do you power off the device?
    Jun 2006
    Yassou Niko!
    Geiasou Giannh (ta agglika mou einai xalia)
    I turn off the power after enough (>30 sec) time when change the value
    Time is not the most critical point. If the program never makes it to the Write commands, then it sure will never store the values to EEPROM.
    I had a similar problem and fixed it by using two variables. Do not know why this worked, but I have used this routine for some time now.
    cnt var byte
    Pb1	var word
    Pset    var word
    READ 0,Pset.BYTE0
    READ 1,Pset.BYTE1
    Pb1 = Pset
    C_P:
    		for cnt = 1 to 1
    		Pb1=Pb1+1
    		WRITE 0,Pb1.BYTE0
    		WRITE 1,Pb1.BYTE1
    		READ 0,Pset.BYTE0
    		READ 1,Pset.BYTE1
    		next
    Maybe all you need is the count routine to ensure that the data is being written?
    Jun 2006
    I have 4 routines to write and read
    Jun 2006
    Need to add the : Include "Modedefs.Bas" ;
    That would do it. Was scratching my head...
    Jun 2007
    Default read write to eeprom
    hello ya all,
    I have been at this for 3 days and nights now, i give up, I need help.
    Its simple in the pbp manual and from what Ive read in this forum, but to no luck. heres the details, not in the exact order
    pbp 2.47
    Include "modedefs.bas" ' is included
    DISABLE ' to turn off interupts even though i never hae used them
    TRISA = %11011
    TRISB = %11011011
    The problem is somtimes it works and somtimes it dosn't. When I read back the data after i write it, it reads correct. but after Ive turned it off and back on it comes up with weird numbers, random numbers. I send it to and lcd through serout2, and also receive a command or two. but I dont think the problem is there because other data shows up fine. the exact full code will be down below, but for now to point out where I think the problem is.
    WRITEIT:
    WRITE 0,T0
    READ 0,T0
    WRITE 1,T1
    READ 1,T1
    WRITE 2,P0
    READ 2,P0
    WRITE 3,P1
    READ 3,P1
    WRITE 4,C0
    READ 4,C0
    WRITE 5,C1
    READ 5,C1
    If my problem is somewhere else then Please point it out, cause I have tried everything. I am not one to give up easy, so for me to be here asking for help is rare. I am not an expert at pbp, but I do my best and can do almost everything I set out to do. here is the rest of my code
    Include "modedefs.bas" ' Include serial modes
    TRISA = %11011
    TRISB = %11011011
    '--------------------------DECLARES------------------------------
    PERCENT VAR BYTE
    TOTAL VAR WORD
    CAMBIO VAR WORD
    PREMIOS VAR WORD
    TT VAR WORD
    PP VAR WORD
    CC VAR WORD
    COUNTING VAR BYTE
    AMOUNT VAR BYTE
    MAC VAR BYTE
    DIP1 VAR BYTE
    DIP2 VAR BYTE
    DIP3 VAR BYTE
    DONE VAR BYTE
    COINOUT VAR PORTB.0
    COININ VAR PORTB.1
    MOTOR VAR PORTB.2
    LLAVE VAR PORTB.3
    BUTTON1 VAR PORTB.4
    COUNTER VAR PORTB.5
    A VAR WORD
    C0 VAR CAMBIO.BYTE0
    C1 VAR CAMBIO.BYTE1
    T0 VAR TOTAL.byte0
    T1 VAR TOTAL.byte1
    P0 VAR PREMIOS.BYTE0
    P1 VAR PREMIOS.BYTE1
    X VAR BYTE
    '-------------------------------SETUP-----------------------------
    counter=0
    motor=0
    DONE=0
    '----------------------------turn off interupts-------------------
    DISABLE
    '-----------------------------get data-----------------------------
    READ 0,T0
    READ 1,T1
    READ 2,P0
    READ 3,P1
    READ 4,C0
    READ 5,C1
    READ 6,MAC
    PAUSE 500
    AMOUNT=100
    COUNTING=0
    '----------------------------DIP SETUP-----------------------------
    DIP1=PORTA.0
    IF DIP1=0 THEN
    DIP1=40
    DIP1=20
    DIP2=PORTA.1
    IF DIP2=0 THEN
    DIP2=20
    DIP2=10
    DIP3=PORTB.7
    IF DIP3=0 THEN
    DIP3=10
    DIP3=5
    IF PORTA.4=0 THEN
    AMOUNT=25
    AMOUNT=100
    PERCENT=DIP1+DIP2+DIP3
    IF PERCENT=70 THEN PERCENT=100
    IF BUTTON1 = 0 THEN BOR
    '--------------------------------MAIN LOOP---------------------------
    LOOP:
    IF COININ = 1 THEN COUNT1COIN
    IF COINout = 1 THEN COINOUT100
    IF PORTB.6 = 1 THEN LLA2
    IF LLAVE = 1 THEN LLAVE1
    IF BUTTON1 = 0 THEN SACAR
    GOTO LOOP
    '-------------------------LLAVERO CONNECTED--------------------------
    LLA2:
    PAUSE 500
    FOR X=1 TO 5
    GOSUB INFO
    NEXT X
    GOTO BORRAR
    '--------------------------CONTAR 1 MONEDA---------------------------
    COUNT1COIN:
    PAUSE 20
    IF COININ=1 THEN COUNT1COIN
    TOTAL=TOTAL+1
    GOSUB WRITEIT
    GOTO LOOP
    '----------------------CONTAR 1 MONEDA SALIENDO----------------------
    COINOUT100:
    PREMIOS=PREMIOS+1
    TOTAL=TOTAL-1
    GOSUB WRITEIT
    GOTO LOOP
    '-------------------------CONTAR 1 A CONTADOR------------------------
    CNT:
    COUNTER=1
    PAUSE 40
    COUNTER=0
    PAUSE 50
    '------------------------EL LLAVE DEL CLIENTE------------------------
    LLAVE1:
    PAUSE 100
    IF LLAVE=1 THEN LLAVE1
    IF CAMBIO +AMOUNT > (TOTAL/PERCENT)*100 THEN LOOP
    COUNTING=0
    MOTOR=1
    COUNT100:
    IF COINOUT=1 THEN COUNT100WAIT
    GOTO COUNT100
    COUNT100WAIT:
    PAUSE 5
    IF COINOUT=0 THEN COUNT100DONE
    GOTO COUNT100WAIT
    COUNT100DONE:
    COUNTING=COUNTING+1
    TOTAL=TOTAL-1
    CAMBIO=CAMBIO+1
    GOSUB WRITEIT
    IF COUNTING=AMOUNT THEN
    motor=0
    gosub cnt
    PAUSE 300
    GOTO LOOP
    gosub cnt
    GOTO COUNT100
    '-----------------------------GUARDAR INFO--------------------------
    WRITEIT:
    WRITE 0,T0
    READ 0,T0
    WRITE 1,T1
    READ 1,T1
    WRITE 2,P0
    READ 2,P0
    WRITE 3,P1
    READ 3,P1
    WRITE 4,C0
    READ 4,C0
    WRITE 5,C1
    READ 5,C1
    'PARA NO BORRAR CON EL BUTTONES AL MENOS QUE NO TIENE UN # DE MAC
    BOR:
    IF MAC > 251 THEN
    GOTO BORRAR1
    GOTO LOOP
    '----------------------------BORRAR INFO---------------------------
    BORRAR:
    SERIN2 PORTA.3,16780, 500,BORRAR,[WAIT ("CB"),DEC1 DONE]
    IF DONE=1 THEN BORRAR1
    IF DONE=0 THEN MAC1
    GOTO BORRAR
    BORRAR1:
    TOTAL=0
    PREMIOS=0
    CAMBIO=0
    GOSUB WRITEIT
    FOR X=1 TO 5
    GOSUB INFO
    NEXT X
    GOTO LOOP
    '----------------------MANDAR LA INFO AL LLAVERO-------------------
    INFO:
    A = TOTAL * 100 'A is temporary storage of computation
    A = DIV32 PERCENT 'using DIV32... B can be any integer up to 65534
    A = A / 100 'final result is placed in variable A as an integer... any
    PREMIOS=A
    SEROUT2 PORTA.2,16780,["M",DEC3 MAC]
    PAUSE 100
    SEROUT2 PORTA.2,16780,["T",DEC5 TOTAL]
    PAUSE 100
    SEROUT2 PORTA.2,16780,["P",DEC5 PREMIOS]
    PAUSE 100
    SEROUT2 PORTA.2,16780,["%",DEC3 PERCENT]
    PAUSE 100
    SEROUT2 PORTA.2,16780,["S",DEC5 CAMBIO]
    '-----------------------GRABAR EL # DE MAC-------------------------
    MAC1:
    serin2 PORTA.3,16780, MAC1,[WAIT ("M"),DEC3 MAC]
    WRITE 6,MAC
    READ 6,MAC
    FOR X=1 TO 5
    GOSUB INFO
    NEXT X
    GOTO BORRAR
    '------------------------SACAR EL GANACIAS-------------------------
    SACAR:
    PAUSE 100
    IF BUTTON1=0 THEN SACAR
    IF TOTAL < 100 THEN LOOP
    MOTOR=1
    COUNTING=0
    CAMOUNT:
    IF COINOUT=1 THEN CAMOUNTWAIT
    GOTO CAMOUNT
    CAMOUNTWAIT:
    PAUSE 5
    IF COINOUT=0 THEN CDONE
    GOTO CAMOUNTWAIT
    CDONE:
    COUNTING=COUNTING+1
    TOTAL=TOTAL-1
    GOSUB WRITEIT
    IF COUNTING=100 THEN
    MOTOR=0
    PAUSE 300
    GOTO LOOP
    GOTO CAMOUNT
    What PIC are you using?
    What are you using for pullup values going out to the EEPROM?
    Jun 2007
    Default reply
    Its the internal eeprom of the pic16f84a
    Quote Originally Posted by jason View Post
    uhh...der...it sure is...dumb question on my part...
    Break it down, get it simple, get rid of all of that other stuff in your program, make something seriously simple, and build it back up. There is a bit of a logic error in your program that'll probably cause your symptoms.
    Jun 2007
    Default ok, I did it
    Thank you for your quick help on this
    Ok I did as you suggested
    I made a new file, and slowly added until I had a problem. I'm not sure if this is the problem with my "write" but I wouldn't doubt it, due to some sort of overflow.
    here I am trying to get a percentage of a word sized integer
    percent=35
    example: A=65535 * .35 or A=(65535*100) /35
    if total=100 wouldn't A=35 ???
    I'm not familiar with DIV32 at all, I read up on it and understand somewhat how it works, becuase PBP can't deal with numbers larger than a "word" it uses this as a temperary variable so that people like me can do this type of math, right ?
    Post EEPROM and index ...
    Hi, Jason
    Did you had a look to THAT Thread ???
    http://www.picbasic.co.uk/forum/showthread.php?t=1078
    Jun 2007
    Default uuuuuh ?????
    WOW
    I think that is my problem here. However I only understood a little bit of it.
    Why is this so complicated just to store a word ?
    OK, so I thought storing total.byte0 in location 0 and then storing total.byte1 in location 1 would handle the whole word right ?
    total=33024 or total.byte0=10000000 and total.byte1=11111111
    write 0,total.byte0
    write 1,total.byte1
    If so then in location 0 would be 10000000 and in location 1 would be 11111111
    or is this wrong ?
    if it is right then I can't get that data back the same way ?
    read 0,total.byte0
    read 1,total.byte1
    total=33024
    if not then what ???? I'm more confused then before, but I think your on the right track
    Mar 2005
    Iowa, USA
    total=33024
    Binary(33024) = %1000000100000000
    total.BYTE1 = %10000001
    total.BYTE0 = %00000000
    Quote Originally Posted by PBP Manual
    To write a word, each of the 2 bytes that make up the word must be
    written separately:
    w Var Word
    WRITE 0,w.BYTE0
    WRITE 1,w.BYTE1
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    And there be the logic error I thought I saw earlier...
    Now build you program up and see what happens...then we can work on optimizing that program a bit. I looks a bit of a mess...not too bad, but could be better...
    Jun 2007
    Default just an example,
    thank you for setting me straight, however that didnt answer my question. am i reading the data back to "total" correctly ?
    Did you try it out yet?
    Jun 2007
    Default yep
    Hello skimask
    Yes Ive been working on your suggestion this whole time, But did get side tracked with one of those replys. so here is the conclusion if I take out "IF COINOUT = 1 THEN COINOUT100" from the main loop it works fine. but I dont see what is wrong there. I dont even have any coins going out while I'm testing this to cause a problem. But ive programed the pic and tested it about 4 times now. every time I take it out of the loop it works fine
    COINOUT100:
    PREMIOS=PREMIOS+1
    TOTAL=TOTAL-1
    GOSUB WRITEIT
    GOTO LOOP
    that math was wrong but I figured it out. However even if I take that clear out it still wouldn't write correctly
    A = TOTAL * PERCENT
    A = DIV32 100
    so I keeped working until I came to that conclusion
    here is the code in its cut down version with the problem quoted out
    TRISA = %11011
    TRISB = %11011011
    A VAR WORD
    DONE VAR BIT
    X VAR BYTE
    PERCENT VAR BYTE
    TOTAL VAR WORD
    PREMIOS VAR WORD
    CAMBIO VAR WORD
    MAC VAR BYTE
    T0 VAR TOTAL.byte0
    T1 VAR TOTAL.byte1
    C0 VAR CAMBIO.BYTE0
    C1 VAR CAMBIO.BYTE1
    COINOUT VAR PORTB.0
    COININ VAR PORTB.1
    DONE=0
    PERCENT=50
    DISABLE
    GOSUB READIT
    loop:
    IF PORTB.6 = 1 THEN LLACONECTED
    ' IF COINout = 1 THEN COINOUT100 'this is the problem
    GOTO LOOP
    COUNT1COIN:
    PAUSE 20
    TOTAL=TOTAL+1
    GOSUB WRITEIT
    GOTO LOOP
    LLACONECTED:
    GOSUB READIT
    PAUSE 500
    FOR X=1 TO 5
    GOSUB INFO
    NEXT X
    GOTO BORRAR
    BORRAR:
    IF DONE=0 THEN
    gosub info
    gosub info
    gosub info
    GOTO BORRAR
    BORRAR1:
    TOTAL=0
    PREMIOS=0
    CAMBIO=0
    GOSUB WRITEIT
    FOR X=1 TO 5
    GOSUB INFO
    NEXT X
    GOTO LOOP
    WRITEIT:
    WRITE 0,T0
    WRITE 1,T1
    WRITE 2,P0
    WRITE 3,P1
    WRITE 4,C0
    WRITE 5,C1
    READIT:
    READ 0,T0
    READ 1,T1
    READ 2,P0
    READ 3,P1
    READ 4,C0
    READ 5,C1
    READ 6,MAC
    INFO:
    PAUSE 100
    PAUSE 100
    PAUSE 100
    PAUSE 100
    rETURN
    CNT:
    COUNTER=1
    PAUSE 20
    COUNTER=0
    PAUSE 20
    'COINOUT100:
    ' PREMIOS=PREMIOS+1
    ' TOTAL=TOTAL-1
    ' GOSUB WRITEIT
    'GOTO LOOP
    Try this out:
    TRISA=$1b : trisb=$db : a var word : done var bit : x var byte : percent var byte : total var word : premios var word : cambio var word : mac var byte : t0 var total.byte0 : t1 var total.byte1
    p0 var premios.byte0 : p1 var premios.byte1 : c0 var cambio.byte0 : c1 var cambio.byte1 : coinout var portb.0 : coinin var portb.1 : done=0 : percent=50
    DISABLE
    GOSUB READIT
    loop:
    GOTO LOOP
    COUNT1COIN: PAUSE 20 : IF COININ=1 THEN COUNT1COIN
    TOTAL=TOTAL+1 : GOSUB WRITEIT:GOTO LOOP
    LLACONECTED: gosub readit : pause 500:for x=1 to 5:gosub info:next x : goto borrar
    BORRAR: SERIN2 PORTA.3,16780, 500,BORRAR,[WAIT ("CB"),DEC1 DONE]
    IF DONE=0 THEN
    gosub info:gosub info:gosub info
    GOTO BORRAR
    BORRAR1: total=0 : premios=0:cambio=0:gosub writeit:for x=1 to 5 : gosub info:next x:goto loop
    writeit: write 0,t0:write 1,t1:write 2,p0:write 3,p1:write 4,c0:write 5,c1 : return
    readit: read 0,t0:read 1,t1:read 2,p0:read 3,p1:read 4,c0:read 5,c1:read 6,mac:return
    info: serout2 porta.2,16780,["M",dec3 mac] : pause 100:serout2 porta.2,16780,["T",dec5 total] : pause 100:serout2 porta.2,16780,["P",dec5 premios] : pause 100:serout2 porta.2,16780,["S",dec5 cambio]
    pause 100:return
    CNT: COUNTER=1:PAUSE 20:COUNTER=0:PAUSE 20:RETURN
    COINOUT100:
    PREMIOS=PREMIOS+1:if total > 0 then TOTAL=TOTAL-1
    Last edited by skimask; - 9th June 2007 at 04:06. Reason: Fixed the colons and smiley faces :)
    Get a few more Colon's in there and we're gonna be in deep ____.
    Or have a cancer problem.
    Hangover, Germany
    Exclamation
    What happens, if you switch off the power ?
    Maybe the code just think, the switch is pressed and try to write to the eeprom - while power is falling...
    Jun 2007
    Default BigWumpus's was right !!!
    Yep that is my problem.
    if I take out the "write" it saves fine
    COINOUT100:
    :GOTO LOOP 'GOSUB WRITEIT
    So I did a little checking and the machine I'm interfacing to sends several signals as its lossing power, somthing to do with a cheap design cause theres no other reason. I will buy a scope to see if its a specific signal or just random crap. I think its just random crap cuase if I hook a anolog counter to it, it counts up to differrent amounts somtime 3 somtimes up to 6.
    As to my messy code design, I'm sorry skimask. I have never had any training of any kind nor has anyone ever showed me how to write decent code. This is the first time in 15 years I have ever been on a forum for basic, quickbasic, visual basic, or pic basic pro.
    I am one to learn things on my own, but as you pointed out (at my messy code) that type of learning has its problems. I do my best
    I will continue this forum experience, Its al right. thank you all for your help with this one.
    And thank you BigWumpus for figuring this one out for me......
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 13:06
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
