How to do serial command with 2 stop bits?
Results 1 to 10 of 10
    Dec 2006
    Brasil, Sao Paulo, Campinas
    Question How to do serial command with 2 stop bits?
    Hello,
    I have an aplication that uses 2 stop bits (4800,N,8,2) and I don't know how to do it using PBP compiler.
    It is possible?
    Can you help me please?
    Thanks for your support
    Pimentel
    Stop bits are at "IDLE" level.
    So if you use ...
    DEFINE CHAR_PACING xxx
    where xxx = 1 bit period in us, then you're good to go.
    Dec 2006
    Question Re: How to do serial command with 2 stop bits?
    So if you use ...
    Darrel, Can you help me?
    I restarted my old project and now I need to send a serial data in 4800 TTL levels , 8 data bits and 2 stop bits. How to do it using PBP?
    I have to simulate the second stop bit ok? And 1 bit in 4800 baud ~ 208us
    The 4800 baud is missing in the serout command mode but is possible to use char_pacing in microsenconds
    Using the serout2 command is possible to use a {pace} but just in milisenconds !
    How to do it then???
    Pimentel
    Default Re: How to do serial command with 2 stop bits?
    Pimentel,
    You could try something like this ...Assuming you have PBP 2.60
    DEFINE OSC 8
    BuffLength   CON 32
    Buff         VAR BYTE[BuffLength]
    Idx          VAR BYTE
    SerPin       VAR PORTC.6
    HIGH SerPin
    PAUSE 100
        ARRAYWRITE Buff,["Hello World!",13,10,0]
        GOSUB SendBuff
        PAUSE 1000
    GOTO Main
    SendBuff:
        FOR Idx = 0 TO BuffLength -1
            IF Buff(Idx) = 0 THEN EXIT
            SEROUT2  SerPin,188,[Buff(Idx)]
            PAUSEUS 220
        NEXT Idx
    Dec 2006
    Thanks! I already read this publication but I am using 2 stop bits!!!
    Dec 2006
    Pimentel,
    DEFINE OSC 8
    BuffLength   CON 32
    Idx          VAR BYTE
    SerPin       VAR PORTC.6
    HIGH SerPin
    PAUSE 100
        GOSUB SendBuff
        PAUSE 1000
    GOTO Main
    SendBuff:
            PAUSEUS 220
        NEXT Idx
    Thanks Darrel,
    I am using 2.46 version!
    I will test it idea today on job. I do not know if go work because I already tested it:
    SEROUT2 TX,188,[$00,$50,$42,$01,$0A] 'ex: 14.2500 MHz
    and other mode:
    SEROUT2 TX,188,[$00]: PAUSEUS 208 '1/4800 ~208us
    SEROUT2 TX,188,[$50]:PAUSEUS 208
    SEROUT2 TX,188,[$42]:PAUSEUS 208
    SEROUT2 TX,188,[$01]:PAUSEUS 208
    SEROUT2 TX,188,[$0A]:PAUSEUS 208
    but without sucess!
    Why do you used a pauseus of 220us?
    I used a 4MHz cristal as osc
    Thanks again
    Pimentel
    Dec 2006
    Unhappy Re: How to do serial command with 2 stop bits?
    Quote Originally Posted by Pimentel View Post
    Thanks Darrel,
    and other mode:
    but without sucess!
    Thanks again
    Pimentel
    Darrel,
    The test failed !
    If you or somebody has other idea please let me know, ok?
    Pimentel
    Pimentel , Why not just use 4800 baud, 8 data bits, 1 parity bit , and 1 stop bit? Just dont change the partiy bit's state... It's worked for me in the past...
    Dec 2006
    Smile Re: How to do serial command with 2 stop bits?
    Dave, it seens a god idea. However I never used parity with serout2 command. Can you to post some lines as sample please?
    Pimentel
  1. serout2 with 2 stop bits
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 10th December 2009, 06:21
  2. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  3. Microcontroller with 2 way paging application problem
  4. Defining 2 stop bits using HSEROUT
    By yba2cuo3 in forum Serial
    Last Post: - 25th September 2006, 13:12
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
