I can't beleive this works! :D
Results 1 to 8 of 8
    Aug 2003
    Default I can't beleive this works! :D
    Hi Guys,
    If you connect an LCD as described in the manual, there are exactly seven port pins left on a 16F84/628. A 3x4 matrix
    keypad generaly requires seven pins, but I was able to flog the
    LCD data port for the keypad scan outputs since no program
    will ever scan the keypad and write to the LCD at exactly the same time.. and now there's four spare pins for speakers, switches, etc.
    At the moment, the only hardware bug is holding down three or
    more keys will cause jargon on the display, so I will stay away from keypad combinations for activating menu functions.
    Now I'm thinking it would be better to use the 4 bit LCD data port
    as inputs for the keypad scan routine, and switch back to output
    for the PBP LCD libraries.
    Cheers, Art.
    Post
    Art,
    If you need a couple more pins, you could use the internal oscillator of the 16F628.
    Then if you move the LCD Enable line from RB3 to RA6, you can use the CCP module (HPWM) to control the brightness of the LCD backlight.
    Just an thought.
    Jan 2007
    Default Re: I can't beleive this works! :D
    Very Cool!!!
    Nice project!!!
    Great drawing also!!
    I've been able to save pins on a keypad by using an A/D input and configure the keypad wires to 11 resistors in a series voltage divider ladder.
    No button pressed is a specific voltage output from the resistive divider circuit.
    Every pad button pressed produces its own voltage.
    FUN STUFF!!! :-]
    Hi Art,
    I feel that way every time I make something that works
    Aug 2003
    And it still works ten years later!!
    Should have made a special character for #.
    Aug 2003
    Lol, that would use more memory defining the character,
    and sending it to LCD CGRAM.
    So long as I had the memory, you are right
    I think I could have also flogged pin RA4 to use any time other than when LCDOUT is printing.
    Most importantly, I should not have done this:
    Which is why I'm suprised it STILL works! Too bad if I ever dropped it.
    Now I have to hope this thread get buried again!
    BUMP
    bump
  1. PORTA.0 works, PORTB.7 or .6 do not
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2009, 04:25
  2. AD works in Porta.0 but not in porta.1
    Last Post: - 19th February 2008, 20:22
  3. Replies: 42
    Last Post: - 14th January 2008, 11:38
  4. TMR1 How it works?
    Last Post: - 12th January 2007, 14:24
  5. 16F628A using PORTA.4, and it works, but...
    By zx81 in forum mel PIC BASIC Pro
    Last Post: - 17th August 2005, 08:45
