1 Wire Search Routine
Results 1 to 4 of 4
    Default 1 Wire Search Routine
    A while back I wrote a bit of code to search a 1 WIRE BUS to find the device rom numbers and store them into ram for future use. Attached is the basic routine I used based on the application notes form Dallas Semiconductor. The storage array can be made larger or smaller as you wish. I have successfully been able to locate upto 32 nodes made up of 5 different types of Dallas products. The only thing needs to be added to the program are the LCD Defines. This was written for a 2 X 40 display connected to a 18F452 @ 40 Mhz. After looking at how many times the attached routine was downloaded I decided to put it in the software section. Hope this helps you 1 wire guy's....
    Dave Purola, N8NTA
    Italy
    Default Re: 1 Wire Search Routine
    Hi, I've no experience in getting the info from more than one sensor, but I've found some other approach to the DS18B20.
    Seems that:
    Temp   VAR WORD
    ID        VAR BYTE[8]       '64 bit memory array
    OWOUT Pin, 1, [$33]         'This read the internal eeprom of the sensor
    OWIN Pin, 0,[STR ID\8]      'Save the result into a 8 byte array
    SELECT CASE ID[0]
    	CASE $28
    		'a DS18B20 has been found
    	CASE $10
    		'a DS18S20 has been found
    END SELECT
    OWOUT Pin, 1, [$CC, $44]                        ' Jump the ROM and convert
    PAUSE 900                                       ' Give enough time for conversion (you could reduce it using 10 bit resolution)
    OWOUT Pin, 1, [$CC, $BE]' Jump the ROM and read
    OWIN  Pin, 2, [Temp.Lowbyte, Temp.Highbyte] ' Read 2 bytes
    As said I've not experience in using more than one of those sensor, but probably there is a way to choose wich one using the data of the internal EEPROM.
    If you get some result, please post your experience for future use.
    Oct 2009
    Utah, USA
    There might be something of use for you here...
    http://www.picbasic.co.uk/forum/cont...r-nine-of-them
    Dwight
    Jun 2008
    Varese , Italy
    thanks everybody for the assistance.
    I suggest the indication provided by Heckler:
    Thanks again.
    Ambrogio
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 14:23
