time for PBP statements
Results 1 to 7 of 7
    Mar 2006
    Default time for PBP statements
    Should it be possible to know how much time or clock cycles needs PicBasic Pro compiler to execute every of its statements? I'm specially interested in If..Then..else, High, Low, While ..Wen and For..Next and GoTo
    -Francesc
    Jan 2006
    Istanbul
    Hi Francesc,
    Here is your answer.
    Check this post.
    http://www.picbasic.co.uk/forum/show...ghlight=timer1
    Mar 2006
    Thanks for your answer Sayzer but the thread explains how to measure time elapsed between sentences in a program and what I 'm interested in is to know when programming with Basic how many cycles it takes for every statement I write.
    -Francesc
    May 2006
    Del Rio, TX, USA
    Francesc,
    You might try this include file I was working on and haven't gotten a chance to post. It should be self explianatory (assuming you are carefully reading your PICs datasheet and the PBP manual.
    CodeTimer
    HTH,
    Steve B
    Jan 2006
    Istanbul
    Quote Originally Posted by fnovau
    -Francesc
    Ok, I see.
    But, my curiosity, why would you need to know that information?
    A kind of HW or what?
    -Francesc
    Impossible to know uneless you measure every single statement or a block of.
    How many different IF-THEN-ELSE combination exist?
    How many different HSERIN combination exist?
    How many different LCDOUT combination exist?
    nobody can answer that. So you need to measure everything. Using a internal Timer or an i/o and a scope.
    Now if you add some interupts in the chain... it's quite impossible to know uneless you sim every conditions... good luck!
    -Francesc
    You should take a look at the program SteveB showed in Post# 4.
    It's a great little program that can tie in with "ON DEBUG", and will show the exact time of each individual line of code in your program. It's pretty cool.
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. I don't understand this code!
    Last Post: - 13th February 2008, 02:55
  3. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 30th July 2007, 23:46
  4. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 14:24
