rs485 to rs232 smart switch
Results 1 to 4 of 4
    Dec 2003
    plano, texas usa
    Default rs485 to rs232 smart switch
    I have an application were I need addressable switch to power on a rs232 device and switch on communications to this device. Ther will be 16 devices on this network. My concern is after PIC determines its addressed (valid command on) I need to make communications transparent through PIC ie bi directional from one
    comm port to the other. I am concerned with loosing data and timing etc. I could buffer input / output data but data strings are not more than 256 or so at a time. Any thoghts or comments would be appreciated.
    Thanks in advance
    Scott
    If you don't want to lose data then here's the options...
    1. Have a handshake protocol, (either embedded in software such as XON/XOFF) or in Hardware (such as RTS/CTS) etc. They were invented so that your tetraplegic Cray Supercomputer would not lose data being sent to it from your Golfball teletypewriter. Most folks don't bother with these any more (or have forgotten what they were invented for)... and then when they lose data or discover it's corrupt they cry into their coffee posting messages that it's all diluted and undrinkable.
    2. Ensure the data being received is at a SLOWER speed than the data being transmitted. This has a neat side-effect of saving on having to buffer in the middle.
    3. Ensure that the speed of your PIC is adequate to handle the dataprocessing involved. This usually means you can't run your PIC on a 32kHz watch crystal.
    4. Ensure you have a sufficient data buffer in the middle to handle unexpected situations. Some folks have tried to do this with a 12C509 and wonder why they can't define a 512Mb RAM buffer (probably because they're using an old version of PBP).
    You may need to implement some, any or all of the above.
    Melanie
    Oct 2003
    Australia
    Hi Mel,
    This sounds confusing, are you referring to a slower baud rate for the receiver?
    Squib.
    Exactly. If the receive data is slower than the transmit data, the net result is you're disposing of your data faster than you're receiving it. It also means you have a little processing breather in the middle before the next byte is incomming. If it was the other way around, you start having to buffer your data because it is accumulating faster than it can be disposed of. You are then limited to your buffer size. Now there's nothing wrong with this as long as you know your limitations... if on the other hand your PIC is receiving a 700Mb episode of Enterprise at 600kb and spitting it out at 56kb to a PC, you just might have a teeny buffering problem in the middle...
  1. RS232 to RS485
    Last Post: - 16th October 2008, 15:37
  2. UART vs software RS232
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 5th September 2008, 18:27
  3. Replies: 14
    Last Post: - 26th September 2007, 05:41
  4. Newbie - 16F628A and switch latching
    Last Post: - 19th May 2006, 02:35
  5. RS232 switch, and thank you Mister E
    By Demon in forum Off Topic
    Last Post: - 3rd March 2005, 01:06
