Serial Programmer dead
Results 1 to 7 of 7
    Sep 2003
    Vermont
    Unhappy Serial Programmer dead
    Greetings list,
    I am using the MElabs serial programmer. It worked great for years, until I plugged it in this morning. No green light. I checked all power connections and regulators, but it all tests good. I also get a "no communications" box from the PC I am working with.
    Other than an 18F252 that decided to stop working, any ideas for trouble shooting?
    Ron
    How about the Crystal?
    Q1, Q2, Q3?
    Possible to have a faulty DB9 cable?
    Possible to have some break-link between the DB9 and the circuit?
    Broken pins on the dip socket?
    Do you have a way to check the com port? You might have a bad port.
    Jan 2006
    Istanbul
    Or may be they inserted a secret timer/counter inside the programmer to terminate the life of it; and now it is time to buy a new one.
    I am a great conspiracy theorist!
    Sep 2003
    Vermont
    Sorry, I haven't checked the list in a few hours. I replaced the crystal, and checked the com port. I normally get the green light on power up whether it's hooked up to the PC or not. Does the chip do a diagnostic on the transistors on power up?
    Sep 2003
    Vermont
    Otay... I spoke to Charles at MElabs. He told me that occasionally, the PIC252 just goes astray. About a dozen have, with no aparent cause. I ordered another chip and will update the list if this works. The board is so simple, I can't believe that it won't.
    Thanks for the input,
    Ron
    Sep 2003
    Vermont
    Received the new PIC controller for the serial programmer. Fired it up, and that did the trick. Thanks for the input.
    Ron
  1. usb 24LCxx serial eeprom programmer
    By badrad in forum General
    Last Post: - 6th November 2008, 18:49
  2. Is My Programmer Dead
    By mikendee in forum Off Topic
    Last Post: - 19th March 2008, 16:59
  3. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  4. Wanted: MELABS serial programmer
    By AndrewC in forum Adverts
    Last Post: - 12th September 2007, 12:13
  5. MELABS Serial Programmer help
    By nigelstephens in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2007, 21:01
