real time clock - PCF8583
Results 1 to 15 of 15
    maria's Avatar
    maria Guest
    Default real time clock - PCF8583
    Hi there,
    Does anyone out there have PIC BASIC code to interface a PIC (I'm using the PIC16F877) to a PCF8583 real time clock IC?
    Thanks!
    Maria.
    lupuccio's Avatar
    lupuccio Guest
    Default Pcf 8583
    Anyone can help me ?
    I'm looking for 8583 routines to read and write data in i2c.
    How can i increase minutes and then rewrite to 8583 ?
    Thanks to all.....
    angelika's Avatar
    angelika Guest
    The pins: sda and scl as inputs or outputs to microcontoller?
    If As outputs:
    sda=1 'high the portx.y, x is the port of micr.,y is the bit of portx.
    scl=1 'high the same as previous
    DECLARE HBUS_BITRATE 100 ' and other values
    TRISC=%00000000 'as outputs
    after you try with:hbstart,hbusout,hbstop (in pic basic functions)
    if you have other problem you ask me.
    regards
    this will never work with Melabs. In case it's working... you should have a look on that forum
    Mar 2005
    Novi Sad, Vojvodina
    Hi Maria, Lupuccio and PCF8583 users.
    ' Ime programa: RTC.BAS
    ' Opis: program ilustruje primenu sata realnog vremena PCF8583.
    ' Za povezivanje sa mikrokontrolerom se koristi I2CREAD
    ' naredba.
    DEFINE LCD_DREG PORTD ' I/O port na kome se nalazi LCD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 2 ' Register select pin
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 3 ' Enable pin
    DEFINE LCD_BITS 4 ' 4-bitni data bus
    DEFINE LCD_LINES 2 ' LCD ima dva reda karaktera
    symbol SCL = PORTC.3 ' I2C data pin
    symbol SDA = PORTC.5 ' I2C clock pin
    Sec var bit
    B0 var byte
    S var byte ' Sekunde
    M var byte ' Minuti
    H var byte ' Sati
    D var byte ' Dan
    Mn var byte ' Mesec
    Y var byte ' Godina
    OPTION_REG = $7f ' Omoguci PORTB pullup otpornike
    lcdout $fe,1 ' Obrisi ekran displeja
    I2CREAD SDA,SCL,%10100001,2,[S]
    I2CREAD SDA,SCL,%10100001,3,[M]
    I2CREAD SDA,SCL,%10100001,4,[H]
    I2CREAD SDA,SCL,%10100001,5,[D]
    I2CREAD SDA,SCL,%10100001,6,[Mn]
    I2CREAD SDA,SCL,%10100001,6,[Y]
    lcdout $fe,1 ' Obrisi displej
    lcdout $fe,2 ' Prvi red prvi karakter
    lcdout "Time: ", hex(H),":", hex(M)," ", hex(S)
    lcdout $fe,$c0 ' Drugi red, prvi karakter
    lcdout "Date: ", hex(D),".", hex(Mn),".20",hex(Y)
    Pause 500
    goto Main ' Ponovi sve
    End ' Kraj programa
    lupuccio's Avatar
    lupuccio Guest
    Default 8583
    Thanks to all for the answers.....
    The only problem that i have... ( a big problem ) is set hour and minutes with buttons.
    Unfortunely i haven't the code here.
    Next week i will post my code.
    and then i hope that someone can help me.
    Thanks again to all.
    That's not a problem... learning opportunuities.
    USE I2CWRITE with the same settings as I2CREAD should work
    you just need to test your pushbbuton...
                        '<== Here
    Pause 500
    but certainely better if you use something like
    While Delay<5000 ' Delay loop of 500 mSec
         ' Select case pushbutton and set/hour time here+I2CWRITE
         ' if there's no push button pressed Do a PAUSEUS 100 and increment
         ' Delay Variable.
         Wend
    yeah just an idea. not everything on a plate and you'll have to do some homework around the above.
    Feb 2004
    Germany
    The PCF8583 is very similar to DS1307.
    Melanie has written an excellent example for the DS1307.
    click here for MN1307.txt
    It should work on the PCF8583 with very small modifications.
    regards
    Ralph
    lupuccio's Avatar
    lupuccio Guest
    Default here's the code.
    part is mine and part i' have found on the net.
    with my circuit it works
    Thanks to all.
    device = 16f876A
    xtal = 4
    CONFIG XT_OSC , WDT_OFF , PWRTE_ON , BODEN_OFF , LVP_OFF , CP_OFF , DEBUG_OFF
    LCD_DTPIN portb.4 ' dati lcd
    LCD_RSPIN portb.1 ' register select
    LCD_ENPIN portb.3 ' enable lcd 1
    LCD_INTERFACE 4 ' interfaccia lcd 4 bit
    LCD_LINES 2 ' linee lcd
    DECLARE SDA_PIN PORTC.4
    DECLARE SCL_PIN PORTC.3
    '*** variabili ************************************************** ***************
    delayms 200 'stabilizza LCD
    cls
    dim bcd_to_bin 'variable used in BCD and Binary conversion routines
    dim low_bits 'low byte for Binary to BCD routine
    dim high_bits 'high byte for Binary to BCD routine
    dim pcf8583_address 'pcf8583 internal registers address(2=seconds,3=minutes etc.)
    Dim second as byte
    Dim minute as byte
    Dim hour as byte
    dim setup as byte
    symbol clkout=%10100000 'set the 8583 to receive data
    symbol clkin=%10100001 'set the 8583 to transmit data
    Symbol button1 = portc.0
    Symbol button2 = portc.1
    Symbol button3 = portc.2
    pcf8583_address = 0
    setup = 0
    second = 0
    minute = 0
    hour = 0
    cls
    delayms 200
    ' qui inizia il programma che legge dal 8583
    C_upd:
    '*** Visualizzazione ora ************************************************** *****
    busin %10100001,2,[second,minute,hour]
    pcf8583_address = 2:gosub read_time 'read seconds data from 8583
    second=bcd_to_bin 'convert to binary
    pcf8583_address = 3:gosub read_time 'read minute data from 8583
    minute=bcd_to_bin 'convert to binary
    pcf8583_address = 4:gosub read_time 'read hour data from 8583
    hour=bcd_to_bin 'convert to binary
    print at 1,5, dec2 hour,":",dec2 minute,":",dec2 second
    '*** menu start
    if button1 = 0 then inc setup
    if setup = 1 then goto set_min
    if setup = 2 then goto set_hour
    if setup > 2 then
    print at 2,1," "
    setup = 0
    goto C_upd
    set_min:
    print at 2,5,"Set Min "
    if button2 =0 then
    busin clkin,3,[bcd_to_bin] 'leggi i minuti
    gosub conv_to_bin ' li converte in binario
    inc bcd_to_bin
    if bcd_to_bin > 59 then bcd_to_bin = 0
    delayms 100
    gosub convert_to_bcd
    busout clkout,3,[bcd_to_bin]
    delayms 10
    goto c_upd
    set_hour:
    print at 2,5,"Set Hour"
    if button2 =0 then
    busin clkin,4,[bcd_to_bin] 'leggi le ore
    inc bcd_to_bin
    if bcd_to_bin > 23 then bcd_to_bin = 0
    delayms 100
    busout clkout,4,[bcd_to_bin]
    delayms 10
    goto c_upd
    '*** antirimbalzo ************************************************** ************
    'Debounce: DELAYMS 200
    ' Update=1
    ' goto c_upd
    ' legge il dato dall'indirizzo puntato da "pcf8583_address"
    ' il dato viene memorizzato nella variabile "bcd_to_bin"
    read_time:
    busin clkin,pcf8583_address,[bcd_to_bin]
    gosub conv_to_bin
    ' Questa routine converte il byte da binario a decimale e lo carica nella
    ' variabile "bcd_to_bin" e lo ritorna nella stessa variabile "bcd_to_bin"
    ' Se il valore è "9" o meno, non fa nulla perche in BCD o BIN sono uguali.
    conv_to_bin:
    select bcd_to_bin
    case 16 to 25
    bcd_to_bin=bcd_to_bin-6
    case 32 to 41
    bcd_to_bin=bcd_to_bin-12
    case 48 to 57
    bcd_to_bin=bcd_to_bin-18
    case 64 to 73
    bcd_to_bin=bcd_to_bin-24
    case 80 to 89
    bcd_to_bin=bcd_to_bin-30
    case 96 to 105
    bcd_to_bin=bcd_to_bin-36
    case 112 to 121
    bcd_to_bin=bcd_to_bin-42
    case 128 to 137
    bcd_to_bin=bcd_to_bin-48
    case 144 to 153
    bcd_to_bin=bcd_to_bin-54
    endselect
    ' Conversione da binario a BCD
    ' Il byte convertito viene caricato nella variabile bcd_to_bin
    ' e viene restituito nella stessa variabile bcd_to_bin
    convert_to_bcd:
    low_bits=bcd_to_bin//10 'get lsb,same for Bin and BCD
    high_bits=bcd_to_bin/10 'get msb
    bcd_to_bin=high_bits*16 'convert msb to BCD
    bcd_to_bin=bcd_to_bin+low_bits 'add BCD msb and lsb together
    Default Help from FDAI - Brazil
    Dear friends, Maria and all:
    My name's Francisco Fambrini and
    I am a Brazilian Electronic Engineer and my website is www.fdai.net
    I would like to help my friends that have problems with PCF8583 and Melabs PICBasicPRO
    My code for this :
    ' PCF 8583 APREDENDO_1.0
    ' programa para testar o chip PCF8583
    ' na placa do Distribuidor de Energia
    ' 26/Fev/2006
    define OSC 20
    DEFINE ADC_BITS 10
    define ADC_CLOCK 1
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    symbol SCL = PORTC.3 ' I2C clock
    symbol SDA = PORTC.5 ' I2C data
    symbol UP = PORTA.4
    SYMBOL DOWN = PORTA.3
    SYMBOL ENTER = PORTA.2
    SYMBOL SEL = PORTA.1
    ; Configuração do PIC
    TRISA=%00111111
    TRISB=%00000000
    TRISC=%00100000
    TRISD=%00000000
    ADCON1 = $0E 'Configura somente RA0 como entrada de AD
    PORTB=%00000000
    PORTC=%00000000
    PORTD=%00000000
    ' VARIAVEIS DO PROGRAMA
    HOUR VAR BYTE
    MINUTE VAR BYTE
    DAY VAR BYTE
    MONTHY VAR BYTE
    YEAR VAR BYTE
    S VAR BYTE
    M VAR BYTE
    H VAR BYTE
    D var byte
    Mn var byte
    Y var byte
    TEMPO VAR WORD
    lcdout $fe,1 'limpa o display
    Pause 500
    lcdout "PCF8583 Aprender"
    Lcdout $fe,$c0
    LCDOUT "FDAI Eletronica"
    Pause 1500
    Pause 100
    I2CREAD SDA,SCL,%10100001,7,[Y]
    IF PORTA.1=0 THEN GOSUB ACERTAR
    lcdout $fe,1 'Limpa o LCD
    lcdout $fe,2 'cursor n primeira posição
    lcdout "Hora: ", hex(H),":", hex2(M),":", hex2(S)
    lcdout $fe,$c0 'segunda linha do display
    lcdout "Data: ", hex2(D),".", hex2(Mn),".20",hex2(Y)
    Pause 500
    goto Main 'VOLTA PARA O LOOP PRINCIPAL
    ' Rotina de ajuste do relogio RTC
    ACERTAR:
    lcdout $fe,1
    Lcdout "Acertar hora"
    Pause 1000
    TEMPO = 1000
    'Verifica se algum botao de ajuste foi pressionado:
    VER_BOTOES:
    IF TEMPO =0 THEN
    GOSUB GRAVAR_HORARIO
    tempo = tempo -1
    ' Checa se algum botao de ajuste de h/min foi pressionado
    If PORTA.3 = 0 Then decmin
    If PORTA.4 = 0 Then incmin ' Last 2 buttons set minute
    If PORTA.1 = 0 Then dechr
    If PORTA.2 = 0 Then inchr ' First 2 buttons set hour
    pause 50
    Goto VER_BOTOES
    ' Increment minutes
    incmin: minute = minute + 1
    If minute >= 60 Then
    minute = 0
    Endif
    Goto debounce
    ' Increment hours
    inchr: hour = hour + 1
    If hour >= 24 Then
    hour = 0
    Endif
    Goto debounce
    ' Decrement minutes
    decmin: minute = minute - 1
    minute = 59
    Endif
    Goto debounce
    ' Decrement hours
    dechr: hour = hour - 1
    If hour >= 24 Then
    hour = 23
    Endif
    goto debounce
    'essa é uma parte da rotina de acerto do relogio
    debounce: 'atualiza o relogio na tela na hora do acerto do relogio
    pause 200
    tempo= 90
    lcdout $fe,1
    Lcdout $fe,2
    Lcdout "Acerte Horario:"
    lcdout $fe,$c0
    Lcdout dec2 hour, ":", dec2 minute, ":00"
    goto VER_BOTOES
    GRAVAR_HORARIO:
    'Converte para Hexadecimal
    DAY = 26
    MONTHY = 4
    YEAR=06
    M = MINUTE/10*16 + MINUTE//10
    H= hour/10*16 + hour//10
    D= DAY/10*16 + DAY//10
    Mn= MONTHY/10*16 + MONTHY//10
    Y = YEAR/10*16 + YEAR//10
    I2cwrite SDA,SCL,%10100001,2,[0]
    I2Cwrite SDA,SCL,%10100001,3,[M]
    I2Cwrite SDA,SCL,%10100001,4,[H]
    I2CWRITE SDA,SCL,%10100001,5,[D]
    I2CWRITE SDA,SCL,%10100001,6,[Mn]
    I2CWRITE SDA,SCL,%10100001,7,[Y]
    Apr 2010
    Default can you help my?
    I'm trying to make a propeller clock with 22 LEDs and was wondering if I can help with handcuffs programming ...... in part to pass the information that the PCF8583 fornesi my PIC (16F877) and passes it to the LEDs ... was shackled to help me say something ... thanks
    ps.: I'm working with miKroC
    Wink Better hit the dedicated door ...
    Hi, East
    You could find much better help on the ... MikroC Forum.
    Here: http://www.mikroe.com/forum/viewforum.php?f=13
    Don't you think ???
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by EAST___ View Post
    So why post on a forum that deals with picBASIC
    Dear EAST
    a "propeller clock with 22 LEDs" is a diferent project.
    It´s not similar than LCD clock, like my code was describe.
    I am sorry, but it's very dferent.
    Apr 2010
    Default Thanks
    Thanks to all...
  1. real time clock
    By maria in forum Code Examples
    Last Post: - 1st March 2022, 12:13
  2. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 04:52
  3. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 16:05
  4. Real Time Clock
    Last Post: - 8th December 2006, 02:02
  5. Real time clock... what a headache!
    Last Post: - 8th June 2006, 21:56
