serial comm to C328 camera module
Results 1 to 3 of 3
    mxkeene's Avatar
    mxkeene Guest
    Question serial comm to C328 camera module
    Has anyone had any experience with the c328 Jpeg camera module? I'm trying to connect to it with a PIC18f2420 running at 40mhz using the standard serout2 command.
    The waveform of the serial command appears to be identical to what is specified in the documentation, but I'm not getting any response from the camera. I've gone over all the specs very carefully, but I'm not getting anywhere.
    Anyone out there have success with this?
    mxkeene's Avatar
    mxkeene Guest
    Wink Ok, figured it out...
    I found that my osc define was incorrect. Duhh! Seems like it makes a difference between osc and OSC for the define.
    So, for everyone having trouble with serial or pause timing problems, double check your oscillator define and make sure it is in uppercase.
    I'm surprised that the compiler didnt give an error for this, it just ignored the define.
    live and learn...
    nesl7998's Avatar
    nesl7998 Guest
    Default Issues syncing
    I am trying to sync a C328 module with a PIC24FJ128 as well as a PIC18F97J60 and have been unsuccessful. My signal appears correct according to the documentation, but I am not receiving a response from the module. I am transmitting/receiving through UART1. What do you think is the problem? Also, would you be able to send your working code so that I might see where I went wrong?
  1. Serial comm between two PICs
    By ALFRED in forum Serial
    Last Post: - 13th March 2014, 23:22
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  3. PIC16F877 to RFID Module Serial Interface
    Last Post: - 17th May 2005, 06:03
  4. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 4th April 2004, 23:58
