PFC8583 Connection and I2Cwrite I2cread!
Results 1 to 12 of 12
    Apr 2005
    Exclamation PFC8583 Connection and I2Cwrite I2cread!
    I want to use PFC8583 . But i coludn't get/set any data .
    I tried
    i2cread sda,scl,$A2,2,[S]
    i2CWrite sda,scl,$A2,4,[H]
    andi changed $A2 =%10100010 ------> %10100001..
    and what must be min configuration for connecting PFC!
    I connected scl and SDA pin!
    sec var bit
    S var byte
    M var byte
    H var byte
    SCL var PORTB.0
    SDA var PORTA.4
    Read 4,H
    pause 20
    Read 3,M
    i2CWrite sda,scl,$A2,3,[M]
    pause 20
    call Display_clock
    Display_Clock:
    toggle sec
    i2cread sda,scl,$A2,3,[M]
    i2cread sda,scl,$A2,4,[H]
    'i2cread sda,scl,$A2,5,[D]
    'i2cread sda,scl,$A2,6,[Mn]
    'i2cread sda,scl,$A2,7,[y]
    LCDout $FE,$C0
    if sec=0 then
    lcdout hex(H),":",hex(M),":",hex(S)
    lcdout hex(H)," ",hex(M)," ",hex(S)
    thx
    Apr 2005
    "and what must be min configuration for connecting PFC!
    I connected scl and SDA pin!"
    Did you put two resistors tied to VDD??
    roberto
    Apr 2005
    i connected resistors..
    i couldn't read and write clock data from PFC?
    ps: i read previous topics but i couldn't find solution ...
    Apr 2005
    i started to read PFC
    these codes works properly !!
    i2cread sda,scl,$A2,2,[S] 'sec
    i2cread sda,scl,$A2,3,[M] 'minute
    i2cread sda,scl,$A2,4,[H] 'hour
    but i couldn't set time ?
    i want to set "18:59" time to PFC but this code didn't work ?
    M = 45
    H = 18
    i2cwrite sda,scl,$A2,2,[S] 'sec
    i2cwrite sda,scl,$A2,3,[M] 'minute
    i2cwrite sda,scl,$A2,4,[H] 'hour
    Aug 2005
    South Africa
    You should use $A1 or $A0 as far as I know...
    Is you control register set to the right value??
    I2CWrite DPIN,CPIN, $A1,$00,[ $09 ] ( See datasheets for the value you need)
    Apr 2005
    thx!
    i can read and setup time !
    but , clock counts very slow !! I couldnt adjust with variable condansator !!
    please help !!
    Dec 2005
    Corum,Turkiye
    Default hi Uludere
    i dont understand why it "slow" .. ..
    you write me..
    Hocam merhaba...
    Pcf de sorun yaşamaman lazım.. Ben ikisinide kullandım. ds1307 veya pcf8583 problemsiz entegreler bunlar. bana sıkıntını tam yazarsan yardımcı olabilirim.
    Elektroline
    www.labarna.com
    [email protected]
    Apr 2005
    thx elektroline!!
    i am going to send my problem on monday !!
    Apr 2005
    Default ds1302 AND pfc8583
    pfc 8583 is counting 1 minute in 2 minute ?
    and second is counting to 99?
    Wink Help from Brazil
    Hi, I am a Brazilian Electronic Engineer and my website is www.fdai.net
    I would like to help my friends that have problems with PCF8583 and Melabs PICBasicPRO
    My code for this :
    ' PCF 8583 APREDENDO_1.0
    ' programa para testar o chip PCF8583
    ' na placa do Distribuidor de Energia
    ' 26/Fev/2006
    define OSC 20
    DEFINE ADC_BITS 10
    define ADC_CLOCK 1
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    symbol SCL = PORTC.3 ' I2C clock
    symbol SDA = PORTC.5 ' I2C data
    symbol UP = PORTA.4
    SYMBOL DOWN = PORTA.3
    SYMBOL ENTER = PORTA.2
    SYMBOL SEL = PORTA.1
    ; Configuração do PIC
    TRISA=%00111111
    TRISB=%00000000
    TRISC=%00100000
    TRISD=%00000000
    ADCON1 = $0E 'Configura somente RA0 como entrada de AD
    PORTB=%00000000
    PORTC=%00000000
    PORTD=%00000000
    ' VARIAVEIS DO PROGRAMA
    HOUR VAR BYTE
    MINUTE VAR BYTE
    DAY VAR BYTE
    MONTHY VAR BYTE
    YEAR VAR BYTE
    S VAR BYTE
    M VAR BYTE
    H VAR BYTE
    D var byte
    Mn var byte
    Y var byte
    TEMPO VAR WORD
    lcdout $fe,1 'limpa o display
    Pause 500
    lcdout "PCF8583 Aprender"
    Lcdout $fe,$c0
    LCDOUT "FDAI Eletronica"
    Pause 1500
    Pause 100
    I2CREAD SDA,SCL,%10100001,2,[S]
    I2CREAD SDA,SCL,%10100001,3,[M]
    I2CREAD SDA,SCL,%10100001,4,[H]
    I2CREAD SDA,SCL,%10100001,5,[D]
    I2CREAD SDA,SCL,%10100001,6,[Mn]
    I2CREAD SDA,SCL,%10100001,7,[Y]
    IF PORTA.1=0 THEN GOSUB ACERTAR
    lcdout $fe,1 'Limpa o LCD
    lcdout $fe,2 'cursor n primeira posição
    lcdout "Hora: ", hex(H),":", hex2(M),":", hex2(S)
    lcdout $fe,$c0 'segunda linha do display
    lcdout "Data: ", hex2(D),".", hex2(Mn),".20",hex2(Y)
    Pause 500
    goto Main 'VOLTA PARA O LOOP PRINCIPAL
    ' Rotina de ajuste do relogio RTC
    ACERTAR:
    lcdout $fe,1
    Lcdout "Acertar hora"
    Pause 1000
    TEMPO = 1000
    'Verifica se algum botao de ajuste foi pressionado:
    VER_BOTOES:
    IF TEMPO =0 THEN
    GOSUB GRAVAR_HORARIO
    tempo = tempo -1
    ' Checa se algum botao de ajuste de h/min foi pressionado
    If PORTA.3 = 0 Then decmin
    If PORTA.4 = 0 Then incmin ' Last 2 buttons set minute
    If PORTA.1 = 0 Then dechr
    If PORTA.2 = 0 Then inchr ' First 2 buttons set hour
    pause 50
    Goto VER_BOTOES
    ' Increment minutes
    incmin: minute = minute + 1
    If minute >= 60 Then
    minute = 0
    Endif
    Goto debounce
    ' Increment hours
    inchr: hour = hour + 1
    If hour >= 24 Then
    hour = 0
    Endif
    Goto debounce
    ' Decrement minutes
    decmin: minute = minute - 1
    minute = 59
    Endif
    Goto debounce
    ' Decrement hours
    dechr: hour = hour - 1
    If hour >= 24 Then
    hour = 23
    Endif
    goto debounce
    'essa é uma parte da rotina de acerto do relogio
    debounce: 'atualiza o relogio na tela na hora do acerto do relogio
    pause 200
    tempo= 90
    lcdout $fe,1
    Lcdout $fe,2
    Lcdout "Acerte Horario:"
    lcdout $fe,$c0
    Lcdout dec2 hour, ":", dec2 minute, ":00"
    goto VER_BOTOES
    GRAVAR_HORARIO:
    'Converte para Hexadecimal
    DAY = 26
    MONTHY = 4
    YEAR=06
    M = MINUTE/10*16 + MINUTE//10
    H= hour/10*16 + hour//10
    D= DAY/10*16 + DAY//10
    Mn= MONTHY/10*16 + MONTHY//10
    Y = YEAR/10*16 + YEAR//10
    I2cwrite SDA,SCL,%10100001,2,[0]
    I2Cwrite SDA,SCL,%10100001,3,[M]
    I2Cwrite SDA,SCL,%10100001,4,[H]
    I2CWRITE SDA,SCL,%10100001,5,[D]
    I2CWRITE SDA,SCL,%10100001,6,[Mn]
    I2CWRITE SDA,SCL,%10100001,7,[Y]
    Aug 2005
    South Africa
    Please give your code... It will be easier to see your problem ...
    Apr 2005
    here is my PFC code!!
    I solved my problem changin PFC8583 to DS1302 :-)
    Define LOADER_USED 1
    ;Define OSC 20
    Define LCD_DREG PORTD ' Define LCD connections
    Define LCD_DBIT 4
    Define LCD_RSREG PORTE
    Define LCD_RSBIT 0
    Define LCD_EREG PORTE
    Define LCD_EBIT 1
    SCL var PORTC.1
    SDA var PORTC.3
    UP var PORTB.0
    DOWN var PORTB.1
    temp var word
    count_remain var byte
    countPerC var byte
    Menusay var Byte
    LoBATT var byte
    TMP var byte
    sec var bit
    'B0 var byte
    S var byte
    M var byte
    H var byte
    D var byte
    W var byte
    Mn var Byte
    Y var byte
    'ADCON1=7
    'pause 100
    s=0
    M=0
    h=0
    d=0
    W=0
    Mn =0
    Y = 0
    adval var byte ' Create adval to store result
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %00000100 ' Set PORTA analog
    Low PORTE.2 ' LCD R/W line low (W)
    Pause 100 ' Wait for LCD to start up
    OPTION_REG.7=0 ' pull direncleri aktif
    TRISB=%00001111
    PORTB=0
    ADCON1=7
    I2Cwrite SDA,SCL,$A2,2,[S,m,h,d,W,MN,Y]
    pause 50
    ' goto main
    'Lcdout $fe, 1 ' Clear screen
    Lcdout $fe, 1 ,"Clock" ' Clear screen
    TRISA=%00001110 ' port a 0 cıkıs 1 giris yapıldı
    LOW PortA.0
    menusay=0
    mainloop:
    if UP = 0 then
    pause 50
    IF MenuSay < 3 then
    Menusay = Menusay+1
    Lcdout $fe, 1,"MENU", dec menusay
    Gosub SetupMenu
    menusay=0
    if menusay = 0 then
    GOsub SAAT
    Goto mainloop ' Do it all forever
    ''' SAAT RUTINI
    SAAT:
    ' Lcdout $fe, 1, " OKUNUYOR"
    ' pause 1000
    toggle sec
    i2cread sda,scl,$A1,2,[S] 'sn
    i2cread sda,scl,$A1,3,[M] 'dakika
    i2cread sda,scl,$A1,4,[H] 'saat
    Lcdout $fe, $c0,"Saat:",hex2 (H),":",hex2( M),":",Hex2 (S )
    pause 250
    SetupMenu:
    Select Case MenuSay
    'Case 1; Baslangis sicakligi
    case 1 ; Saat Ayar
    DevamSaat:
    'Read 4,H ' epprom 1
    'Lcdout $fe, 1,"S :" ,Dec (H)
    ' call RTC_write
    Gosub ArtirAzalt
    IF up = 0 and down=0 then goto CikisSaat
    goto DevamSaat
    cikisSaat:
    Lcdout $fe, 1,"SET :S:" ,Dec (H)
    'gosub RTCWrite
    I2Cwrite SDA,SCL,$A1,4,[h]
    pause 250
    case 2 ; dakika ayar
    DevamDakika:
    Gosub ArtirAzalt
    ' i2CWrite sda,scl,$A2,3,[M] 'saat
    IF up = 0 and down = 0 then goto CikisDakika
    goto DevamDakika
    cikisDakika:
    Lcdout $fe, 1,"Dk Set"
    'gosub rtcWrite
    I2Cwrite SDA,SCL,$A1,3,[m]
    pause 250
    'Case 4 ; Gun Ayarla
    'Case 5 ; Ay ayarla
    Case 3 ;save
    Lcdout $fe, 1,"Setup OK"
    menusay = 0
    end select
    ;Azaltma Artirma Rutinleri
    ArtirAzalt:
    ;Sıcalik Artir
    Select Case Menusay
    case 1 ' Saat
    if up = 0 then
    pause 50
    if H = 23 then
    H =0
    H = H + 1
    If Down = 0 then
    pause 50
    if H = 0 then
    H = 23
    H = H -1
    Endif
    Lcdout $fe, 1,"Saat", dec H
    pause 250
    case 2 ' Dakika
    if up=0 then
    pause 50
    if m = 59 then
    m =0
    m = m + 1
    If Down = 0 then
    pause 50
    if M = 0 then
    M = 59
    m = m -1
    Endif
    Lcdout $fe, 1,"Dakika", dec M
    pause 250
    end select
    RTCWrite:
    tmp=S
    S=(tmp dig 1<<4)+(tmp dig 0)
    tmp=M
    M=(tmp dig 1<<4)+(tmp dig 0)
    tmp=H
    H=(tmp dig 1<<4)+(tmp dig 0)
    tmp=D
    D=(tmp dig 1<<4)+(tmp dig 0)
    tmp=MN
    MN=(tmp dig 1<<4)+(tmp dig 0)
    tmp=Y
    Y=(tmp dig 1<<4)+(tmp dig 0)
    I2CWRITE SDA,SCL,$A1,2,[S,M,H,D,W,MN,Y] 'Write parameters to RTC
    pause 50
  1. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 14:01
