Instant Interrupts - Revisited - Page 5
Page 5 of 20 FirstFirst 12345678915 ... LastLast
Results 161 to 200 of 773
  1. #161
    sougata,
    I'm glad it's working out for you. And yes, it is more managable. Kinda the whole idea behind it.
    Squibcakes,
    No, it doesn't work that way.
    The AD_INT is fired on the completion of an A/D conversion. Not when the value changes.
    So, in your AD_INT handler, you could test to see if the recent A/D reading differs from the previous A/D value. If it does, call a subroutine.
    Then start another conversion before exiting the handler.
    Added: Or like sougata said, have a timer periodicaly start a conversion, then do the same.
    HTH,
    Oct 2003
    Australia
    Hmm,
    That kind of defeats the purpose of what I wanted to do....
    All understood and thanks for the info.
    Rgds,
    Squib
  3. #163
    Feb 2005
    Kolkata-India
    Default Use your compare module in special event trigger
    Hi Squibcakes,
    You can use your compare module to automatically fire your ADC at a given interval. So the ADC will automatically generate interrupts. In your interrupt routine compare the current value with the old value. Keep some margin as two consecutive results may be different even if your pot is unchanged. When a change is found set a flag and process it in your main loop.
    Sougata
  4. #164
    Question Darrels' Bring Together Interrupts
    Hello,
    I have been toying with Darrels' interrupts and the elapsed timer
    programs. It's an amazing piece of work and just what I need at the
    moment. Thanks!
    Going on, I tried the "bring together" demo but that didn't go so
    well. It won't compile using MPASM. The error messages are ;
    FATAL ERROR too many errors
    Error line 15: redefination of VAR. (DT_INTS-14.bas)
    Error line 26: redefination of VAR. (DT_INTS-14.bas)
    Error line 27: redefination of VAR. (DT_INTS-14.bas)
    ........Etc.
    I am using the Pic 16f877 but that shouldnt matter at this point.
    Any ideas?
    Thanks John
    Homerclese
  5. #165
    mmm, weird, no problem here. so we talk about
    http://darreltaylor.com/DT_INTS-14/combine.html
    If so, did you add something special in the code or you're using EXACTLY the following...
    LED1   VAR  PORTD.0
    LED2   VAR  PORTD.1
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    INCLUDE "Elapsed_INT.bas"    ' Elapsed Timer Routines
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
            INT_Handler   TMR0_INT,  _ToggleLED2,   PBP,  yes
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    OPTION_REG = OPTION_REG & $80 | 1  ; Set TMR0 Prescaler to 256, leave RBPU alone
    @    INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    @    INT_ENABLE  TMR0_INT     ; enable Timer 0 interrupts
    @    INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    GOSUB ResetTime              ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer             ' Start the Elapsed Timer
        IF SecondsChanged = 1 THEN
           SecondsChanged = 0
           LCDOUT $FE,$C0, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    '---[TMR0 - interrupt handler]-------------------------------(Blinky Light)------
    T0Count  VAR WORD
    ToggleLED2:
        T0Count = T0Count + 1
        IF T0Count = 512 THEN T0Count = 0 : TOGGLE LED2
    @ INT_RETURN
    which version of PBP and MPASM are you using?
    Are all files located in the same folder?
  6. #166
    Question
    Hello,
    I tried a cut and paste of your code and got a whole new set of errors. The only code differences I could find were the ones at the top for outputting to a LCD display. The include files all exist in my usual PBP folder. I'm using Microcode Studio version 2.2.1.1 with Pic Basic Pro 2.40.
    Thanks John
    Homerclese
  7. #167
    did you get...
    <img SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1438&stc=1&d=117284877 8">
    If so, make sure you have selected MPASM in the View>> Compile And Program option >>> Assembler
    EDIT
    Pic Basic Pro 2.40.
    I don't know if it could be the problem... The current version is now 2.47.
  8. #168
    Question
    Gettin' better!
    MPASM box was not checked. I didn't know it existed. No errors on compile now, however it can not find the .HEX file for programming. I did a system search and there is no .HEX file generated after compile. There are .HXH and .HXL files.
    Is your result box a screen capture?
    Thanks again
    Homerclese
  9. #169
    It happen because you probably have selected INH8XS file format under the MPASM check box. use INHX8M instead.
    Yes indeed, CTRL + PrintScr, then you paste it in Paint or whatever else to edit it.
  10. #170
    Question
    Good, That worked. However, when I add a line to the top of the program as simple as :
    TRISA = %00000000
    AlarmOUT VAR PORTA.0
    I get
    Error[113 cbp\pbpic14.lib 1588 : Symbol not previously defined (port A)
    Error[113 cbp\pbpic14.lib 1612 : Symbol not previously defined (port A)
    Error[113 cbp\pbpic14.lib 1619 : Symbol not previously defined (port A)
    .........Etc.
    Also, going back to the previously working "elapsed timer demo" and using the MPASM settings I get the same type of errors there if I try to add a port reference.
    I can get the result box into Photoshop but can't get the edited image to paste into the forum.
    Homerclese
  11. #171
    <table><td></td><td>It really drives me nuts when it work here but not elsewhere. Ok then just copy/paste your code here and place it between code bracket. you just need to type...
    [code]
    ---paste your code here---
    [/code]
    to edit your screen capture, use Windows paint. If you don't find it, click on Start> run then type mspaint. then save it to a .jpg file</td></table>
  12. #172
    Quote Originally Posted by Homerclese View Post
    TRISA = %00000000
    I get
    .........Etc.
    You said you were using the 16F877. Are you sure it's not the 16F877A?
    'cause if it is, you need to upgrade your PBP. You said you've got PBP 2.40. The 16F877A isn't supported until PBP 2.42
  13. #173
    Unhappy
    "Not previously defined" error was caused by having PortA instead of PORTA. It's 4AM and I think MPASM is the cause of some strange chip behavior. Only when I uncheck MPASM do I get back to a working 16F877 chip. I patched pic basic Pro to 2.40 but any attempts to go higher are met with "unknown version" errors. I'll hit it again tommorrooowww....
    "Homer sleep now".
    Homerclese
  14. #174
    somehow strange but you could still try to uncheck the Case Sensitive option in MCS.
  15. #175
    Aug 2005
    Darrel,
    I recently replaced the On Interrupt code in an existing program with the RX_INT and it works great.The code was reduced by 127 words and I was able to eliminate a interrupt anomaly I sometimes experienced.Though compilation was successful,I would get a warning "Temp variables exceeding T4",which was generated in the ReEnterPBP.bas.I found what caused it in my code was this long comparison evaluation "if (fwd_cycle_comp = 1 and portb.4 = 1 and portb.2 = 1 and porta.0 = 1) or (datain1 > 1638) then".If I shortened the code the warning disappeared.Since everything was working fine I commented out the error routine for T4.I am using the latest Mplab and PBP.
    Thanks & Good Job
  16. #176
    Quote Originally Posted by arniepj View Post
    As long as the long formula isn't in the Interrupt Handler, you should be OK.
    There's no way for the program to tell if a complex formula is in the handler or somewhere else. So I err'd on the side of caution and had it give a warning no matter where it is.
    Glad you like it.
    Maybe on POST 116 which is few time after the Green splat thingy
    http://www.picbasic.co.uk/forum/show...&postcount=116
  18. #178
    Mar 2006
    Smile DT_INTS with MPLAB 7.50
    Good day to all!!!
    I'm Ryan from the philippines i've been wanting to use my homebuilt icd2 but i'm having a hard time compiling my sourcecode with Darrel's instant interrupt in MPLAB has anyone tried and successfully compiled it in MPLAB?
    To anyoneThanks in advance!!!
  19. #179
    is this happen to ANY PBP program or just when using DT-INT.
    I don't know why it shouldn't. can you at least post some code OR the errors message + PIC#
  20. #180
    Mar 2006
    Default here it is
    Yes indeed just when using dt_ints it fails to compile here are the following error message
    "Executing: "C:\PBP\PBPW.EXE" -p16F877A -ampasm -oq -z "SMS_CONTROL1_MPLAB.bas"
    Error[113] C:\PBP\PBPPIC14.LIB 2784 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2785 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2789 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2790 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2800 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2871 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2889 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2913 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2920 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2928 : Symbol not previously defined (PortD)
    Error[113] C:\PBP\PBPPIC14.LIB 2934 "
    Quote Originally Posted by leisryan View Post
    Which version of PBP?
  22. #182
    The problem is due to your LCD DEFINES
        		' 	LCD Display
        	DEFINE LCD4X20
        	DEFINE LCD_DREG	       	PortD		' Set LCD Data to PortD
        	DEFINE LCD_DBIT	       	0		    ' Set starting Data to Bit0
          	DEFINE LCD_EREG	       	PortD		' Set LCD Enable to PortC
        	DEFINE LCD_EBIT        	5		    ' Set LCD Enable line to PortC.1
        	DEFINE LCD_RSREG       	PortD		' Set LCD Register Select to PortB
        	DEFINE LCD_RSBIT       	4		    ' Set LCD RS line to PORTC.0
        	DEFINE LCD_BITS	       	4		    ' Set for a 8 bit Bus
    Always make sure that ALL DEFINEs are properly written. you MUST use PORTD in uppercase.
  23. #183
        		' 	LCD Display
        	DEFINE LCD4X20
    Of course! That's right! Just like it says in the PBP manual on page 30!
  24. #184
    and one suggestion, add
    @ errorlevel -306
    as MPLAB output list a $%$%^ load of those annoying...
    Message[306] C:\PBP\PBPPIC14.LIB 624 : Crossing page boundary -- ensure page bits are set.
  25. #185
    Mar 2006
    Smile thanks guys!!!
    thanks Mr. E!!! thanks skimask!!! next time i'll post my orcad and gerber file of my clone icd2 here so everybody can have a taste of it!!! trully wonderful debugger and fast programmer too!!!
  26. #186
    Feb 2005
    Kolkata-India
    Default On Change style Int with RB0
    I hope this is the right place to grab your attention. I am using a 16F73 @ 20Mhz with Hardware USART @ 115Kbps. I am using RB0 external interrupt portb.0 (can't help it only it is available) . Initially it is set to fire interrupt on a Low2High edge. Now when inside the interrupt I want to toggle the INT edge bit in the option_reg to have an interrupt on High2Low edge. The simple idea is to reset a timer when a variable duty cycle pulse begin and read the timer value when it turns off. Can't sit in a tight loop to watch if portb.0 = 0 cause got other tasks to do. So I am using Darrel's INT in both ASM and PBP. Here is the code:
    INT_LIST macro   ; IntSource,  Label,         Type,  ResetFlag?
        INT_Handler  INT_INT,     INT_ASM,        ASM,   NO
        INT_Handler  INT_INT,     _INT_PBP,        PBP,   YES
    ; BELOW IS THE ASM INTERRUPT HANDLER
    INT_ASM
           BSF   STATUS, RP0             ; SELECT BANK 1
           BTFSS OPTION_REG, INTEDG      ; CHECK THE INTERRUPT EDGE
           GOTO  EDGE_LOW
    ; IF HERE THEN EDGE IS HIGH2LOW AND INT OCCURED AND NEEDS TO BE ALTERED/////////
    EDGE_HIGH
           BCF   OPTION_REG, INTEDG      ; SET TO INTERRUPT ON LOW2HIGH TRANSITION
           CLRF  STATUS                  ; SELECT BANK0
           CLRF  TMR0                    ; CLEAR TIMER0
           BSF   _HIGH_EDGE              ; SET FLAG THAT THIS IS A LOW2HIGH_EDGE INT
           INT_RETURN                    ; RETURN FROM THE ASM INTERRUPT
    ; IF HERE THEN EDGE IS LOW2HIGH AND INT OCCURED AND NEEDS TO BE ALTERED ////////
    EDGE_LOW
            ; BANK1 IS ALREADY SELECTED
           BSF   OPTION_REG, INTEDG      ; SET TO INTERRUPT ON LOW
           MOVF  TMR0, 0                 ; MOVE TIMER0 TO W
           MOVWF _TIMER                  ; MOVE TO THE TIMER VARIABLE IN BANK 0
           BCF   _HIGH_EDGE              ; SET FLAG THAT THIS IS HIGH2LOW_EDGE INT
    INT_PBP:                     '  PBP INTERRUPT HANDLER
    IF HIGH_EDGE = 1 THEN        '
    HSEROUT [10,"L2H",10]        '
    @ INT_RETURN                 ; RETURN FROM INSTANT INTERRUPT
    HSEROUT [10,"H2L",#TIMER, 10]
    Now my questions are :
    1. Will this work ? Chances of false interrupt should not be, cause anyway while changing the option_reg the INT0 flag is not cleared and taken care of in the next PBP slice. Am I right ?
    2. Should I manually check the transmit buffert (TRMT) and do the transmission to make things faster or let it be handled by PBP (keeps my hairfall under control )
    P.S. : Actually I am counting on the email notification and everybody working with Darrel's II . Lester/Darrel please move this thread if you think that this should go as a new thread.
    Sougata
  27. #187
    As far as the interrupt routines go, it looks like it should work.
    But the limiting factor is the number of bytes you're sending the results with.
    Even at 115200, sending a string of 10 characters will take over 800us. With trying to find both high and low transitions you double that (1600us). So you'd be limiting the frequency to around 600hz.
    I don't think a buffer and TX handler would help speed it up, because it's just the total amount of data being sent that limits it. A buffer would just over-run if it couldn't keep up.
    HTH,
    Jan 2006
    Default Multiple interrupt
    Hi Darrel
    I've seen lots sample codes of digital clock and elapsed timer demos in this forum and all of them are using LCD as an output device. I was wondering why is it that nobody post sample codes driving 7-segment displays in multiplex mode?
    I've seen your code and it was amazing. I tried compiling it but i received errors. I'm using PIC16F628A, 4MHz xTAL and PICBasic Pro v2.33.
    I'm planning to test your code using TMR0 interrupt handling the refreshing of the 7-segments and TMR1 handling the 1/100 timer tick.
    Can you share to me sample approaches on how to handle the elapsed timer using 7-segment displays in multiplexed mode?
    emavil
  29. #189
    Feb 2005
    Kolkata-India
    Thumbs up Thanks Darrel
    It works. Your II rules. I am using it to 100Hz and thanks for your concern.
    Sougata
  30. #190
    Interrupt for 18F's works fine.
    How to write assembly to set a variable instead of toggle led?
    Norm
    '---[TMR1_INT - interrupt handler]------------------------------------------
    ToggleLED1
        btg  _LED1               ; toggle the pin
        INT_RETURN
    That depends on the type of variable, and what you want to set it too.
    INTERRUPT_SET VAR BIT
    set to 1
    Norm
  33. #193
    ToggleLED1
        MOVE?CT   1, _INTERRUPT_SET
        INT_RETURN
    Works good. Thank you.
    I would like to reload timer 1 on each interrupt from a variable.
    Something like:
    wTIMER1 var TMR1L      ' access 16 bits of TMR1
    wTimerPreload VAR WORD
    wTimerPreload  = 65211  'adjust in program
    ToggleLED1
        MOVE?CT   1, _INTERRUPT_SET    ; SET FLAG
        INT_RETURN
    wTIMER1 = wTimerPreload  ; in assembly
    Norm
  35. #195
    See this page...
    DT_INTS-14 (Timer Template)
    http://darreltaylor.com/DT_INTS-14/TimerTemplate.html
    It's in the 14-bit section, but it's pretty much the same for 18F's
    Interrupt now OK with one time adjustable Hz.
    Is their a way to change a Hz variable before each interrupt on?
    wFREQ_Hz var word
    Something like:
    ;--- Change these to match the desired interrupt frequency -------------------
    ;--- See http://DarrelTaylor.com/DT_INTS-14/TimerTemplate.html for more Info.
    ;@Freq = 10 ; Frequency of Interrupts in Hz
    @Freq = wFREQ_Hz ; in assembly
  37. #197
    I don't have anything ready-made for DT_INTs like that.
    But this program has a routine to calculate the timer ticks required to produce a given frequency at a given dutycycle.
    Slow speed Software PWM
    http://www.pbpgroup.com/modules/wfse...hp?articleid=6
    Just use the SetSPWM and CalcSPWM routines.
    The interrupt portion isn't compatible with DT_INTS.
    HTH,
    Jan 2006
    Default Multiple interrupts
    Hi darrel,
    This is my follow up inquiry about your excellent code for multiple interrupts.
    I've seen your code and it was amazing. After compiling, Microcode studio locked up. I'm using PIC16F628A, 4MHz xTAL and PICBasic Pro v2.33.
    Your site states that MPASM is required. Does it have any relevance to the compilation?
  39. #199
    Quote Originally Posted by emavil View Post
    Besides the fact that it won't work without it. No.
    Hmmm, PBP V2.33
    There's been at least a hundred different things fixed with PBP since that version from Several years ago.
    There's no telling what could be going wrong with such an ancient compiler.
    Time to spend the 10 bucks for an upgrade.
    Jan 2006
    thanks a lot for that reply.
    I have also this notion that its really the PBP Compiler that limits me from utilizing your code. thank you very much.
    With regard to PBP 2.33. I managed to enable the feature of 16F628A coz if we look at the installation files, only 16F628 is present.
    Now, my question is, what is really the minimum version of PBP just to compile your "multiple interrupt" codes?
    You said 10 bucks, with all your respect, can you let me have that upgrade for that amount. I'm just a hobbyist and purchasing a new PBP compiler by far costly for me? What are the possible solutions can you suggest?
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 11
