HI
ABOUT THE ROUTINE WRITTEN BY MR MISTER_E.
I NEED HELP HOW TO MAKE THE NUMBERS ARE IN SERIES EXAMPLES 12345566
AND THEN PRESS THE BUTTON # SEND VIA SERIAL A SEQUECIA.
__config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _CP_OFF & _LVP_OFF & _WRT_OFF
TRISA=%00000011
TRISB=%00000000
TRISC=%11111110
ADCON0=%11000000
ADCON1=%00000111
INCLUDE "KeyPad2.bas"
' Hardware connection
DEFINE KEYPAD_ROW 4
DEFINE KEYPAD_ROW_PORT PORTC
DEFINE KEYPAD_ROW_BIT 0
DEFINE KEYPAD_COL 3
DEFINE KEYPAD_COL_PORT PORTC
DEFINE KEYPAD_COL_BIT 4
DEFINE KEYPAD_DEBOUNCEMS 200 'debounce delay = 200 mSec
define KEYPAD_AUTOREPEAT 1 'use auto-repeat
' LCD Display
' Adjust these to suit your chosen LCD pinout
'----DEFINIR LCD--------------------------------------------------------------
DEFINE LCD_DREG PORTB ' LCD data port
DEFINE LCD_DBIT 4 ' LCD data starting bit
DEFINE LCD_RSREG PORTB ' LCD register select port
DEFINE LCD_RSBIT 2 ' LCD register select bit
DEFINE LCD_EREG PORTB ' LCD enable port
DEFINE LCD_EBIT 3 ' LCD enable bit
DEFINE LCD_BITS 4 ' LCD data bus size
DEFINE LCD_LINES 2 ' Number lines on LCD
DEFINE LCD_COMMANDUS 5000 ' Command delay time in us
DEFINE LCD_DATAUS 50 ' Data delay time in us
mykey VAR BYTE
myvar var byte
array var byte[5]
index var byte
i var byte
word_v var word
LCDOUT $FE,1, " FONTE DIGITAL "
PAUSE 1000
LCDOUT $FE,1
' ---------------------------------[Program Start]----------------------------------------------
start:
@ READKEYPAD _myvar
gosub lcddisp
goto start
lcddisp:
LCDOUT $FE,$C0,DEC4 myvar
pause 60
