serin2 read until?
Results 1 to 8 of 8
    eoasap's Avatar
    eoasap Guest
    Default serin2 read until?
    is there a way to perform a serin2 read until CR or a defined char is received?
    Dec 2003
    Wichita KS
    You can loop the Serin2 or the Serin until the predetermined "Flag" is found.
    Loop:
    serin datapin....variable.
    Process by storing data in Eprom or whatever
    if variable <> CR (or flag) goto Loop:
    This is assuming you are reading 1 char at a time.
    I don't know how your data is being sent... but you can read a string of char and check for the "Flag" before looping back.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    eoasap's Avatar
    eoasap Guest
    Thanks Dwayne, i'll work on that first thing saturday morning. do you think there will be any dataloss doing a loop for the read?
    so pseudo code something like this?
    loop:
    SERIN2 one byte
    check that byte for Carriage return (when to stop)
    if CR, exit_loop
    goto loop
    exit_loop:
    Dec 2003
    Wichita KS
    Hello eoasap,
    e>>so pseudo code something like this?
    loop:
    SERIN2 one byte
    if CR, exit_loop
    process data
    goto loop
    exit_loop;
    yes this is a good pseudo code example.
    Now to answer your other question:
    This depends on how your data is being sent. If it is a non-stop 40 characters, yes, you will lose some data. You will have to change your read to a different method... like reading in a string of characters or something before processing.
    If your data is coming in spurts, you can use a "control" character to "flag the receiver that the following character is the one you want read.
    If I were you, I would *FIRST* find out HOW the data is being sent to you. Then program your PIC for this format of sending. *IF* you can chose the way the data is being sent to you, then you have many many available options!...
    Dwayne
    Ability to Fly:
    eoasap, to answer your original question, use the "WAITSTR" modifier to finish loading your array of characters or variables. This is covered in your manual under "SERIN2".
    eoasap's Avatar
    eoasap Guest
    I through about that, but doesn't WAITSTR wait for that string before reading in bytes? i want to read in bytes until a certain byte is received (carriage return),
    The length of the string being received is unknown, but terminated with the carriage return
    eoasap, I'm Sorry, What I meant was to use the optional ending character to finish the array load. I usually use the carriage return character $0D to end my input strings. Sorry for the confusion.....
    eoasap's Avatar
    eoasap Guest
    Thanks Dave, I'll give that a try
  1. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  3. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 15:25
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  5. Serin2 - All I Need Is 8 Numbers....
    By SOMRU in forum Serial
    Last Post: - 14th December 2006, 13:50
