micro code studio plus asm error
Results 1 to 8 of 8
    cesurcelik's Avatar
    cesurcelik Guest
    Angry micro code studio plus asm error
    hi everybody.
    when i try to compile code with the mcsp ,it gives compiling error ,it says;
    fatal:[302] unable to open file 'xxxxxx.asm' which is i want to compile.
    i couldn't sort it out what the problem is.
    does anybody know what the problem is?
    best regards.
    cesur
    Perth, Australia
    does it give you any other errors or warning before this error?
    it looks like it isnt generating a .asm file due to some other error.
    cesurcelik's Avatar
    cesurcelik Guest
    hi kamikaze47,
    no,it dosen't give any errors or warnings,before compiling.
    Perth, Australia
    does it do it for any code? will it compile one of the sample programs that come with mcsp?
    can u post everything that is logged when you try to compile
    cesurcelik's Avatar
    cesurcelik Guest
    hi kamikaze47
    i solved that problem,but it's so weird; i thought that might've been the file name too long so i changed the file name "mat.bas" instead of "matrix_ser_den0".bas,i was right ,it's ok now!
    many thanks for your help.
    gwen's Avatar
    gwen Guest
    Hi, I noticed that any file name longer than 8 letter are not compiled. You have to chose short names.
    I had the same probleme few days ago.
    cheers
    Mentor, Ohio
    Smile
    Hello,
    I have using file names with 22 to 28 characters in length and have not any compiling problems.
    cesurcelik's Avatar
    cesurcelik Guest
    as i told that it's so weird! i can't explain that. i hope that someone explain it.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Making Program Code Space your playground...
  3. EPIC, Code programming error at 0000
    By shorton in forum General
    Last Post: - 29th May 2007, 00:26
  4. ASM (I am Working in ECU for Micro Turbines
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 29th January 2005, 01:00
  5. ASM Interrupts with BASIC code?
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 19:21
