multiple serial inputs
Results 1 to 3 of 3
    Richardco's Avatar
    Richardco Guest
    Smile multiple serial inputs
    Hi All, Well i was hoping that when someone looks at the diagram i have provided they will say " oh yeh i know how to do that here is the code" However being a realist as well i dont suppose that will happen so, would anyone have any example code that i would be able to modify or look at to help me get where i want to go as indicated in the diagramm....Please.
    Feb 2004
    Germany
    Richardco,
    if you had provided a bit more details on the other thread you definitly had got a more qualified answer.
    The "NMEA-Multiplexer" issue has already been discussed on this forum.
    Please use the "Search"
    As there is no defined timing between the different talkers I would prefer to have one (small) PIC per Talker to listen to the NMEA sentences and one "MASTER" PIC to combine the different sentences oito one telegram.
    That way you don't miss any sentence from any talker, and you can easily convert sentences before you send out the combined telegram to the bus.
    regards
    Ralph
    Richardco's Avatar
    Richardco Guest
    Ok ive put this post in the wrong place so to save posting it again here is where this thread continues http://www.picbasic.co.uk/forum/showthread.php?t=2827
    sorry
  1. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 15:13
  2. Multiple Pics to One serial port
    By Rleonard in forum Serial
    Last Post: - 18th January 2007, 18:30
  3. 2 Serial inputs at the same time?
    By a_critchlow in forum Serial
    Last Post: - 29th January 2006, 14:07
  4. Multiple Servo Control --Serial
    By gbm_designs in forum mel PIC BASIC Pro
    Last Post: - 24th December 2004, 01:28
  5. RX two serial inputs at the same time?
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 31st October 2004, 10:57
